Closed Thread
Old 08-17-2011, 08:50 PM   #2676
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Re: What did you do to your truck today!
Thanks for the encouragement, Boog. I gotta spend some time on my back in here:
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-17-2011, 10:47 PM   #2677
Bishop73
Bishop73's Avatar
I installed my visors, that is all.
Bishop73 is offline
Old 08-18-2011, 09:17 AM   #2678
Low & Slow
whole new front end. Trying to get back to pre drunk driver status. Aligning body panels blows.
Low & Slow is offline
Old 08-18-2011, 03:04 PM   #2679
magwakeenercew2jh
Pretty easy day today. Rough wired in the fan relay associated wires, "hot" junction terminal (moved from the pass. fender to the side of the battery box), got the fan sensor in the radiator.
Stopped for a break and got side tracked. Installed the radiator overflow. I think it looks pretty good. Rubber hose wrapped with some coated braided stuff I'm using until it runs out.
I may move the hose. Maybe not.
BTW, I may be wasting some of you guys' time with these pics every day. I'm just too lazy to set up a build thread. Let me know if I'm being a thread hog and I'll move over.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-18-2011, 07:01 PM   #2680
dukcaln
dukcaln's Avatar
I Like your over flow tank
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP
SOLD 1972 chevy c10
dukcaln is offline
Old 08-18-2011, 08:29 PM   #2681
wilbilt
wilbilt's Avatar
No problem here, looking good!
1971 GMC C2500 Custom Camper - Second Owner.
350/TH350, Dana 60 Rear.
wilbilt is offline
Old 08-18-2011, 10:40 PM   #2682
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Removed the rear bed quarter to replace with a nice new straight piece....Pics should be up in the build thread friday sometime....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-19-2011, 12:12 AM   #2683
RossRinSD
RossRinSD's Avatar
Nah, you're good. I'm not going to read through everybody's build threads... I just like to see a little bit of everything.
RossRinSD is offline
Old 08-19-2011, 03:22 AM   #2684
72TealnWhite
72TealnWhite's Avatar
been wanting to do this for a while now.. not too hard.. Going to paint the inner grill tomorrow.
72' Chevy C-10 Custom Deluxe 350 bored over .30 Th350 Tranny 3.73 gears flowmaster 40 series
87' Ford Mustang GT 302 HO Underdrive pulleys, 3.73 gear, flowmasters
72TealnWhite is offline
Old 08-19-2011, 11:23 PM   #2685
flashed
I went to a local wheel supplier today to buy new beauty bands for my truck ralleys but he only deals in cash and all I had was credit cards and my checkbook so I left empty handed .I didnt have $55 cash on me which is not unusual as I use plastic most everywhere. I will have to go back with cash as thats a great deal.
flashed is offline
Old 08-20-2011, 12:47 AM   #2686
magwakeenercew2jh
Finished up some wiring in the engine bay and cleared away a bunch of trash from the shop. Most of the boxes read, "Early Classic Enterprises".
I found out something I didn't know today. Really stupid I didn't know it before. Fans suck. They Do Not Blow. I wired up both electric fans with
the wrong polarity. I'll have to change that tomorrow.
I thought it was funny I didn't know that. After all the cars and trucks, etc. I guess I've just always just installed a fan on the water pump
and put on a shroud and called it good.
Today, after I came home, I was questioning myself. I lit a little paper in the garage, snuffed it out, started my car and when the electric fan
clicked on, the smoke pulled into the engine compartment from behind the grille.
Duhhhh!
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-20-2011, 04:23 AM   #2687
Ray Rust
Ray Rust's Avatar
Gave the 69 a good bath along with the 51 , all bright and shiny ready for our Sunday Morning cruise .....
Ray Rust is offline
Old 08-20-2011, 11:37 PM   #2688
flashed
I ordered my new fleetside sport bumper from GMC PAULS .
flashed is offline
Old 08-21-2011, 12:17 AM   #2689
wilbilt
wilbilt's Avatar
Thermostat housing gasket was leaking. I didn't have a gasket on hand, but it is one of those 15-minute jobs, right?
Wrong. It is one of those potmetal housings, the truck has been sitting for years and electrolysis caused the bolts to sieze to the housing. After an hour trying to carefully remove them, I ended up snapping both bolts off. The short one snapped at the head and the longer one snapped about halfway up.
Another couple of hours spent trying to save the housing and make it let go of the bolts and come off, but it wasn't happening. The BFH finally made it let go, in pieces.
Thankfully, the remnant of the long bolt came out of the manifold easily. The short bolt was not going to be cooperative, so after another hour I started drilling. 1/8", 1/4", 5/16"...then ran a 3/8" tap to clear out the threads. Only about 2 threads remaining at the bottom of the hole, it is going to take a heli-coil to fix the manifold for good.
