Closed Thread
Old 02-26-2011, 09:59 PM   #2601
knuckledragger
knuckledragger's Avatar
Re: What did you do to your truck today?
Installed the wood in my bed and reinstalled the bed.I got wood!
65 c-10 swb,bbw,step,402/t350,sold!!
1979 c10 Silverado,250,auto,gonna have a 3/5 drop,and twice pipes!Sold
Bought the wife a 84 gmc short step
knuckledragger is offline
Old 02-26-2011, 11:24 PM   #2602
trevota
drove it, first time in 9 months,
trevota is offline
Old 02-27-2011, 09:16 AM   #2603
Blue Heeler
Blue Heeler's Avatar
front liners, wheel cylinders, rubber brake line,painted air cleaner,new water pump,upper & lower hoses and farted in the cab
Blue Heeler is offline
Old 02-27-2011, 01:36 PM   #2604
kieth
kieth's Avatar
Layin down the interior color right now, it sure looks better.
http://kieth.smugmug.com/Trucks/66-G...00123246_FU6Bt
kieth is offline
Old 02-27-2011, 06:08 PM   #2605
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Looking good! I have been stipping paint, and hope to be where you are at in a couple weeks
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline
Old 02-27-2011, 09:23 PM   #2606
knuckledragger
Installed the driveshaft,finished the e-brake,Wired the taillights,dropped the distributor,wired the alternator,installed the cooling fans and trans cooler on the radiator,installed the rear shocks,ran the heater hoses,installed the front bumper,wired in the 67 column,connected the fuel sending wire for the new tank.Fired it up and drove it out of the garage with open headers!First time it has run under its own power in 30yrs!Took both doors apart to replace regulators and seals.lots done this weekend.
Old 02-27-2011, 09:26 PM   #2607
jbgroby
jbgroby's Avatar
Keith I hope you are using a mask, Your lung don't got a drain valve.
jbgroby is offline
Old 02-27-2011, 09:31 PM   #2608
jbgroby
jbgroby's Avatar
Got a decent bit done today, First I installed Capt. Fabs Dual master Cylinder Bracket/Plate.
The I popped on the Master Cylinder. Then I put in the gas tank took three tries to get it just right You need to make sure the top edge of the filler neck is at least 7 1/2 inches from teh bottom on the filler neck hose. and a touch of axle grease ain't all that bad.
jbgroby is offline
Old 02-27-2011, 10:11 PM   #2609
DPowers
DPowers's Avatar
Replaced my speedo cable and added a front swaybar.
DPowers is offline
Old 02-27-2011, 10:14 PM   #2610
allaboutchevelles
allaboutchevelles's Avatar
I cut the pass side rocker panel off and cut out the pass side rusted floor and made the patches for it. Now I just have to burn them in when I get time.
My Build 64 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=439559
69 chevelle malibu, 64 C-10 shortbed
allaboutchevelles is offline
Old 02-27-2011, 11:09 PM   #2611
knuckledragger
Pic of it out of the garage for the first time in 5 months.
Old 02-27-2011, 11:41 PM   #2612
hotrod66
hotrod66's Avatar
put a column in my short truck and cleaned the bed out (old pick still looks the same other than the column and the fact that it has a bed now)
the long bed I cut the bump stop mounts off and lowered the clutch petal (the stop had gotten bent up so the clutch petal was way higher than the brake) then went for a drive.
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline
Old 02-28-2011, 11:14 AM   #2613
kieth
kieth's Avatar
It was not me doing the paint, a friend of mine is one hell of a painter and he volunteered to do all the shooting. I did not pay attention he was wearing a mask of some sort but not a respirator. He made the metalic on the medium fawn poly paint really stand out. Just as a point of reference it took 2 quarts of this PPG paint to cover the dash, roof,doors, and firewall. We did not paint the floor since we were just going to cover it up with sticky sound proofing and insulation but we did por-15 it for rust. the paint for the interior was only $27.00 per quart.
