#226 |
Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN** The truck Chevrolet should have built.
Grinding all the welds down still. Going back and welding again when I find a hole. First I have been grinding them pretty close with the cut off wheel, then finishing with the flap disk. The whole weld area will end up being lower than the adjacent areas slightly which will make it easy to have a thin layer of filler/ thick primer for blocking out before paint.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#227 |
67cheby
![]() Join Date: Sep 2008
looking great
#228 |
Now we go into uncharted territory.
I really want this truck to be one I WANT to drive, all the time. So I need to make it as functional, smooth, fast, efficient, good driving, and quiet as a new truck. I figured the easiest and best way to go about it was to have as much modern equipment as possible, including the frame and modern suspension geometry. (4 wheel disc with ABS, factory rack & pinion, etc.) So here we are with a 2001 2wd Silverado frame. Problem is, nobody has done any write-ups on something like this. I will be engineering this as I go and could probably use some ideas from you guys here on the forum. Let the comments fly! First thing I see tonight is the carrier bearing mount is way too tall. (The hoop looking thing.) Body mounts on the frame aren't needed because the 72 body mounts line up perfectly with the wider new frame rails. Overall frame length will need to grow by approximately 4 inches. Too much frame kick up in the rear.
#229 |
best of luck frame work is a lways kinda the most important but not really as fun as body work or putting an engine in, good luck
#230 |
I personally like the frame portion. Taking the dirtiest part, and reworking with new clean parts and then there a re the details that not very many people will see.
67- 72 Parts collecter |
#231 |
true classic chev very true
#232 |
VA72C10
![]() Join Date: Mar 2008
cool! Looking forward to this part!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#233 |
6>8 Plugless........
![]() Join Date: Sep 2007
You can more than likely ditch the carrier bearing cross member and relocate it how you want and where you need it once you get the rear axle and power train set in the chassis. As for the frame kick up being too high, you could do some figuring and this might be an idea. Right where it kicks up starting before the last cab mount, and before the spring mount, try to find how much kick up you need. Cut the frame at maybe a 45* cut somewhere in that area. Remove some material needed to get the kick up you desire. Cut the other at 45*, bevel each side, weld up, then plate the inside and either bolt this in or weld it in. Then place your rear axle and figure out where you can add your 4" of frame to achieve your desired wheel base. Good luck with this portion of the project. It is coming along nicely!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 12-11-2010 at 02:40 AM. |
#234 |
GEARHEAD
I wonder if the rear section of the frame from a 2001 suburban or tahoe is the same profile. I have a 2003 yukon denali, but haven't looked underneath it much.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#235 |
67cheby
cant wait to see more of this
#236 | |
#237 |
![]() Join Date: Jul 2007
Good job on it Drew. Wish I lived closer so I could give you a hand.
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#238 | |
On another note, I will be unable to do much until after Christmas.
#239 |
Still plays with trucks
If it is just the location of the kick up being too far forward to work you could section the frame and move the kick up rearward where it will work. Then all you have to do it add some extra material up front to create the wheel base you need.
I did this on my 67 K10 conversion to make a square body chassis fit the body better without need for a body lift.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#240 |
Luv the Crewcabs
Jusr read your entire Build & am Quite impressed by Your Build, Excellent Documentation for all who may wish to copy your Design. Also quite Impressed by the Fact that your Family is Involved.......
I Really enjoy my Current 86 Crew Stepper & One of my long term goals is to Have a 67-68 Style Crew Stepper some day, I have been collecting parts for a couple yrs now & Hope to Start sometime in next yr or so........ Here is a Pic of my 86 Crew Cab & a Photo Shop of what i hope my 67-68 Crew will come out Like...... Thanks & Merry Christmas. Rick
55 Nomad 52 Willys Truck 67 Stepper 67 Fleet 68 Wrecker 68 Suburban 76 Crewcab 79 Gmc Dumptruck 84 Blazer 86 Crewcab Stepside 87 Iroc 89 GMC Plow Truck 91 Camaro Vert 96 Z71 Stepsde |
#241 | |
What I think I know so far: 99-2006 frames have a 9.5 inch rise or kick up for the bed. The bodies on these trucks really hang down over the frame. The new truck frame is 2 inches taller than my old frame, 4 inches wider. 67-72 truck bodies only hang down over the frame about 4.5 inches, so I need to keep the cab as close to the frame as possible to help hide the taller frame. Old truck frames only kick up about 4.5 inches, So I need to come up with 5 inches of bed drop some how. (if I mounted the body and bed how they are now, the bodyline would be off by 5 inches) All of these numbers are preliminary and will probably be adjusted somewhat.
#242 | |
Currently Blazerless
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#243 |
wow that is too long
#244 |
Build looks awesome,keep up the great work. Its getting me motivated.just subscribed.
Jay Barrhead,Alberta,Canada 1967 GMC 400sb Porterbuilt stage 2 front and rear suspension ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=419519 |
#245 |
That always cracks me up!
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
#246 |
#247 |
Very cool!
#248 |
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#249 |
TNT-MOTORSPORTS
Doesnt the red one look like it had a dodge pu grafted on the back of the cab ......?
#250 |
That's just how they look when a surburban is cut down to a crew cab and the high roof is left.