I found another housing on an old V6 manifold out in the shed and got it back together for now. The 15-minute job ended up taking all day because I was trying to save the parts. That ended up not happening, so I should have just whaled on it with the hammer from the start. Lesson learned, LOL.
wilbilt is offline
Old 08-21-2011, 10:48 PM   #2690
shopking72
shopking72's Avatar
I tore apart my cluster and touched up my needles and added some Cool White LED's and also installed all new gauges. I am getting matching LED's for the tach this week
Before
After
All done! (Tach looks huge but its only 3" 3/8")
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350
1966 Caprice
1968 Impala (Frame Off LSX Project)
2001 Tahoe LT
2013 Hyundai Elantra
2010 Kawasaki Z1000
shopking72 is offline
Old 08-22-2011, 08:14 AM   #2691
Bennett68C10
Bennett68C10's Avatar
Yesterday I finished the metal work around my rear window, had to replace 80% of the window channel
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline
Old 08-22-2011, 02:48 PM   #2692
solar649
My wife and I decided that we wanted to try our hand at building a Bed cover .
solar649 is offline
Old 08-22-2011, 04:33 PM   #2693
Shyguy
Junior Member
Shyguy's Avatar
I just read what I wrote, you might want to get a beverage of your choice and get comfortable because I got real long winded as I tend to do sometimes. I am sure some of you can relate to this adventure.
Saturday about noon I got a call from my son, he wanted to know if I was busy. Friday he found a mostly rust free '71 swb fleet truck without an engine and transmission for $600 and needed it brought home on his trailer since his wife was using his truck to go to Wal-Mart.
I drove my '92 K-3500 up to his house and hooked up to his flat-bed trailer, as luck would have it, my truck needed gasoline. I rarely drive it because of the poor mpg and high gasoline prices. So we went to the local quick stop and got some gasoline and a couple of 44 oz Mountain Dews.
He set up his GPS to guide us to the place where the truck was since he had kind of forgot how to get there.
As we got closer to the place the truck was the GPS kept saying we were almost there and then past it. GPSs are not perfect so we drove about a half mile further and found the place. The owner was not there, but his brother was.
As most of our trips go we kicked the dirt and tires while shooting the breeze for a while before deciding to load the truck. As these things normally go one of the tires was flat, actually it had a split on the side and would not hold air. We searched around and found a tire with air in it. The only jack the guy had was low of fluid so it would not raise the truck high enough without the help of a 4 by 4.
Then came the chore of figuring out how to load the non running truck. We were going to winch it, but the guy said, heck I will pull it up on the trailer with my trusty '64 GMC dually flat-bed, as he was backing up the exhaust pipe came loose and caught and raised up his truck enough it got his attention.
So I got the trailer backed into position, but not before setting on the soda cup in my seat that was full of Mountain Dew, whoa that felt cold, lol.
The guy hooks up a real long chain to the '71, gets in his truck and gives it what for so fast my son could not steer the truck onto the trailer real straight, almost off one side so we had to jack up the front of the truck and shove it over straighter.
Once the truck was loaded and lashed down off we go, luckily made the trip home ok.
After we got the truck to my son's we decided take the cover off the rear-end and see what a 4.11 spooler looked like, nope not a 4.11 but was a 3.73 spooler that looked in great shape. Don't ask me what a spooler is though.
Sorry no pictures, will take some the next time I am at my son's. Well here is a picture of my K-3500.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 08-22-2011, 04:52 PM   #2694
Shyguy
Junior Member
Shyguy's Avatar
Attachment 790293Yep, I am back I had to get a glass of "Sweet Tea".
Sunday I went to my son's to play with my old trucks. First we worked on his '72 Malibu installing a radiator and hooking up the shift linkage.
After that we stripped out the inside of the cab of my '67 getting it ready so we can cut out the rusted areas and put in the patch panels.
I guess it was about 1:00 pm when the heat started to get to us and we stopped for the day.
This is the '67 we are starting to fix up. The bed has been sold and the front clip has been removed.
I should look more like this blue truck by the car show in town next July.
I have a short stepper bed that is ready for paint already,
Shyguy is offline
Old 08-22-2011, 06:59 PM   #2695
UNEASYRIDER
UNEASYRIDER's Avatar
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 08-22-2011, 07:13 PM   #2696
Kidd-7
Kidd-7's Avatar
Well I'm 2 days late... Changed the oil in her, found some zinc added some lead to the gas and removed some coil spring conpressors that were on the rear. PO's attempt to lower??? Set here down and drove her. She still smoked some, but seemed to be less. 40 years old & sat for 10 months, she runs with no issues, amazing...
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline
Old 08-22-2011, 07:13 PM   #2697
67Slider
67Slider's Avatar
You have got to do a write up on this! That looks great and is exactly what I want on mine. Any more info?
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 08-22-2011, 07:21 PM   #2698
project 67 sub
project 67 sub's Avatar
some more work on my modified rear bumper for my burb
just needs some filler work and block sanding then it can be sprayed satin black
project 67 sub is offline
Old 08-24-2011, 12:40 AM   #2699
dabruce15
dabruce15's Avatar
Finally converted to HEI on my inline six and added a tach. It's a great feeling when parts that have been sitting on the shelf for 6 months finally get installed! Next is the offenhauser 4bbl intake and holley 390.
Beauty is in the eye of the beer-holder.
Praise the lowered!
dabruce15 is offline
Old 08-24-2011, 05:56 AM   #2700
prairewolf
paid 3 months of ins. 52$ and 7 months worth of license plate tags 32$
thats a cheap date......no heater so about a month of ins. will go into suspend.
eat,work,spend,sleep,repeat.
prairewolf is offline
Closed Thread
