08-03-2022, 04:23 AM | #1 |
Radio/stereo connector
Was wondering if anyone had a connector that looks like this one with the same wires and everything. My 1977 c10 has the yellow wire snipped to close to the connecter to resolder it back together. if someone can give me a link to a company selling the connector with the wires.
Posted via Mobile Device Last edited by old Rusty C10; 08-03-2022 at 10:12 AM. |
08-03-2022, 10:18 AM | #2 |
Re: Radio/stereo connector
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
08-06-2022, 09:31 PM | #3 |
If you go to the pick and pull yard you can get that Speaker wire Connector plug off any GM factory stereo car73-88 or truck73-90, from radio shop still open or try Standard auto motive wiring still may have them throw other seller. like other Summit Racing.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
08-07-2022, 02:10 PM | #4 |
Does this look like your connector? https://www.rockauto.com/en/catalog/...connector,2612
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
08-07-2022, 10:55 PM | #5 |
check to see if you can just replace the metal connector that the wire is crimped to. Some of these plugs can be disassembled with a small small flat head
