05-14-2022, 08:35 PM | #1 |
One piece driveshaft swap
I am thinking of replacing the two piece driveshaft in my th400 Dana 60 leaf axle equipped 67 c20,had new rear half made and need to replace center support bearing after 3000 miles.I measured the one piece in my 2002 lwb Siverado,it is about an inch too long.Anyone know of an application that would work better?I know slip yoke would have to be changed as well as trailing arm crossmember removed.Truck has had a vibration ever since build,not from wheels/tires.Most driveshaft companies will not build one as long as I need.Thanks
05-14-2022, 11:38 PM | #2 |
Re: One piece driveshaft swap
I just did it. Went to a local shop and they cut it down and balanced it for me. In fact the drive he cut down was out of a Siverado.
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a million pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" 2012 Jeep JKU "Crush" 1976 Chevy short bed with a 327 and 3 on the tree (Sold it to buy the Blazer) 1971 Chevy Blazer (Sold it) |
05-16-2022, 07:18 PM | #3 |
I'm interested on how this turns out. I have a 70 C20 with driveline vibration. Had the 2 piece rebuilt and balanced with no change.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
05-17-2022, 10:04 AM | #4 |
Getting ready to swap a 6.0/4L80 in my c20 and I’m thinking the same. Just the trans is 11.5” longer than the existing 4 spd. Haven’t made it that far so I’m following.
70 C20 Build link : Project Montezuma http://67-72chevytrucks.com/vboard/s...d.php?t=794479 How to repair that rusted out 67-72 c10-c30! Please subscribe! https://www.youtube.com/c/MaycoCustomRestorations |
05-17-2022, 05:40 PM | #5 |
Here is how I did mine. I measured from the end of the transmission output shaft to the diff ujoint cap. Then I subtracted an inch and had it cut and balanced.
Note: I went from a two piece shaft to one piece. I was going to cut out the center carrier out of the two piece as I made my truck a 6' bed. I was told that a cut down two piece would vibrate and that I needed a 4" diameter drive shaft.
05-17-2022, 09:25 PM | #6 | |
Is your truck a leaf or coil spring rear suspension? You mentioned both styles. Has the truck been lowered or lifted? What are the U-joint angles? There may be other issues than the drive lines. Have you had the rear end throughly inspected? Worn bearings in the rear axle will cause vibration issues.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-29-2022, 07:55 AM | #7 |
Thanks for the replies.
