Old 08-20-2022, 10:09 AM   #3076
HO455
HO455's Avatar
Re: What did you do to your truck today.The 3rd chapter
That looks good. I need to do that.
RIP Bob Parks.
Old 08-20-2022, 10:10 AM   #3077
HO455
HO455's Avatar
Originally Posted by tdangle View Post
Finally got the floor finished and added new wheel wells. Next step when I recover is prep for paint. This is my daily driver so I did the bed while on the truck
Wow that is sharp looking!
RIP Bob Parks.
Old 08-20-2022, 02:32 PM   #3078
72c20customcamper
72c20customcamper's Avatar
Semi restored the heater box . Need to get some HVAC foam tape for around the upper hose inlet . So far everything on the truck seems to have been made around oct 1967 so pretty much original to the truck
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 08-20-2022, 02:36 PM   #3079
72c20customcamper
I’m liking this flex seal liquid rubber . Works great on wire clamps dip’d twice in 6 hours left overnight to dry this is dry
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-20-2022, 05:28 PM   #3080
72c20customcamper
Got the dash apart going to paint the inside cab this week . Had to put the cluster back in to move it . Almost started it with the oil line dangling.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-21-2022, 09:24 AM   #3081
Jiggers72-GMC
Jiggers72-GMC's Avatar
LoL Mark, that would be a good/bad way to check the oil pressure
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 08-22-2022, 04:36 PM   #3082
Marty68
this MONTH the 283 that came with my truck lost compression on one cylinder each bank. so i recruited my daughters boy friend to help swap in a fresh "corevette" 350 78 vette 30k miles 10 miles on rebuild domed pistons roller timing chain rockers and hyd roller rockers. builder stated 400 hp. maybe 375. my forst engine swap sonce the 80s. new exhaust being installed today.
Marty68 is offline   Reply With Quote
Old 08-23-2022, 07:28 PM   #3083
72c20customcamper
Got the gate , tail lite brackets and glove box door epoxy primed . Going to spray the high build tomorrow have a 72 hour open window .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-23-2022, 07:31 PM   #3084
72c20customcamper
Little bummed out . Gathered up the tail lites and one of the backup lites is damaged . I know it wasn’t when I bought it so it must have got bumped around in the storage box .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-24-2022, 11:08 AM   #3085
thedudeabides86
Active Member
thedudeabides86's Avatar
After a few years of running this truck on my own sweat, cussin', and frustration, I got it serviced. Sealed up all the gaskets, replaced the intake, carb, and exhaust manifolds and it hauls a$# now!! Still needs a lot more work, bust she's prettier now.
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 08-24-2022, 11:49 AM   #3086
OregonNed
OregonNed's Avatar
Ignition switch changed out and overall cleaned up for this Saturday's next car show.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 08-24-2022, 07:11 PM   #3087
72c20customcamper
Got the inside of the cab ready for paint . There were runs on the dash and back panel. The runs were actually in the primer .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-25-2022, 07:10 PM   #3088
72c20customcamper
Got some more done on the cab. Not going to be able to paint till at least Sunday . Going to pick up mom tomorrow and Saturday is my granddaughters 1st birthday party. Tailgate and dash pieces are all sanded and ready for paint . The roof was really weird lots of what looked like drips in the primer and very thin paint . Need to hook up the oil pressure gage so I can move it into the garage for paint. I have the cluster apart to repaint the bezel and needles .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-25-2022, 07:14 PM   #3089
72c20customcamper
And I finally got a grommet that fits
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-26-2022, 04:20 PM   #3090
67C10Step
67C10Step's Avatar
Steering wheel upgrade thanks to the wife. Birthday present.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is online now   Reply With Quote
Old 08-26-2022, 05:36 PM   #3091
LNP
Nice! Happy Belated Birthday
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 08-26-2022, 05:39 PM   #3092
LNP
Originally Posted by 67C10Step View Post
Finished up the install of the S10 washer bottle and pump. Don’t think the squirters ever worked that good.
I take it the original wiper/washer switch doesnt work the pump or does it? I got a 69 so its more a mechanical pump.
Harley
Old 08-26-2022, 05:46 PM   #3093
Grumpy old man
Grumpy old man's Avatar
Looks Good ! Every time Mrs Grumpy comes home and sees another box from Fed Ex / UPS or Summit she says "Did I get another birthday present ?"
Old 08-26-2022, 05:54 PM   #3094
LNP
hahahahaha
Harley
Old 08-26-2022, 09:05 PM   #3095
67C10Step
67C10Step's Avatar
The original switch on the wiper/washer runs the new pump. With the hoses no longer running through the firewall there was a perfect pass through for the wiring harness I built plus the fuel level from the rear mounted tank.
The old click clack pump had a sort of timer but this one will run only when you hold the button in. But it squirts way better.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 08-27-2022, 09:17 AM   #3096
LNP
I will check the switch out to see how you wired it. Thanks. I like the idea of the electric pump. And the tank looks like it fits well there too. Thanks again
Harley
Old 08-27-2022, 09:17 AM   #3097
LNP
Awesome!!
Harley
Old 08-27-2022, 07:37 PM   #3098
72c20customcamper
Set up my “Spray booth” today
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 08-27-2022, 08:38 PM   #3099
68bowtie
68bowtie's Avatar
I trimmed in my carpet today and installed the dash pad and belts. The ACC carpet was a damn good fit in general, just a bit more wrinkle than I’d like over the trans hump. But I can live with it. I expected way worse.
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
68bowtie is online now   Reply With Quote
Old 08-27-2022, 08:56 PM   #3100
67C10Step
67C10Step's Avatar
68,
Let me be the first to say that looks fantastic!
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
