08-06-2022, 11:45 AM | #1 |
brothers disc brake conversion kit
Bought a kit off market place today. Came off a guys 66. Going to go on my 65. Complete kit, master, drop spindles, discs, calipers.
I tried digging up info on the kit but cant find much. The holley site, doesnt tell you anything. What outer tie rod do I need to use? Where can I get replacement rotors and pads when the time comes? Thanks in advance. |
08-06-2022, 02:36 PM | #2 |
Re: brothers disc brake conversion kit
Tie rod will depend on what spindle you have. Was the kit designed for the stock ball joints, or different year ball joints? Most likely the tie rod end corresponds to whatever year ball joints were used.
Is it 6 lug or 5 lug? If 6 lug, you'll have to special order the 6 lug rotor. CPP sells just the rotor I believe. You can probably find it on Summit Racing. If 5 lug, you can go to your local parts store of choice to get a stock rotor for the later model trucks. Just make sure you order the correct 5 lug rotor (1.25" vs. 1" rotor). You will most likely be able to acquire new pads and calipers for the same year truck you get a 5 lug rotor from if the stuff is stock type. So, got any pictures of what you purchased? Maybe a part number?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-06-2022, 03:00 PM | #3 |
Thanks for the info. I havent dug into it yet. Working today. Ill take a look. They are 6 lug.
08-06-2022, 08:14 PM | #4 |
If the kit was recently purchased, there's a good chance the spindle is made for the factory ball joints for your truck. If it's an older kit, it could be for square body ball joints.
The kit I purchased over 7 years ago, aka before the aftermarket spindles were commonly being manufactured to use the older ball joints, uses square body ball joints in the 63 control arms. Basically, what I'm saying is order the ball joints and tie rod end stuff that works with your drop spindle and you should be good
08-07-2022, 09:49 AM | #5 | |
08-07-2022, 01:34 PM | #6 |
Happy to help!
08-13-2022, 11:11 PM | #7 | |
08-14-2022, 09:28 AM | #8 |
08-14-2022, 09:39 AM | #9 |
