03-05-2023, 12:14 AM | #3626 |
Re: What did you do to your truck today.The 3rd chapter
Not much to show but big day man. This has been what's approaching an 8 year project. I'm still waiting on bumpers, upholstery held hostage by a covid economy, hub caps, and the grilles I'll install after the A/C is charged. Beyond that I had one last thing I could possibly do, and that's install the windshield wipers.
I've only seen the truck with a battery say 20 minutes. Everything works so far, but then came what I was waiting for most, the washer pump. not a drop. Clicked that dude say a dozen times or so, nothin. Heck I bought the truck in 1989 and it's never worked. But I knew the pump was operable years ago, after I cleaned her out and tore this thing down. So I thought, what happens if I prime the system by blowing into washer bottle's hose with my lungs. Wholly cow, hit the pump and struck water. Another dozen pumps later and hallelujah. I also finished the assembly guide I've worked on for this entire ride. Really happy about that. I spent more time on that than actually building the truck.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-05-2023, 03:39 AM | #3627 |
68 C10 Longbed
Added a reverse light switch from Hurst to my Muncie M22. Now I can see when I back up at night
03-05-2023, 04:43 PM | #3628 | |
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-06-2023 at 12:16 AM. |
03-05-2023, 07:15 PM | #3629 | |
03-05-2023, 08:13 PM | #3630 |
3900. Top end shop, great reputation = not cheap.
Trio 1971 C20 350/700R4 |
03-09-2023, 08:17 PM | #3631 |
03-30-2023, 10:19 PM | #3632 |
Rec’d these caps today. Props to CHEVMN for restoring them. His father is a board member.
I need to choose tires yet, leaning to 235-75-15, not sure about 235-70-15. I like the look of the current prifile, but oh snap, those are 255-70 on 6” wheels for temporary, YIKES! Using this as a gauge, strikes me 235-75 and 255-70 have similar profiles. 4/2.5 drop suspension. Picture is of existing 255-70, input appreciated. https://www.tacomaworld.com/tirecalc...0r15-235-75r15 Oh, boy, my truck is finally running today too. Someone else dialed in the carb, same guy who rebuilt it. That was a long haul. The hick-ups were the transmission was rebuilt twice, and lesson learned for radiator. I also dog-proofed my truck space today, built that friggin wall. He’s a rambunctious German Shepard, stuff gets knocked around sometimes, plus it's just a good idea due storage considerations. The extra lumber was I started too close to the door, so some 2x3. Now the door just opens all the way, I took every pinch of space I could. Think I’ll throw some foam on the "center" post, but there is 8-9” play. I just made a post of my work tableit's a heavy unit. Bummer I can't rightly pop the hood without moving it, but on the bright side all three of my vehicles have a garage space again, and the truck is secluded.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-30-2023 at 10:27 PM. |
03-30-2023, 10:42 PM | #3633 | |
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
03-31-2023, 01:07 AM | #3634 |
Removed the pan off my T400 transmission since its hanging off the engine lift right now.
Changed the filter, and getting ready to install the new crossmember I bought a couple weeks ago from Overkill Customs, out of Red Deer. (Running exhaust up in the frame) New B&M 3200 stall, and switching to Type F fluid. ...not spending a bunch on this transmission, as I doubt it will last very long behind the new engine. (Spent way too much this last winter.) Picking up a lot of stuff tomorrow from the border. (Parts and pieces Ive ordered as far back as December) Super excited!!!
"If it ain't broken, fix it 'till it is!" |
03-31-2023, 03:00 AM | #3635 |
I went over to my buddy, Dennis' place and we had a couple of steaks, canned beans and a baked potato each.
