Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-28-2022, 09:21 AM   #3426
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
So that’s the answer
Yeah, I think Ray Charles could weld better than me
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-01-2022, 09:05 AM   #3427
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16646293177813820326499128216283 by James Jaros, on Flickr
Ok second attempt, spot welds weren't strong enough, more weld
Turned heat up, wire speed down
SAFETY FIRST
AS usual, off topic
Jim
Old 10-01-2022, 09:16 AM   #3428
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16646300026108707310386517396770 by James Jaros, on Flickr
I like the idea GMC had on the access holes, may cut 2 more, top and bottom, for my C clamps
SAFETY FIRST
AS usual, off topic
Jim
Old 10-01-2022, 03:46 PM   #3429
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Jim,
I like how you are keeping at it, It has been a long haul for you.
I'm excioted to see the end result.
Doug
low'n slow is offline   Reply With Quote
Old 10-02-2022, 09:51 AM   #3430
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for the encouragement, I call it my therapy
Glad I bought my camaro back in 15, at least I have something fun to drive....
Doug, thanks for stopping by and posting up, sometimes I wonder if anyone really reads this stuff, glacially slow
Going on 7 weeks of lower back pain, twice to the hospital and once to doctors office, to no avail,just injections and pills, that's not the lifestyle I want
I think I may have found my welder problem someone switched to 035 welding wire, I'm used to 023
SAFETY FIRST
AS usual, off topic
Jim
Old 10-15-2022, 09:23 AM   #3431
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16658400680457579285331816009724 by James Jaros, on Flickr
Apparently, lead work falls in the same category as welding, if you can’t lead good,lead alot
Start over
SAFETY FIRST
AS usual, off topic
Jim
Old 10-17-2022, 12:31 PM   #3432
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Clean up on isle 3
Ledd zep gave me a smoking deal on a speed warning buzzer, last part of that system, now I have to wire and mount, any clues on mounting location welcomed
16660239156701578065190211596116 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 10-17-2022, 01:31 PM   #3433
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16660275236377039429056022507464 by James Jaros, on Flickr
Identify the use of this tool, it was in my Dewalt drive set
Has a Phillips head but no threads, sleeve is magnetic
OEM prize available for correct answer
No internet search or calling Dewalt lol
SAFETY FIRST
AS usual, off topic
Jim
Old 10-17-2022, 06:29 PM   #3434
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
Is it one of those bit holders, where the bit slides in, and the sleeve contacts what you are screwing into.
Thus disengaging the screw to prevent overdriving it? Like for drywall?
litebulblsc is offline   Reply With Quote
Old 10-18-2022, 08:22 AM   #3435
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: PO has me PO'd
It holds the screw for you so you don't drop it?
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 10-19-2022, 09:56 AM   #3436
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Can't say that either of you are wrong, because I don't know what it is.?..
SAFETY FIRST
AS usual, off topic
Jim
Old 10-19-2022, 12:32 PM   #3437
CG
BlahBlahBlah
Re: PO has me PO'd
Mine is a version of yours. Basically you can put one of your bits in there and I makes it magnetic. They are a bugger to get back out though. Kinda works like a socket locks onto a socket wrench. Here is a pic of mine with the diagram that is in the mini holder
Almost looks like yours has a screw stuck in it. Kinda hard to tell in the pic
Old 10-20-2022, 06:28 AM   #3438
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
OK CG, tried it and it works, just really snug, didn't want to break it.
So it looks like we have a winner
SAFETY FIRST
AS usual, off topic
Jim
Old 10-20-2022, 06:33 AM   #3439
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16662619029735887295601303952669 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 10-20-2022, 09:36 AM   #3440
CG
BlahBlahBlah
Re: PO has me PO'd
I have a few of those sets so it’s kinda like I cheated =)
I picked them up when I worked at Lowes, the people that worked in tools always let me know when something went on clearance.
Old 10-21-2022, 10:09 AM   #3441
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16663611590767148743234464889880 by [url=https://www.flickr.com/photos/97391199@N06
How about a w/s knob, do you need it, I think it's a 67 or 68
I put the set screw in it to check thread size..............?..
SAFETY FIRST
AS usual, off topic
Jim
Old 10-21-2022, 10:37 PM   #3442
CG
BlahBlahBlah
Re: PO has me PO'd
No prize necessary, happy to have contributed =)
Old 10-22-2022, 10:00 AM   #3443
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
BTW, thanks for the oil filter
16664470247175019608423288234761 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 11-02-2022, 10:22 AM   #3444
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16673984703773450446192185152939 by James Jaros, on Flickr
Just wanted to make a fillet, for added strength and fill in my burn through
Need to practice welding, no burn through
Lead work sucked, dirty work area probably the cause
Need to move forward on this area, so this was the only solution so far
This stuff has been laying around for ever and still works
SAFETY FIRST
AS usual, off topic
Jim
Old 11-05-2022, 10:51 AM   #3445
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16676596374944128832282892444689 by James Jaros, on Flickr
Looking like a B post to me, or at least 1/2 of a B post
SAFETY FIRST
AS usual, off topic
Jim
Old 11-05-2022, 08:15 PM   #3446
low'n slow
low'n slow's Avatar
Re: PO has me PO'd
Keep at it Jim.
Looking good.
Old 11-06-2022, 07:17 PM   #3447
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by low'n slow View Post
Keep at it Jim.
Looking good.
Thanks bud, I think you may be one of the few people who actually follow this stuff, but now I have to figure out what the piece looks like that bolts to the area I'm working on.
I suppose it mounts to the torsion box, may have to buy one.....
SAFETY FIRST
AS usual, off topic
Jim
Old 11-07-2022, 11:37 AM   #3448
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
16678352221473917045362126754143 by James Jaros, on Flickr
Now I have to build the flange wit square nuts welded on, I think I have them, bought from McMaster Carr
Paper cut outs
SAFETY FIRST
AS usual, off topic
Jim
Old 11-07-2022, 03:50 PM   #3449
Thealien
Thealien's Avatar
Re: PO has me PO'd
I’m sure there’s a bunch of us that have been following along. I don’t usually comment but I do check every time you post an update.
Old 11-07-2022, 08:38 PM   #3450
litebulblsc
Re: PO has me PO'd
This