My painter buddy also does soda and walnut shell blasting, he is coming back over next week to do the rest of the front clip and bed he said this soda blasting saves a lot of man hours sanding, and after the small amount of body work is done, her can etch primer, seal, lay base coat, and clear coat in one day............now that is fast, but it will take 2-3 days to do all the bodywork.......preparing for him to come over and paint it.
kieth is offline
Old 02-28-2011, 11:39 AM   #2614
lakeroadster
Kieth,
There has been a lot of discussion here on the paint and body forum about not using soda blasting due to bad problems showing up in the paint down the road. Might want to use media like nickle slag instead. From what I have read most of the companies that make paint will not stand behind there products if soda balsting is used.
Just saying... not preaching, just trying to help.
John
lakeroadster is offline
Old 02-28-2011, 01:30 PM   #2615
jimmydean
jimmydean's Avatar
Test fit of my pimp seats.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline
Old 02-28-2011, 02:30 PM   #2616
timjt
jimmydean,
got a nice lone wolf image with that single seat
2001 silverado stolen by family
1983 short n wide custom deluxe SOLD
1985 silverado longbed 305 engine 700r4
OH NO! NOT ANOTHER LEARNING EXPERIENCE!!!
"Just because you can do it, doesn't mean that you should"
timjt is offline
Old 02-28-2011, 03:25 PM   #2617
jimmydean
jimmydean's Avatar
Well, until I get the controls figured out, I can't put the passenger one in.
I was lucky the driver seat was in an ok position when I started. But I hope to have the seats wired this week along with my center jump seat installed. My wife thought it was funny that my old motorcycle was solo, too.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-28-2011, 04:11 PM   #2618
steverino66
Fixed this passenger fender brace rust - not especially pretty and I cut some pieces from an old scrap Toyota tailgate (same gauge sheetmetal…), but the fender will hide it and I won't tell anyone but you guys.
steverino66 is offline
Old 02-28-2011, 04:51 PM   #2619
kieth
kieth's Avatar
I think due to the cost we are going to use walnut shells, only $7.00 per bag. On the soda blasting I think one has to do some other treatment to neutralize it, but my painter said the most important thing after all of that is using a etching primer, then a sealing primer, then a base coat, and then clear. heck the sealing primer and etching primer cost as much as the paint. It is expensive but the results seem to be worth it.
At the present time we are sanding the cab and getting it ready to seal and then paint with a test coat of PPG base coat clear coat.
LT1burb on this forum was nice enough to help me with his paint code, but after seeing a good chip of the color we determined that it had too much blue in it. PPG mixed a custom light green (started with a 503 stock lt green)added a metalic base replacing the white in the formula and using a transparent yellow instead of a std yellow. I think this will give me the look I wanted. Stock but with a little Kick....only applying it will tell the tale. Will post pictures when cab gets shot.
Thanks for the advise on the baking soda........will let you know how it all comes out. Kieth
Originally Posted by lakeroadster View Post
Kieth,
John
kieth is offline
Old 02-28-2011, 08:54 PM   #2620
glendale
glendale's Avatar
yesterday i went out to start the truck and button up the burnt wiring and new parts install. the battery was as dead as could be. sooo i am going to rewire the whole truck i am over it. and lost hope your helping !
glendale is offline
Old 02-28-2011, 11:30 PM   #2621
impalaboy9
Drove it for the first time yesterday!
impalaboy9 is offline
Old 02-28-2011, 11:39 PM   #2622
neto
neto's Avatar
Decided to stop working on the 65 and move all the trucks around and work on the 63 just to have something to drive around the block.
neto is offline
Old 03-01-2011, 09:08 PM   #2623
nachodog2
Hell yeah!!!
nachodog2's Avatar
i added my freebie steering wheel
Stock is good but custom is the sh*t!
nachodog2 is offline
Old 03-01-2011, 11:31 PM   #2624
chris6499
chris6499's Avatar
ordered a fuel tank from boyd welding
chris6499 is offline
Old 03-02-2011, 09:13 PM   #2625
kirtzen
kirtzen's Avatar
Cut the bottom of my drivers door.
Name:  door repair.jpg
kirtzen is offline
Closed Thread
