View Poll Results: what light setup looks the best?
#1 current LED setup, Hella Rallye 4000 Compact Xenon pencil 8 29.63%
#2 current LED setup, Hella Rallye 4000 Xenon Euro Beam 1 3.70%
#3 BD Squadron wide cornering, Hella Rallye 4000 Xenon Euro 1 3.70%
#4 BD Squadron w.-crn., Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#5 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 2 7.41%
#6 BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 0 0%
#7 HIDDEN BD Squadron wide crn, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Comp. Xenon pencil 1 3.70%
#8 HIDDEN BD Squadron wide cornering, Hella Rallye 4000 Xenon euro, Hella Rallye 4000 Xenon pencil 2 7.41%
#9 BD Squadron wide crn, Hella Rallye 4000 Comp. Xenon driving, Hella Rallye 4000 Comp. Xenon pencil 9 33.33%
current LED setup 2 7.41%
Multiple Choice Poll. Voters: 27. You may not vote on this poll
Old 03-16-2017, 11:59 PM   #226
El Dorado Jim
Re: 78 K20 custom delux "modern meets vintage" build thread
nice truck!!!
El Dorado Jim is offline   Reply With Quote
Old 03-17-2017, 05:56 AM   #227
K20chevy
K20chevy's Avatar
Originally Posted by quadzero View Post
Wow, those gauges look good. The whole cluster is top notch.
Thank you!
Originally Posted by MTCK View Post
Diff locks?
It has those, yes, along with the compressor and the 4x4 light. The hint is the one all the way to the left...
Originally Posted by El Dorado Jim View Post
nice truck!!!
Thank you!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104
68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441
K20chevy is offline   Reply With Quote
Old 03-17-2017, 02:27 PM   #228
MTCK
MTCK's Avatar
Front sway bar disconnect? I'm grasping at straws now...
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 03-18-2017, 08:48 AM   #229
K20chevy
K20chevy's Avatar
well done, exactly! I donīt think anybody has done that to a square yet! pneumatic disconnect that is!
Old 04-02-2017, 04:31 PM   #230
84lngbed
Have you installed the nvu gauges yet? I'm getting around to finally putting my set in. Just having trouble how they bolt to the bezel.
84lngbed is offline   Reply With Quote
Old 04-03-2017, 02:27 AM   #231
K20chevy
K20chevy's Avatar
Hi, no I have not. I actually havenīt touched the truck since last year. Just havenīt had any time to work on it.
With so many other things going on, not sure when or if I get to it this year.
What exactly do you mean by bolting to the bezel? You have the frame with the gauges and that mounts instead of the white plastic part that the OEM installed. Then your dash bezel just bolts in the original sport like it did with the OEM gauges.
Or do you mean how the physical gauges bolt up to the mounting frame?
Old 11-27-2017, 02:58 AM   #232
K20chevy
K20chevy's Avatar
Sorry for the long pause, Have not had much time to work on it. I started the front 4-link on a spare frame. Will post pictures soon!
Old 10-20-2020, 04:26 AM   #233
K20chevy
K20chevy's Avatar
update after a long pause. ...
4-link is mocked up and 80% ready to go on the truck. I need to find the time to weld everything onto the frame and axles. The rear Deaver springs also fit, just need to cycle the rear to see where I have to mount the hydraulic bump stops.
The lower link mounts in the front need to have a new transmission cross member. I have to build this as I go.
Stay tuned... more pictures to come
Old 10-20-2020, 04:28 AM   #234
K20chevy
K20chevy's Avatar
Still not gotten around to do that. But it will go to the new cab, not on the current cab. Will have to check if they fit with the roll cage.
As soon as I can get back to the US (we canīt come to the states at the moment) then I will start with the new cab/cage and install the gauges.
