Old 01-08-2016, 01:41 PM   #2551
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
Originally Posted by franken View Post
None of my business, but I wouldn't do it that way. We/I try not to buy from LMC but that's another story.
The longer bolts in my small mind add leverage at the pivot point, which increases the likelihood the bolt will break in a wreck.
More clever people will chime in, but I'd get SAE washers from napa in the meantime.
The bolt in the pic looks like a floor bolt. Not sure ir they're the same.
Are you referring to the bolt on the B pillar? Is it longer to accommodate trim? I know the ones on my Jeep are long like that so they extend through the roll bar padding.
daddyjeep is offline   Reply With Quote
Old 01-08-2016, 08:00 PM   #2552
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - a GM Haiku
another day
another part
some say it's junk
I say it's art
Gregski is offline   Reply With Quote
Old 01-08-2016, 08:11 PM   #2553
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
Good to see they got some in stock.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-09-2016, 12:19 AM   #2554
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Actually John they only had the passenger side in stock, they were out of the driver side. I wanted to get both. Summit has both sides but they are $10 bucks more each.
Old 01-09-2016, 06:15 PM   #2555
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Wow installing the new replacement window regulator is a bear! Which roller wheels of the three do you put in first? Any tips / advice greatly appreciated.
Old 01-10-2016, 01:25 AM   #2556
midnight rambler
midnight rambler's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
Watch this guy. He's your video counterpart. Not as entertaining as you but he documents like you.
http://youtu.be/ZkbA3iP6Xzo
Ive been following that guy on youtube for awhile he does document every detail
midnight rambler is offline   Reply With Quote
Old 01-10-2016, 10:31 AM   #2557
TrailerTrash
TrailerTrash's Avatar
Re: Restoring Rusty
the seat belt retractors are not supposed to be mounted on the floor. check out my pics in this thread
http://67-72chevytrucks.com/vboard/s...&highlight=lmc
TrailerTrash is offline   Reply With Quote
Old 01-10-2016, 12:25 PM   #2558
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yes, LOL, thank you I have seen Payton Manings work, ha ha, sorry he sounds like Payton Maning the NFL quarterback. Very nice guy and very detailed videos. He removes the vent window, which is what I finally decided to do, didn't want to at first, but heck maybe that's the only way, we shall see later today, it's Sunday already. Yesterday I gave it three good attempts in between the NFL playoffs, ha ha
Old 01-11-2016, 10:18 PM   #2559
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
I just put my windows back together and can't remember! The biggie is getting the rollers all in BEFORE you bolt the regulator back in and using the window crank to spin the regulator into position.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 01-12-2016, 11:20 AM   #2560
hawkeyegold
Re: Restoring Rusty
just found this gem of a thread... can't put it down!!
hawkeyegold is offline   Reply With Quote
Old 01-12-2016, 12:53 PM   #2561
68Timber
68Timber's Avatar
Re: Restoring Rusty
I had the luxury of putting mine in with the vents out. I put the one roller in its track in the door then loosely bolted it in, ran the regulator all the way up out of the door and attached the glass. If you're going to leave the vents in, I think it was Old rusty C10 that posted recently that you can loosen the bottom of the tracks in the door and replace the glass without removing the vent assembly. I don't know if that works but I get to try it soon myself. I bent a regulator and get to replace it. The fun never ends.
John
74 Honda Z50 build
Old 01-12-2016, 05:02 PM   #2562
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
where is it, shoot us a link, ha ha
Old 01-12-2016, 05:07 PM   #2563
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ah, Installation Amnesia... nice!
Old 01-12-2016, 05:12 PM   #2564
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yup, that's what worked for me too, can't get the window low enuff in the door to slip the second roller in the track cause there is a metal bracket holding the outter door skin to the inside skin, so the only way is to roll the regulator all the way up so the rollers stick out about an inch over the top of the door and slip the glass on the rollers that way.
Old 01-12-2016, 05:14 PM   #2565
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
can't believe how long I dragged out this regulator replacement, but oh well, lets get you updated, so the replacement regulator showed up from Rock Auto took about a week, but there was a weekend in between
old and new pic
Old 01-12-2016, 05:19 PM   #2566
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so decided to pop out the vent window and its easy to take it out once you know how, LOL
there are 6 fasteners, three philips screws on top, two regular screws behind the door card, and one long skinny screw holding the inside of the side mirror bracket to the outside doorskin from the inside (you'll find it)
the guys video you shared above really helped, kudos to him
Old 01-12-2016, 05:22 PM   #2567
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
this pesky little welded in bracket is in perfect location to prevent you from being able to slide the window just enough forward while inside the door to get it on the track, thank you very much GM, you must have gotten that from that German conference on Difficultaism, ha ha
Old 01-12-2016, 05:25 PM   #2568
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
ah yes Dorman aftermarket parts. buying Dorman parts is like buying a box of chocolates, you'll never know what you are going to get, these parts are junk, flimzy stuff, they won't last a year, let alone 40
Old 01-12-2016, 05:36 PM   #2569
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Ok, so finally did you get it done? well sort of, almost, about 99%
you see now my stock, original door crank won't go all the way on the aftermarket regulator, no I did not strip anything, no I did not butcher it, it goes on fine on my old regulators, yes both of them, both old cranks slide right on both old regulators, but neither one goes on this new replacement one, I wonder if they are rebuilt items or brand new ones, donno
so to quote an astute colleague of ours, John:
...The fun never ends.
I think I am going to buy a brand new replacement crank, who knows maybe if I'm lucky Dorman sells them, ha ha!!!
Old 01-12-2016, 05:42 PM   #2570
68Timber
68Timber's Avatar
Re: Restoring Rusty
Man I forgot about that part. I was able to get AC Delco regulators from Rock Auto because my truck is an 85 model and they have different regulators. But even so, I still had to get out the grinder - the original window crank would not seat far enough to get the clip on.
John
74 Honda Z50 build
Old 01-12-2016, 05:48 PM   #2571
68Timber
68Timber's Avatar
Re: Restoring Rusty
I had to go look and see what I did - don't grind on the regulator, grind on the window crank. Open up the hole a smidge all the way up to the threads but don't mess with them - it should fit at that point.
John
74 Honda Z50 build
Old 01-12-2016, 06:41 PM   #2572
68Timber
68Timber's Avatar
Re: Restoring Rusty
Either one of you two fine fellas got pics?
You wouldn't think this would be necessary, but this is the backside of the crank and it was binding up in this hole before I could even get it on far enough for the splines to engage. I removed a little bit at a time until it would fully seat. You don't have to remove any material past the slot that holds the retention clip, that would put you into the splines.
John
74 Honda Z50 build
Old 01-12-2016, 09:15 PM   #2573
Jeramy
Jeramy's Avatar
Re: Restoring Rusty
Dorman window crank handle part#76912 9 bucks a piece
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 01-12-2016, 10:01 PM   #2574
68Timber
68Timber's Avatar
Re: Restoring Rusty
Hmm...
Yep. Exactly what I was thinking...
John
74 Honda Z50 build
Old 01-13-2016, 09:13 PM   #2575
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
so still trying to get a [ahem] handle on this thing, lol
as much as I appreciate John's advice on grinding out the old handle, for $6 bucks I decided to get a new one from the land of Dormania
Can someone explain to me how in the world GM managed to leave one part alone, virtually unchanged from 1952 to 1996, see APPLICATIONS section in the pic below, did they not get the Make Unecessary Changes BiAnnualy Memo, did someone forget the TPS cover sheet
