04-03-2022, 08:43 AM | #2801 |
Re: What did you do to your truck today.The 3rd chapter
Very cool, nice work.
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
04-03-2022, 11:47 AM | #2802 |
Very nice work
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-03-2022, 11:49 AM | #2803 |
Who Changed This?
Nice! I also like what you did with the dash and glove box door.
04-03-2022, 12:42 PM | #2804 |
04-03-2022, 02:11 PM | #2805 |
Who Changed This?
Not at first. Nice to carry the theme across the whole dash!
04-03-2022, 11:34 PM | #2806 |
yes a little bitt of Purple goes a long ways
04-04-2022, 12:34 AM | #2807 | |
04-08-2022, 07:14 PM | #2808 |
At the body shop.
Hei mis firing like a wet or cracked cap.
Nah just a broken ground wire. Sure glad I spent the money for 10 cent connection
" That didnt make it any newer " " Dont antique the equipment " |
04-08-2022, 07:52 PM | #2809 |
Who Changed This?
Keep a spare module in the glove box. When that ground wire is missing/detached, the module is "walking wounded" and may fail at any time, even after completing that circuit.
04-08-2022, 08:29 PM | #2810 | |
At the body shop.
I replaced the gm module with the msd digital style. I left the gm one and wiring in the glove box though.
04-10-2022, 01:31 AM | #2811 |
Update on the new console I'm building. It has been bolted down for the first time and the door is on and working, the lower has been test fitted, still need to cut in the cup holders and wire up the switches. have decided to add floor lights on the sides too. When completed it will be black with stained wood to match the box.
04-20-2022, 12:16 PM | #2812 |
Almost done
04-21-2022, 08:51 PM | #2813 |
Done stamp on this one, even got the fuzzy stuff inside . Had my nephew 3D out some custom sized cup holders and the trim ring for the shifter.
04-21-2022, 09:41 PM | #2814 |
Wow, that looks fantastic! Nice work.
04-21-2022, 11:48 PM | #2815 |
My idea here was to bring in the look of the box to the cab. switches are for the electric dumps and the passenger door release to let someone in. The deep part of the console is for tools, guns, booze
04-22-2022, 07:27 PM | #2816 |
Looks great .
04-22-2022, 07:33 PM | #2817 |
I sorted out the 68 Golden . PO really screwed it up Points we’re from god knows where and not for the truck . I replaced them roughed in the gap sounded much better . Timing was 4 degreees or so after TDC corrected that got the dwell meter out set the points to 30 degrees and the idle to 750 . Runs great smoothed right out . Now to get the gas tank sorted out can’t run it on a gallon can under the hood to far .
04-22-2022, 07:50 PM | #2818 |
70+ ( Old Skool Club )
A friend came to help and we got my Truxedo Lo Pro Tonneau cover on the truck. Does anyone know here you can buy plugs or anything that can go into the stake pockets and seal them.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-22-2022, 09:12 PM | #2819 |
Today I bought a L83/6L80E combo with under 50K on them. As soon as they arrive I will be yanking out that 402 BB and the TH400 with the Doug Nash OD to make room for this combo. I have already installed a 30 Gallon Tanks Inc fuel tank between the bed rails in back and fabricated this fuel filler in the corner of the bed. So let the party begin!
To be born a Redneck is by chance to live your life as a Redneck is a lifestyle. Lifelong Gearhead, if it's fast make it Faster! |
04-22-2022, 11:34 PM | #2820 |
Finished 2 1/2" lift kit last night.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
04-23-2022, 12:05 AM | #2821 |
I'm curious, what is the height to the top of the cab now? In other words, does in fit through a standard garage door now?
Nice looking!
Ron 1972 Cheyenne Super 1/2 ton LWB 4x4 - Grapefruit Yellow / White |
04-23-2022, 07:45 AM | #2822 | |
04-23-2022, 07:48 PM | #2823 |
At the body shop.
Swap meet score
Pair of stainless wind wings to replace my rusty ones.
04-23-2022, 09:28 PM | #2824 |
Finally got everything together to make some brackets to properly mount the early 90’s seat in my 67. The PO had put the seat in and I do like it better than the original but they had just drilled holes in the floor to mount. I don’t think that is the safe or proper way to do it.
Bent the brackets to match the 67 floor profile and drilled holes for proper bolting. Then used grade 8 studs and threaded/welded them in the bracket. Once the seat was in I just had to put the 3 point seat belts in.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-23-2022, 10:43 PM | #2825 |
Yes, it fits in standard door no problem. The antenna hits, need to trim 6" off, have solid antenna and I don't want bend the cowl.
