Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Misc. For Sale
Old 03-03-2022, 08:10 AM   #1
C.I.Blazer
WTB 15x8 Steelie
Looking for 1 15x8 4 nub steel wheel (6x5.5) to use for a spare. Thought I would see if something original is out there before going with Wheel Vintiques.
Thanks!
C.I.Blazer is offline   Reply With Quote
Old 03-03-2022, 06:54 PM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB 15x8 Steelie
Just a suggestion but might want to ask a Mod to move this to the WTB parts forum as this is posted to "Misc. for Sale" section. Might get better response. Those steel 6 lug 15 x 8s can be rough to find and don't come cheap. Good luck with your search. Swap meets can be your friend if you have any local to you.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 03-29-2022, 05:54 PM   #3
Grandpa's CST
Grandpa's CST's Avatar
C.I.Blazer they are back in stock at Summit racing the WV series 62
..........._____|__\___
..........|_(O)_____(O)]
Grandpa's CST is offline   Reply With Quote
Old 04-06-2022, 09:35 AM   #4
Eagle9502
Will the original stainless dog dish hubcaps work with these Wheel Vintique wheels?
Eagle9502 is offline   Reply With Quote
Old 04-06-2022, 01:27 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Wheel Vintiques makes a 6-lug Series 62 wheel now?
Keith
Convert to disc brakes.
Old 04-06-2022, 02:24 PM   #6
cwcarpenter98
cwcarpenter98's Avatar
Yes, they will if your hubcaps are the nub style caps.
They have made them for awhile now, but was apparently either discontinued for a bit or just out of stock for a bit. I've got a set of them on my 63 that I bought used almost 3 years ago. The original purchaser had bought them a year or two prior to removing them after switching to 5 lug
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 04-06-2022, 02:27 PM   #7
lolife99
lolife99's Avatar
They have made them for awhile now, but was apparently either discontinued for a bit or just out of stock for a bit. I've got a set of them on my 63 that I bought used almost 3 years ago. The original purchaser has bought them a year or two prior to removing them after switching to 5 lug
Thanks. I had no idea.
Do they make them in 15x8?
I can’t find them.
With the skyrocketing prices of the original 15x8 CUCV wheels, these are a great alternative.
Keith
Old 04-06-2022, 02:29 PM   #8
lolife99
lolife99's Avatar
I did find these,…
Keith
Old 04-06-2022, 09:12 PM   #9
cwcarpenter98
Yes, mine are 15x8s
All of my hubcaps stayed on when I went over a stupid rough section of I-20 outside of Atlanta that made me feel like the whole truck left the pavement for a second or two
Christian Carpenter
Old 04-08-2022, 09:00 AM   #10
Eagle9502
I had heard from some that they did not work so good to know.
I do notice the Wheel Vintiques are 3 nub, the cucv's are 4 nub.
Old 04-08-2022, 12:44 PM   #11
cwcarpenter98
You have to make sure you order the correct style.
One style they sell is made for the Corvette style caps that mount to the inside of the lug nut area. This one has no nubs on the outside for the nub style hubcaps.
The style posted by lolife99 and what I have on my truck is the one you need for nub style caps.
I've been pleased with the quality of my wheels and even though I bought them used, they were basically new. The tires I put on are the second set of tires on the wheels
Christian Carpenter
Old 04-23-2022, 10:54 PM   #12
72FamilyBlazer
I did find these,…
Those are nice! I just looked them up and the reviews say they don't fit front Disc brakes. bummer..
72FamilyBlazer is offline   Reply With Quote
Old 04-24-2022, 12:25 AM   #13
cwcarpenter98
I have stock 1.25" squarebody brakes on my 63 (6 lug rotor though) and they clear my wheels with no problems at all. I don't remember my exact backspacing, but it's either 4" or 4.25". Not sure when I'll get a chance to pull the wheel off for a measurement though
Christian Carpenter
Old 04-26-2022, 07:43 AM   #14
C.I.Blazer
I heard the same thing, that they will not fit on the front with disc brakes. I can still buy one and use it as a spare. Just would require swapping a rear to the front and the spare on the rear if I ever had a flat up front.
Can anyone confirm on the disc brake question?
Old 04-26-2022, 05:40 PM   #15
leddzepp
Moderator
leddzepp's Avatar
The 5 lug 15x8 would not clear the calipers on a set of 88-98 spindles I have. They were 4.25” backspace. I sent them back to summit racing. They may have fit if I ground off some material on the calipers but I did not want to do that. I believe the 6 lug wheels are also 4.25” backspace. I plan on getting 6 lug rotors and using my 6 lug CUCV wheels as they are 3.75” backspace and should hopefully clear the calipers.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