Then, when we came to, we rebuilt my '71 GMC Jimmy's 350's Carter AFB [9635-S]. Since I got YOM Plates, I don't have to tune up [and dial down the carb and timing] for Emissions testing every year. We were always changing out metering rods and jets to pass in June. Right at the peak of the hot dry season. Then there was the long lines at the ADEQ Facility. Went to a 4-core radiator just for that. If your coolant pukes, you flunk for the day. Fix it and come back. Anyway, it had been a while since we rebuilt that 600 CFM carb. I got a fresh EDL1477 re-carb kit on the way out. $54 bucks. Inside the fuel bowl was stained pink. Possibly from rust and the red dye in Sta-Bil, which I use to preserve pump gas. The Accelerator pump gasket had been shot for a long time. Varnish on the flapperators, etc. I treat my AFB [Federal Mogul vintage] like an Edselbrock 1405. We broke it open and cleaned all the little bits with spray carb cleaner. Then we reassembled it with all the little bits and new gaskets back on. After the carb was back together, we re-mounted it on the SBC, and fired it up. We then checked the timing and reset it to 12* advance. It had gone retarded. Dennis dialed in the Performance Series Carter AFB, [Vacuum up to 17'' Hg @ 700 RPM, 180*F H2O = Nominal] and it sure is good to throttle up again. [Usually, we'd do the BBQ after the tune-up, but Dennis was hungry early, I guess. He was the cook.] Sorry no pix.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 03-31-2023 at 03:19 AM. |
03-31-2023, 07:14 AM | #3636 | |
03-31-2023, 07:17 AM | #3637 | |
03-31-2023, 12:30 PM | #3638 |
Giving my truck bed its yearly waxing with micro crystalline wax (suggested by my friend who finished it for me. Using a bit of glass cleaner first to remove any shop dust. It has 14 coats of Epiphanes marine varnish on the wood.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-31-2023, 01:01 PM | #3639 |
beautiful work,looking very nice.
03-31-2023, 01:33 PM | #3640 |
Magazine pretty, nice job.
I could almost see myself with that shine. |
03-31-2023, 03:25 PM | #3641 |
I better get something done, maybe some body work.
03-31-2023, 05:26 PM | #3642 |
If you don't do it ^^^^^^^ no one will
Gerry, North Bay Ontario 1971 Chevy K10 short stepper, 518 med green & white 1972 GMC C1500 long box, dark Brown, owned since 1977 1969 GMC C2500 manual |
03-31-2023, 08:07 PM | #3643 | |
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-31-2023, 09:41 PM | #3644 |
Picked up new Schott wheels, one piece window kit, all the tailgate trim, billet radiator support brackets, complete 3" exhaust pipe kit, 3" v-bands, and fire sleeve
04-01-2023, 12:17 AM | #3645 |
Today, on my '71 Jimmy, I R&R'ed the Fuel Filter and replaced the 3/8'' hose connecting it to the carb. I also reattached the lid on my center Console. All 3 screws had worked loose and the lid was flopping all over the place.
I looked into changing out the gasket on the Fuel Sender in the '68 C/10 Stepside. Since I changed out the float last year, the tank was leaking fumes into the cab. Especially when filled up. I had pulled about 9 gallons from the in-cab tank -- syphoned into jerry cans -- so I could operate, but the Special Tool I bought from LMC to remove the sender, lock ring and gasket was nowhere to be found.
04-05-2023, 03:25 PM | #3646 |
After a month or so of phone calls and e-mails my seat saga has been resolved . I received three yards of the Dark Fawn material today to redo the 68 seat back. Free of charge they also sent me a check for the estimate from my upholsterer to do the repairs . So all in all Im happy with the outcome . Ill post when the seat is fixed most likely a month or so as the shop is extremely busy at this time . Color is dead nuts .
I think they just wanted me to stop calling
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 04-05-2023 at 03:30 PM. |
04-05-2023, 03:36 PM | #3647 |
Right on Mark, glad to see it
04-05-2023, 03:45 PM | #3648 |
I've been spending time in the garage waiting for the weather to get better, and polishing the stainless bed bolts and reinstalling. Might even do all of the strip bolts as well.
04-05-2023, 06:07 PM | #3649 |
70+ ( Old Skool Club )
I had my original AM Radio redone so is now AM/FM and has Blue Tooth with a built in microphone so can talk hands free. It was recommended by the builder that I use a fixed mast antenna for better reception on the AM so today ordered a complete new fixed mast antenna kit. My truck has the original telescoping antenna now.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
04-05-2023, 06:35 PM | #3650 |
BlahBlahBlah
I looked up the company on the sticker of your radio and they say they are only Mopar and AMC. How did you get them to do your radio?
