Old 09-11-2009, 12:59 PM   #226
71'tahoe
71'tahoe's Avatar
Re: Project '86
Callme slow..but I looked on SD's website and cant find just the upper control arm mounts..Did you call in and order them special?
71'tahoe is offline   Reply With Quote
Old 09-11-2009, 01:48 PM   #227
dv8customs
dv8customs's Avatar
Re: Project '86
They aren't on the site seperate, give them a call and you can get them.
dv8customs is offline   Reply With Quote
Old 09-11-2009, 06:45 PM   #228
SBTork
Garage wrench
SBTork's Avatar
Re: Project '86
very nice work, way to fab
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 09-11-2009, 08:44 PM   #229
Tagg33
Tagg33's Avatar
Re: Project '86
Originally Posted by dv8customs View Post
Any of you guys seen my pinch weld? I could have sworn it was here yesterday
Do you have any pics of the pinch weld removal process? I'm interested in maybe doing this but I haven't seen anyone else's pics or explanation. Was it difficult? I know removing the pinch weld was the most difficult area of the firewall for me.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 09-12-2009, 01:22 AM   #230
texastruckjunky
texastruckjunky's Avatar
Re: Project '86
Your truck is coming out AAAAAAWWSOME. You are a man of many Talants.
texastruckjunky is offline   Reply With Quote
Old 09-12-2009, 12:12 PM   #231
dv8customs
dv8customs's Avatar
Re: Project '86
I actually just rolled it under. Next time I have the cab off I need to do some clean up on it because it wasn't that easy to do on the ground and it could use a bit more straightening in some areas. Some parts of it were pretty stiff so I cut a few vertical slots so I was bending smaller pieces in those areas. If you do decide to actually cut it off then just cut a small amount at a time and tack it together. If you cut the whole thing off at once you will have a mess.
Old 09-13-2009, 05:54 PM   #232
dv8customs
dv8customs's Avatar
Re: Project '86
Trimmed the bottom off the driver side fender and started working on the fender lip. Finally had to give my buddy's wheels back so I am back on the 15's.
Old 09-13-2009, 06:14 PM   #233
ratty 46
Re: Project '86
Now that my friend is on the ground. Nice job.
Ratty 46
ratty 46 is offline   Reply With Quote
Old 09-13-2009, 08:31 PM   #234
mrenj23
mrenj23's Avatar
Re: Project '86
so did you only go suicide on the pass. side
mrenj23 is offline   Reply With Quote
Old 09-13-2009, 08:49 PM   #235
3r!c84
Badass
3r!c84's Avatar
Re: Project '86
ohh yea i just seen that ..whats up with that?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-13-2009, 10:53 PM   #236
dv8customs
dv8customs's Avatar
Re: Project '86
I am going to suicide the drivers side as well. Just haven't gotten to it yet.
Old 09-15-2009, 12:31 AM   #237
lowhoe
Re: Project '86
i see you said you welded the cab mounts back on. Why were they removed in the first place? Was it to move them lower?
lowhoe is offline   Reply With Quote
Old 09-15-2009, 07:56 AM   #238
dv8customs
dv8customs's Avatar
Re: Project '86
They are riveted on from the factory. In order to get the 2x4 tubing to lay flat in the frame I had to remove all the rivets. I could have drilled holes and bolted them back on but welding is easier. They were put back in the stock locations.
Old 09-15-2009, 04:27 PM   #239
lowhoe
Re: Project '86
ahh thats what i thought. I didnt think they had to be moved to lay the rocker. Lookin clean bro. Cant wait to start on mine. Keep it up
Old 09-18-2009, 10:59 AM   #240
Str8Ugly
Re: Project '86
Looks damn nice dude I wanna come over and check it out one day... I hope to get off somewhat early to go get mine on concrete under the carport today
Str8Ugly is offline   Reply With Quote
Old 09-23-2009, 11:06 AM   #241
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Project '86
Wow subscribed.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-23-2009, 12:04 PM   #242
Str8Ugly
Re: Project '86
U live like right by the 4 way by poppys don't u? I alwas saw nice rides over there
Old 09-23-2009, 01:51 PM   #243
dv8customs
dv8customs's Avatar
Re: Project '86
Yea, I would park stuff out front when trying to sell it. You probably saw my '74 Nova, my bagged extended cab, or the 2 door tahoe.
Going to mount the air tanks and start plumbing today if the rain holds off so hopefully I will have updates by the weekend.
Old 09-23-2009, 01:54 PM   #244
menace121978
menace121978's Avatar
Re: Project '86
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 09-29-2009, 11:34 PM   #245
dv8customs
dv8customs's Avatar
Re: Project '86
Check it out, my truck is on a shirt! My buddy used a pic of my truck for one of his shirt designs. I don't want to break any rules about advertising in the forum so if anyone wants more info just PM me.
Old 09-30-2009, 09:29 AM   #246
FRENCHBLUE72
PROJECT 7DEUCE
Re: Project '86
Sweet shirt..
MEMBER #6377
Project "7DEUCE"
Old 09-30-2009, 11:09 PM   #247
dv8customs
dv8customs's Avatar
Re: Project '86
Kicked around a lot of ideas as to where to mount my tanks and finally decided the only place they would really fit is behind the rear wheels. Might need to make some shields to block anything coming off the rear wheels but that won't be hard.
Old 10-01-2009, 02:12 PM   #248
begining87
begining87's Avatar
Re: Project '86
Dont stop the sickness. Need to hook up so I can get my ft fenders too you. You need to mass produce that bro nice work.. Subscribed.
begining87 is offline   Reply With Quote
Old 10-14-2009, 11:07 PM   #249
dv8customs
dv8customs's Avatar
Re: Project '86
Got all the stainless air line plumbed today and it seems to hold air pretty good. Ran out of daylight so tomorrow I plan to chase down any leaks.
Old 10-17-2009, 05:48 PM   #250
dv8customs
dv8customs's Avatar
Re: Project '86
Fabbed up a new crossmember for my upper 4 link bars.
