Old 09-19-2013, 09:41 PM   #226
firedog
firedog's Avatar
Re: Project 67
just a little flash back to where this started, good job sammy you have come a long way
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 09-19-2013, 09:44 PM   #227
firedog
firedog's Avatar
Re: Project 67
of course the page had to flip
here we go to compare
Name:  IMG_0529 (640x480).jpg
Name:  IMG_0530 (640x480).jpg
Name:  IMG_0531 (640x480).jpg
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 09-19-2013, 10:01 PM   #228
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project 67
Lookin good!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 09-20-2013, 10:41 AM   #229
Sammy
Re: Project 67
So far.
69 frame, 67 cab, 71 6' bed, 71 GMC front fenders, 68 hood, 67 core support, ECE drop spindles n disc conversion kit, 71 5 lug rear, ECE trac kit n lowered shocks, new windshield, vent rebuild n weather stripping kits, window regulator, bags/plates n plumbing, C-57 Coy wheels, tires, dash panel, complete rebuild of rear end brakes, brake lines, brake booster n master cyl, gallon n half of primer both etch n 2K, gallon of paint. And the list gets longer. Boyd tank, 93 van marker lights, bed fuel door
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 09-26-2013, 07:38 PM   #230
Sammy
Re: Project 67
Got the cleaner smaller profiled 93 Van marker lights for a different look than stock. Also the fuel access panel arrived. 5 X 8 overall outside measurements. Made of stainless should work fine. May end up replacing the huge lock with a key type when finished.
Old 09-27-2013, 02:48 PM   #231
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: Project 67
Looks like it has come a long way from where you started.
Only hope mine will look half as good as what you have done to yours.
Nice idea on the fuel door in the bed area.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 11-26-2013, 07:28 PM   #232
Sammy
Re: Project 67
My heater in the garage is awaiting a circuit board part and the heater guy. Not good for "Odd Ball".. Next stop working on the air management side of the suspension, parts are in shipment.
Old 12-06-2013, 12:46 PM   #233
Sammy
Re: Project 67
Piece by piece.
Old 12-06-2013, 02:37 PM   #234
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project 67
Accuair?
-Nate
Old 12-06-2013, 07:47 PM   #235
Sammy
Re: Project 67
Yes
Old 12-06-2013, 08:48 PM   #236
HotRod C/10
HotRod C/10's Avatar
Re: Project 67
Originally Posted by Sammy View Post
Got some things done today thanks to FireDog n Pop's help. First reinstalled the cab on the frame, then installed the windshield, and the rear window. Surprising how well installation went with the windows. Maybe 45 min with a 15 m brake n the middle. Also received the new panel for the cluster Pop's done a fine job on that. Also installed the two doors after replacing the window regulator on the driver's side. Wanted to comment on GMC Pauls parts..Dash Panel was super nice no issues with the quality at all. Plus the other items arrived in about 3 working days. Even with the holiday in the middle. Also worked some on the bed as you will see in the pics I will post below. Very happy so far how things are going and starting to see some progress which is a good thing. Starting to look more like a truck again..
What did you use to seal the heater core "doghouse" to the firewall......Lookin Good!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 12-07-2013, 10:41 AM   #237
Sammy
Re: Project 67
Thanks...small amount of Black Gasket type RTV in a tube
Old 12-07-2013, 11:15 AM   #238
Sammy
Re: Project 67
Recently talked with the shop that done my bench seat and other interior work for me. Reference to seat belt webbing. Black webbing material if it is the correct width he didn't know for sure but suspected it was. He had re-webbed his Cuda belts. Claims he uses the correct thread for them to be safe. Early spring thaw, I will let them re-web a set of 67 belts.
Old 01-12-2014, 03:15 AM   #239
sstaten69
sstaten69's Avatar
Re: Project 67
looks nice, great progress. looks like we are not that far from you.
sstaten69 is offline   Reply With Quote
Old 01-12-2014, 10:26 AM   #240
Sammy
Re: Project 67
Yes, almost next door. With the cold pretty much a lull on the project. Spring is around the corner though. I am the VP for the Leadbelt Cruisers in Bonne Terre. Not a big car club that meets in the summer at Dairy Queen. As time draws near you should attend and meet some of the family's. Some don't even have a vehicle but just go to jaw jack and comment on cars, trucks, n politics. Typical small country town gossip.
Old 03-09-2014, 01:16 PM   #241
sanford&daughter
sanford&daughter's Avatar
Re: Project 67
Wow it looks like you have been busy and made a lot of progress since I've checked in last keep up the good work
sanford&daughter is offline   Reply With Quote
Old 03-10-2014, 05:54 AM   #242
Sammy
Re: Project 67
No doubt spring weather will allow a new interest in the project. So still so much to do. I have the steering coupler may first reinstall the steering column.
Old 03-11-2014, 06:58 PM   #243
C20-67_N_MO
Re: Project 67
Dang Sammy, you should have that nice truck almost together by now.
Old 03-12-2014, 07:49 AM   #244
Sammy
Re: Project 67
Still need some critical stuff. Tranny, shaft, radiator n some other odds n ends.
Old 12-07-2014, 10:50 AM   #245
Possmguts
Possmguts's Avatar
Re: Project 67
Nice job Sammy... Ill be watching the progress now :like:
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline   Reply With Quote
Old 12-08-2014, 10:23 AM   #246
Sammy
Re: Project 67
If weather is kind I may get more done. I now have everything for the AccuAir System I need. Using the SwitchSpeed controller. Once placed determine what clamps/protective covering I will use to secure it all. Since not enough room behind the bench seat most likely end up next to the head board in the bed. Then likely a covered bed to keep sticky hands away.
Old 12-08-2014, 03:53 PM   #247
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Project 67
Nice system you've gathered up Sammy!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-09-2014, 11:39 AM   #248
Sammy
Re: Project 67
This system should work great for my needs. One thing I have noticed is there is no pressure gauge for anything. I am thinking of adding a single gauge for tank pressure for assurance of peace of mind. Just unsure yet where I put it. On the tank itself or remote it elsewhere. I have a Viair 0-220 PSI gauge and will likely use that.
Been a slow process but I have more time than funds ha ha.
Old 08-05-2017, 05:21 PM   #249
firedog
firedog's Avatar
Re: Project 67
Little update, the truck is still parked in the garage at Sammy's, other than collecting dust since the last post it hasn't changed much. There is a set of tan hounds tooth covered buddy buckets for it now. But Sammy experienced a disabling stroke a couple of years ago and has been battling since. He was in and out of hospitals for a year, he was able to return home only to experience a bad infection and bouncing from hospital to hospital. He is currently in a VA care center and expecting to be discharged soon. The bad news is he will not be returning home. I have all intentions to take the project over from him and get it on the road but that will take some time. So keep him in mind.
*SOLD*
350/350 combo
Bagged/18" Wheels
Black on Black
'30 Model A Frame
Dual Carb 5.3 LS
2007 GMC 4 DOOR 2WD
2023 Jeep RENEGADE
Wifes ride
Old 08-07-2017, 09:02 PM   #250
Dieselwrencher
Re: Project 67
I'm so sorry to hear that about your father and I wish him all the best. My prayers go to him, you and your family during this time.
Ryan
