Old 12-29-2015, 12:01 PM   #226
cooperhw
cooperhw's Avatar
Re: Roushinator's 72 C10 Stepside Restore/Build
Originally Posted by swamp rat View Post
Personally i think this thread deserves an ongoing and updated parts list so rookies like me can put 2 and 2 together and figure out how to build one of these things! LOL!
Lets just say this would be a go to thread for tho's of us that need more than pictures.
Awesome work!
Ongoing and parts list;'
Time, time, money, money, money, time, money, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,< = more time and money.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 12-30-2015, 11:15 PM   #227
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Nice work.... and parts too! I'm particularly fond of the No Limit R&P upgrade...something I'm looking at myself.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-17-2016, 10:45 AM   #228
roushinator
roushinator's Avatar
Nothing real exciting.... But i ordered all my fuel line and fittings. Black nylon braided hose with Black AN fittings. I still have to order a few more pieces. Also i made my top radiator hose and bottom. Not real happy with the bottom so i might redo it.
Bottom..
Top...
Ryan...
1972 C10 Stepside With 2014 Camaro 6.2L/6l80e drivetrain
http://67-72chevytrucks.com/vboard/s...11#post5532411
roushinator is offline   Reply With Quote
Old 03-20-2016, 04:27 PM   #229
roushinator
A lot of learning has been going on but not a whole lot of progress... Where do i begin.
I am still working on exhaust. I think i figured out how to support it while i fabricate it. Will show that later. Still need to run Fuel lines. Learned how to make the AN fittings to the hoses. Now to the fun stuff..
I found the correct adapter plate and installed my TB and fuel line between the fuel rails. I used that to learn how to make the AN fitting connections. Oh and after much trial and error i found the correct length belt.
Well i did not realize that the injectors from the Camaro are compact versions and would not fit in my intake. They are the EV14 compact but i need the LS1 size injectors.
So i started looking for adapters. I found these and bought them.
But they were still a little too short and i was worried about leakage from the way it was designed. So i called the guy at Fuel Injection Connection and he told me to buy his adapters and the ones i had were crap. LOL So i did. Their adapters are WAY better and are the correct length. And as you can see these have a lock to keep them in place.
So i still have to install them but decided to wait until i got the intake bolted down. Ii had to measure to find the correct ARP bolts and had to get some Felpro gaskets since the stock intake came with individual oring gaskets. So i when i bolted it down i noticed that it was hitting on someting and would not bolt down all the way. Below is each side of the intake.
Upon further investigation the intake cross supports were hitting on the edges of the valley cover plate. So i started looking into options... I think i found a solution. I found that the LSA supercharged engines use a metal/oring gasket that is thicker.
I ordered a set and they line up and everything appears to work good. Everything lines up.
Ran out of time to finish bolting it up but will do that this week.
I did install some locking header bolts and got one of the PS hoses made.
Ryan...
Old 03-20-2016, 04:28 PM   #230
roushinator
So here is how i made sure the gaskets stayed in place for the install...
All bolted down. The gaskets worked perfect!
Injectors, Fuel Rails and TB Installed!
All i need to do now is.... Two PS lines, Transmission lines, Fuel Lines and get y new wiring harness and this can be started!
Ryan...
Old 03-20-2016, 05:07 PM   #231
69short
69short's Avatar
Great work. It's looking good. Clean build
69short is offline   Reply With Quote
Old 03-21-2016, 08:57 AM   #232
sperger72
Ryan looks awesome. You could come help with my c10.
Zach
sperger72 is offline   Reply With Quote
Old 03-21-2016, 09:47 AM   #233
sperger72
Zach
Old 03-21-2016, 11:26 AM   #234
knomadd
knomadd's Avatar
Looking good!
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-21-2016, 12:55 PM   #235
roushinator
Zach
I would love to. You probably would teach me a thing or two..
Originally Posted by knomadd View Post
Looking good!
Thanks!
Ryan...
Old 03-29-2016, 02:10 PM   #236
roushinator
Changed up the fuel line up front. Went under instead of over. I think it looks better...
Started running the fuel lines. This may change a little.
More work this week....
Ryan...
Old 03-29-2016, 11:45 PM   #237
trkfrk
trkfrk's Avatar
I can't believe I haven't come across your build before now! Wow!!
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 03-30-2016, 02:20 PM   #238
knomadd
knomadd's Avatar
The front fuel line does look better routed under the throttlebody. Nice work!
-Duane
Old 03-31-2016, 01:52 AM   #239
swamp rat
swamp rat's Avatar
Nice work!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 04-10-2016, 04:52 PM   #240
roushinator
So here is where i am going to mount my coil packs...
Also i was not sure what this was at first but found it it is a steam port. Well it was on the wrong side for my new radiator so i relocated it...
Ryan...
Old 04-11-2016, 05:14 PM   #241
knomadd
knomadd's Avatar
Nice! How are you running the plug wires, above or below the headers? Those steam port pieces look nice too!
-Duane
Old 04-12-2016, 04:07 PM   #242
sperger72
Ryan,
The Mac's engine left is the way to go. Just used it to install my sons LS in his 49. Awesome product. I am ready to see both of our trucks done. We both have a ways to go. I definitely do.
Old 04-13-2016, 03:41 PM   #243
SMKN TA 95
What did you end up using for a Power Steering reservoir?
-1998 Formula WS6 1LE- LSX 427
4.58 @ 162 mph, 1.12 60'
2017 Silverado 3500 High Country DRW DMAX, 20" Fuel Wheels
1972 Chevrolet C10 Cheyenne - SOLD
RaceWire Solutions
SMKN TA 95 is offline   Reply With Quote
Old 04-13-2016, 04:10 PM   #244
RRR18
RRR18's Avatar
Damn
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 05-17-2016, 09:30 AM   #245
roushinator
Not much going on lately but things will be moving fast here soon. But in the meantime i picked up some new items...
New Custom Fender badges..
And Custom Valve Cover Insert...
Ryan...
Old 05-17-2016, 10:03 AM   #246
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Awesome!!!
Zoomin is offline   Reply With Quote
Old 05-17-2016, 01:06 PM   #247
jwilb88
jwilb88's Avatar
This thread is responsible for me ordering a complete set of mounts and cross members from PB fab today... Those mounts are sweet!
jwilb88 is offline   Reply With Quote
Old 05-17-2016, 01:28 PM   #248
roushinator
I am glad to be of help. LOL
Ryan...
Old 05-24-2016, 09:33 PM   #249
FullThrottle
Such a sweet restomod! I'm hoping to start on my '84 soon.
FullThrottle is offline   Reply With Quote
Old 05-25-2016, 10:19 AM   #250
sperger72
Ryan,
Engine is looking great. What coil pack mounts are you using? We could use this idea on the 49 5 window truck. you can PM me if you would rather
I have not had a lot of time to work on my 67, with oldest son's 49 and my wife's firebird starting. I do have my truck in the body shop getting slicked off and ready for paint.
