#1 | |
Cruzin
Re: Post Your Straight Six Pics!
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
![]() Join Date: Feb 2002
I didn't want to say it, but it looks like somebody used that 215 for a boat anchor already.
Was there ever a 2v Rochester carb and GM intake for that specific motor and was it compatible with 250s and 292s? '72 SMOKER: That's no ordinary 292, is it?
Six in a row makes it go...
![]() Join Date: Mar 2009
I had a 215 in a '65 LeMans. It had the same 1-barrel as the others. I think I still have the manifold in the barn.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
No it's not, the truck did have a 292 in it before though. It's a 1991 5.9 cummins and still a strait 6.
#6 | |
Is that a turbo on that Cummins? And can you go BioDiesel? I think the only way to beat the high cost of fuel these days would be to go BioDiesel, manage a McDonalds, and then steal the grease.
That gets my vote as the cruddiest engine/trans I've ever seen...
Believe or not there was no rust under mud. Pic of a trunk filled with mud and after car wash. It was sitting in the desert since '78.
Some good lookin' engines here, but haven't seen any with a/c. Still waitin' on Pritch's engines to return (maybe he will do a progress with pics?). Maybe get an autograph (sign the engine?) since the builder is a Salt Flats Legend! Lets see some more pics, it will keep me motivated!
No bling or paint, but there is plenty of cold AC.
'67 GMC 2500, 292, 4spd, AC |
![]() Join Date: Oct 2009
I have a couple of questions regarding your A/C set-up. Did you have to modify the air cleaner support to accomodate the the a/c brackets? It doesn't look like you added a different shroud when you put a/c on, am I missing something? Finally, what aftermarket a/c set-up did you go with?
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
#13 |
![]() Join Date: Jun 2005
What kind of carb is that?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#14 |
Carter AVS from '70 Mopar
#15 |
Hey, I got one of those! It was prop in a kevin costner movie that no one saw. I 'swagged' it when the pic was over and they were throwing stuff out. I bought a bunch of rods and jets from the Edelbrock Thunderor 1825 for a rebuild. The accelerator pump had a purple leather cup. I couldn't find the 3-stage metering rods, anymore. I have one pair of deep-dish primary jets, that some P.O. had switched to the back, secondary jet position. [.100. I think]
Somebody looked it up on line and said it was out of an early '70s 440 Mopar. I've back burner-ed the project for now but I'd like to know more about your carb for future reference. I never thought about using it on an L6 though. I think 500 CFM for a 296CuIn build: [292 @ .030- over = 296] is already too fat, but , heck, I got tired of always adjusting my Holley 390. After a 25 year run, it was shot...
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 09-01-2011 at 05:54 AM. |
#16 |
If I understand your question, the answer is no. It is just spaced out from the head a little. The bracket uses the two bolt holes near the front of the head and the bottom of the two holes behind the #2 plug. One piece of steel stock goes from the front straight back to that bolt. A second piece from the top of the bracket goes down at an angle and is welded to the lower piece, just below plug #2.
No shroud. The '94 Cad DeVille pusher fan runs all the time the AC is on, which is all the time because it is an Electronic Climate Control from a '87 Lincoln Mark VII. You just set the temp degrees and leave it alone year round. The other fan is a '89 DeVille fan. It is on a 208 deg temp switch mounted on top of the thermistat housing and to my knowledge has never turned on. The factory temp gauge has just the "L" and "H". In this heat, it goes all the way up just over the "L". ![]() ![]() I love the unit, but it was far too much work to sqeeze it in there. Had I known, I would have used an aftermarket.
#17 |
To keep this Chevy related, the spec sheet with the rebuild kit for this carb shows that it was used on 1966 Chevrolet 327's. It was also used on 307, 327 and 350 Chevy Marine engines.
The Mopar 440 AVS had 1 11/16" primary and secondary bores. The 383, 340 carbs had smaller 1 7/16" primary bores. Depends on who you believe, but many list them as 625 and 750 cfm carbs. Edelbrock's cheap copies are listed as 500, 650 and 800. They don't list the bore or venturi sizes so I don't know how they compare. The one with the smaller primary and the flow regulated secondary does not have a problem with a 300 cu in engine from what I've seen. The secondary only flows as much air as the engine can handle.
#18 |
subscribed
#19 |
Redneck Hillbilly
subscribed. Cool stuff!
#20 |
Redneck Hillbilly
Too late to add pics to my previous post I guess.....here's a shot of the 230 in my '65 C10. She's backed by the SM420 "granny" 4 speed, and I assume 4.11 or higher gears. This was taken a week or so after I got the truck at the beginning of the year. Not much has changed; I cleaned up the battery, and a lot of the dust is gone from tuning and driving her. Other than that, this is how she sits today.
#21 |
![]() Join Date: Apr 2001
I have good news for you.. that is not a 230 pictured, you have a 292!!!!! Your side covers are the 6" tall versions, and your fuel pump is located behind the motor mount on the pass side....
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
#22 | |
![]() Join Date: Aug 2010
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#23 | |
Redneck Hillbilly
#24 | |
#25 |
hello I6 guys. im new and ignorant to em but very interested in swapping my 350 for a I6 in my 70 c20 in the future. just want to lean what i can about them. which one is the most popular and why? not interested in power really, just a dependable motor. does one motor have cheaper replacement parts over others? are the I6's taller then a sbc?
My Build Thread. 70 C-20, SFBD, angled Z, 3 linked. impressive for a noob? http://67-72chevytrucks.com/vboard/s...d.php?t=438132 |
