The Niner
![]() Join Date: Nov 2010
Flood Penetrol as a clear coat
Thursday night's project with the Bomber was putting some kind of clear coat over the tired old paint.
Super impressed with how Penetrol works. Makes the paint really pop and works well on the black trim too.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
![]() Join Date: Jun 2005
Re: Flood Penetrol as a clear coat
Which pics are before and which are after?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
The Niner
Here's a before.
Wood Paint?
I would expect checking and crowsfeet within weeks. Maybe longer out of the sun.
'67 GMC 2500, 292, 4spd, AC |
#5 | |
“Penetrol is a product of linseed oil mixed with a few other ingredients. Penetrol is essentially a product of linseed oil, long oil alkyd resin, and Stoddard solvent” BLO has been used forever to protect outdoor tools
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
![]() Join Date: Jan 2001
It looks nice.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
At the body shop.
Every 6 months ish.
" That didnt make it any newer " " Dont antique the equipment " |
Does it feel like there is oil on the paint after it’s applied or is it more like wax?
The Niner
It's definitely oily, you hafta let it cure for 12-24 hours.
I painted houses for the last 40 years. I add this to all my oil base paints to slow down drying time and it helps to flow the paint out. I use it on interior trim and you sware I sprayed it on where I use a quality oil brush. Latex paint you would use Floetrol.
#11 | |
![]() Join Date: Jun 2022
Would you use Japan dryer to force a complete cure of oils/varnishes, or does that defeat your drying time+flow? I only know of it from woodworking, and maybe it's an antiquated concept
1970 C10 Custom longbed 350/350 |
The big problem with using Penetrol right out of the can is it does NOT have uv protection or salt protection. It's not a sealer. It's a paint conditioner. Works great for wood primers as it slows down drying time to allow the primer to penetrate deeper. Works great with oil base paints to allow it to flow out smooth. I used it for years. Still do. Same with Floetrol for water base paint. I have to wonder what the truck will look like in the spring. When the time comes to get a real paint job, will the Penetrol be an extra paint prep step to remove?
#13 | |
At the body shop.
I just washed it, when it's dry I will get a flake pic
#14 | |
The Niner
#15 |
At the body shop.
Flaking.
3/4 months in the weather.
#16 |
The Niner
Rolled her outside today, pretty happy with the way it turned out.
#17 |
You can also use Thompson Water Seal.
71 C-20 07 Magnum RT AWD |
