Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-27-2016, 10:02 PM   #226
Wilson!
Originally Posted by thompson1122 View Post
Attachment 1594481
Attachment 1594482
Attachment 1594483
So all I would need to buy is the Impala SS hard lines and the soft lines that connects to the caliper??
if I remember correctly, the line that comes from the hard line on the truck is Impala as well.
Wilson! is offline   Reply With Quote
Old 11-27-2016, 10:05 PM   #227
thompson1122
Re: Impala SS Rear Disc Brake Brackets
Originally Posted by Wilson! View Post
Imthe phone the pics was on was damaged and I couldn't get any pics off of it. All three soft lines and the two hard lines are from the impala
The pics are of my truck rear now. So I remove my hard lines and replace with the Impala SS hard lines where they meet in the center above the housing? Then connect the hard lines to my flex hoses connected to my calipers, correct? Without using any adapters
thompson1122 is offline   Reply With Quote
Old 11-27-2016, 10:08 PM   #228
thompson1122
Just want to make sure, are you saying my truck hard lines are the same as the Impala SS hard lines? Or do I get the Impala SS hard lines?
Old 11-27-2016, 11:18 PM   #229
Wilson!
Everything on the rearend is Impala. Both hard lines and all three soft lines.
Old 11-28-2016, 12:07 AM   #230
thompson1122
So I do need to get the Impala SS hard lines right?
Old 11-28-2016, 12:10 AM   #231
thompson1122
Sorry to be so nerve racking...So I do need to get the Impala SS hard lines right? Just tell me what all I need to get to do as you did without using the adapters.
Old 11-28-2016, 12:28 AM   #232
Wilson!
yes the hard lines and hoses are from the impala.
Old 11-28-2016, 09:36 AM   #233
urmyboyblue
I didn't read this entire thread, but I have a question- do these fit a "big" 12 bolt brake pattern- like used on Impala's? I don't remember if the big pattern is on both trucks and Impalas or if they are different.
urmyboyblue is offline   Reply With Quote
Old 11-28-2016, 10:03 AM   #234
Wilson!
yes, the Impala SS uses the same 5x5 pattern as the truck. The only part that needs modification is the center hole on the rotors is slightly too small and needs opened up
Old 11-29-2016, 01:39 AM   #235
Captainfab
60-66 Nut
The truck 12 bolt and the Impala 12 bolt both have the same backing plate bolt pattern. So these brackets will bolt up to a Impala 12 bolt but depending on the year, the wheel stud pattern will be different.
Old 12-01-2016, 06:14 PM   #236
thompson1122
Mr. Wilson, I meant to ask you where did you get your Impala SS hard lines for the rear?
Old 12-01-2016, 06:21 PM   #237
thompson1122
I saw these on ebay..are these like what you have?
Old 12-14-2016, 01:28 AM   #238
thompson1122
Finally changed out the rear..ditched the drums and installed the rear disc conversion using Impala SS slotted and drilled rotors, calipers. and the brackets made by captainfab! They fitted perfect!!Name:  SAM_1207.jpg
Old 01-17-2017, 03:08 PM   #239
NoNeck
NoNeck's Avatar
Hey Captain,
I need a set of your brackets shipped to ZIP 37343 (Tennessee). I need a total.
The way I understand it, I can use '94-'96 Impala SS Calipers, Rotors and Brake Lines for the installation. Correct?
Thanks, POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 01-17-2017, 03:14 PM   #240
thompson1122
Yes you must use the calipers, flex hoses, and hard brake lines. I ordered everything off of eBay. Everything was a direct fit.
Old 01-18-2017, 12:25 AM   #241
Captainfab
60-66 Nut
I replied to your PM's........
Originally Posted by NoNeck View Post
Hey Captain,
Thanks, POP
Old 02-15-2017, 06:50 PM   #242
rubicon03
Wanted to thank capt fab got the impala disk bracket and the power steering both are excellent and was a breeze to install would post a couple pics but for some reason I can't
rubicon03 is offline   Reply With Quote
Old 02-16-2017, 12:21 AM   #243
Captainfab
60-66 Nut
Thanks for the positive feedback....I appreciate the purchase. If you are trying to post pics direct from your computer or phone, I believe you can not do that because you are not a paid member. You would first have to upload them to a photo hosting site such as photobucket and then post them from there.
Old 03-07-2017, 10:34 AM   #244
Daveyc12
Originally Posted by Captainfab View Post
Here is my latest design of the Impala SS rear disc brake brackets. These are laser cut out of 1/4" with 1/4" spacers stitch welded on and then tapped M12 x 1.25 for the caliper cage attachment bolts. The price on these is $75.00 plus a flat rate shipping of $7.15. PayPal is preferred, but I will also accept money orders. The package includes one pair of brackets plus grade 8 fasteners to attach the brackets to the axle tube flange and the metric bolts to attach the caliper cages to the brackets. This setup is for the 5 x 5 bolt pattern.
If you would like a set, post in this thread and either make a PayPal payment to captainfab454@ hotmail dot com, or send me your email and I can send you a PayPal invoice. If you wish to send a MO contact me for a snail mail address.
I would like a pair of these. Could you send me a paypal invoice? Thanks Cantrell_david@sbcglobal.net
Daveyc12 is offline   Reply With Quote
Old 03-08-2017, 01:26 AM   #245
Captainfab
60-66 Nut
PayPal invoice sent and payment received. Thank you for the purchase
Old 03-12-2017, 04:47 PM   #246
rubicon03
Ok so what are you guys using for rims? Having a tough time finding any that will fit this setup
Old 03-12-2017, 11:12 PM   #247
Captainfab
60-66 Nut
What wheels are you trying to fit? As far as I knew any 15" or larger disc brake compatible wheel should work.
Old 03-13-2017, 06:08 AM   #248
rubicon03
Ridler or similar the hub register is to big I guess you have to use a adapter
Old 03-13-2017, 11:17 PM   #249
Captainfab
60-66 Nut
I have heard/read that some of the modern aftermarket wheels have the smaller car sized hub bore. I don't understand why they would offer a wheel with a 5 x 5 pattern and the small hub bore.
Old 08-19-2017, 07:32 AM   #250
BigHuss88
Captain ,
Looking to get a pair if you still make those , thanks
BigHuss88 is offline   Reply With Quote
