09-03-2022, 05:12 PM | #1 |
Rear Parking Brake Cable for 4” lift?
My parking brake cable started to fray and was causing binding. Order a new set off Brothers. Of course they are short and not for a 4x4. (Their listing didn’t specify)
Can anyone point me towards stock cables I can use? I’m just looking for the rear portion going from the drum to the connector that sits in the middle of the truck. I see some go with Lokar but I’m not looking to replace the whole system. Ideas? |
09-04-2022, 08:07 AM | #2 |
Re: Rear Parking Brake Cable for 4” lift?
I have an extra set of black Lokars I'm not using, can be cut down, don't know if they would work for your application since I went a different route
I can measure them, but I don't know how a factory connector looks at the center link, if you have a pic, I could confirm if these would work
09-04-2022, 08:50 AM | #3 |
I have a 14 bolt and it matters as to the connection at your brakes. I went to the junk yard and found a set off of a FURD van were long enough and had the right connections. 4 inch lift of course.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-04-2022, 01:43 PM | #4 | |
09-05-2022, 10:25 AM | #5 |
Having a hard time loading pics, but cable ends at connector are blank, brake arm has a swaged ball, LMK
09-05-2022, 10:28 AM | #6 |
09-17-2022, 07:28 PM | #7 |
Just to wrap up this thread. Found the cables at In-Line tube. Correct length 48”.
09-20-2022, 11:46 AM | #8 |
