Old 05-17-2022, 12:36 AM   #1
Dodge68charger
Disc/Disc Proportioning Valve Help?
Hey Guys im running a disc/disc setup in my 1969 C10. Front Ends From a 87 GM Vehicles. Rear Ends From a Early 90’s Truck..
Do I run any sort of proportioning valve with a disc/disc setup?
The front brake lines are tee’d together and one 1/4 line from the rear.
Dodge68charger is offline   Reply With Quote
Old 05-17-2022, 12:43 AM   #2
Accelo
Accelo's Avatar
Re: Disc/Disc Proportioning Valve Help?
The short answer is yes.
A panic stop would be dangerous without one.
They sell them for disc-disc set ups. Or Drum-discs, different part numbers.
Accelo is offline   Reply With Quote
Old 05-17-2022, 10:31 AM   #3
68 P.O.S.
https://www.summitracing.com/search/...plication/disc
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 05-17-2022, 11:34 AM   #4
j_cst_10
j_cst_10's Avatar
I run maximum ine pressure to the fronts (T'd no prop valve) and a single adjustable for the rear line. Dial the rear back until they do not lock up first. This is a common way to do it.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 05-17-2022, 03:00 PM   #5
BASE
BASE's Avatar
It's not clear to me if the disc/disc valves do any proportioning. I'm guessing not, but it probably gives you the safety valve and warning light switch. I may be way off, but I've never seen any specs on what kind of bias they use. I guess I haven't seen that for a disc/drum valve either though. You would think that requirement would vary a lot based on front to rear caliper piston size, weight dist, etc. I was going to plumb mine without any kind of valve but now I've about talked myself into the adjustable setup.
'68 K10 496/465/205
BASE is offline   Reply With Quote
Old 05-17-2022, 04:17 PM   #6
Caddylackn
Caddylackn's Avatar
The front gets a lot of extra weight thrown on it during braking, while the rear end gets lighter during braking Given the same hydraulic brake pressure the rear will lock up first since there is the least weight on it. The proportioning valve lets you add some internal resistance in the rear brake line so the rear will lock up around the same time as the front.
An adjustable proportioning valve lets you dial it in with different loads.
1969 Custom Camper C20; Factree Air, 350/TH400/Dana 70U with C30 wheel cylinders, Disk brakes, H4 conversion, headlight relay mod, 3G 135 amp alternator. 7500 GVW
Caddylackn is offline   Reply With Quote
Old 05-17-2022, 06:07 PM   #7
68 P.O.S.
Yes, it does. The disc/disc combo valves still have a proportioning valve in the back, pressure differential switch (warning light) in the middle, and metering valve in the front.
Old 05-17-2022, 07:28 PM   #8
Dodge68charger
Is MP Brakes a Good Quality Parts Company?
They Got Some Nice Stuff On Their Site!
