![]() Join Date: Nov 2015
WiW 72 4 speed with related components
I see that most times a sm465 transmission is listed between $75-$200.
Would it be worth more to list items separately or is that more headache than it’s really worth. I have the z bar & linkage, spring & frame bracket. Bell housing with mounts,is usable, but a portion by the starter is damaged. Flywheel with clutch disk & pressure plate that have approximately 4500 miles on them. Shifter boot. 2 piece drive shaft for LWB. Are these items worth much separately?
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
Re: WiW 72 4 speed with related components
I thought I would give a partial update of sorts on value.
I sold the transmission, throw out bearing, clutch fork, pressure plate and clutch disk, locally for $300 cash. I still have the remaining related parts,and after searching I found some values on parts, but most were many years old, so I am unsure if completely accurate, but maybe close. Z bar $20 Spring $10 Adjuster rod $10 Shifter $40 Clutch fork $20 Transmission crossmember to bell housing bolts $ 10 Speedo gear $10 Flywheel ? LWB driveshaft? Bell housing? Shifter boot? Shifter knob?
Another update on part values, maybe not what they are worth, but what items actually sold for. Heavy or large items sold locally as one would expect. But even though there was a lot of interest locally, bad weather, or longer distances for travel to pick up parts, caused some to pass on parts. Offering to ship smaller parts helped
Shifter boot sold for $20 Flywheel sold for $45 Driveshaft sold for $100 Z bar with upper and lower push rods, push rod nut, frame bracket, engine side z bar bracket with ball stud, fork pull back spring, z bar stud, lock, and nut, frame side ball stud. Heavy duty clutch assist spring with pin that bolts to clutch pedal. Sold for $100 Perhaps these values will help others price their items.
![]() Join Date: Jan 2007
Good info
I live in California, but identify as a Texan ![]() "If a job's worth doing, it's worth doing well" Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Thanks a lot for your updates with prices. This forum is to help get a value and give values. You came to get, ended up giving
Too bad everybody can't do this every time they sell something where we could find sale prices listed by part.
![]() Join Date: Nov 2022
I vote for that good idea Special K
#8 | |
I will try to add info on the WIW forum, as well as the 1967- 1972 Chevrolet & GMC Pickups parts board, if and when a item sells. Hopefully updated info helps others. Or is there another option?
