Old 02-20-2016, 04:47 PM   #2701
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Dash Cover
and here she is all installed and put together - got her a little dusty whilst installing it, but you git the idear
Gregski is offline   Reply With Quote
Old 02-20-2016, 05:00 PM   #2702
flashed
Re: Restoring Rusty
I think it turned out very well ,looks great .
flashed is offline   Reply With Quote
Old 02-20-2016, 05:08 PM   #2703
lkfldredneck
Re: Restoring Rusty
Looks good Greg! I wish mine had factory Tach And i dont really want to go the length you did to put a factory tach in.. haha
lkfldredneck is offline   Reply With Quote
Old 02-20-2016, 06:53 PM   #2704
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thanks, if we are talking about your 1985 GMC K15 than you already have a volt meter and a electronic oil pressure gauge I assume, so you would only be getting a tach out of a cluster swap, where as in my case I got all three, upgraded from an Amp meter to a Volt meter, from a mechanical oil pressure gauge to an electronic, and from no tach to a tach, so I get why you wouldn't wanna, but in my case it made sense / worked out
now back to reading your Spruce Moose thread
Old 02-20-2016, 06:57 PM   #2705
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
alright boys, so we've installed the dash cover and the new speedo and tach, so how do the new gauges work? what RPMs is the truck idling at now? what about at 60 MPH whats the cruisin RPMs? etc, etc?
well if you had to ask than clearly you have not worked on a 40 year ol' truck, ha ha - cause she won't even start now, won't even turn over, no click, no clack, no pluck, no nothin' my gray hair wisdom tells me the new battery be kaput for some odd reason, go figure fellow truckodians, such is the way of the ninja warrior
we got no reading off the battery, nothin', so we put her on the ol' charge box and wait - might could take the battery to AutoZone for a test or super charge there later on
Old 02-20-2016, 07:56 PM   #2706
lkfldredneck
Re: Restoring Rusty
Yea in your case it made sense. I think i might have to get a big bulky autometer tach and make it look like a 90s wannabe drag truck hahaha
Old 02-25-2016, 09:16 PM   #2707
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Nylon Nuts
just wanted to give you a quick update on the truck today, today was a good day, I found replacements for these nylon nuts that go under the dash, my old ones were crusty and brittle, NAPA came through for us, 16 for only $5 bucks, USA, USA, USA!!!
Old 02-25-2016, 09:29 PM   #2708
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty MPH and RPM
Even more better, O'Reillys replaced my 1 year old battery with a brand new one, so I was able to start and test drive the truck today. The new speedo works, and the new tach works as well.
Here are some numbers for you all.
Idles @ 900 RPM (kinda high but that's by the book, will need adjustment) old Tach idled at @ 1200
with 235/75 R15 tires I get this:
35 MPH @ 1500 RPM
50 MPH @ 2000 RPM
60 MPH @ 2500 RPM
then I ran out of runway, lol
Old 02-26-2016, 02:03 PM   #2709
D13
D13's Avatar
Re: Restoring Rusty
Ah, Gregski, yer an insperatin to weuns. I wish I had half your energy. Not to mention yur weather (he sais looking at yesterday's 8" of snow)
BTW I'm not actually iliterate but I am kind of a redneck.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 02-26-2016, 02:23 PM   #2710
68Timber
I know the pieces fit
68Timber's Avatar
35 MPH @ 1500 RPM
50 MPH @ 2000 RPM
60 MPH @ 2500 RPM
That's odd. Do you know your gear ratio? Plugging those numbers HERE says you have 3.58 gears, pretty much between 3.40 and 3.73.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 02-26-2016, 02:49 PM   #2711
Gregski
Post Whore
Gregski's Avatar
I thought I read somewhere that there was an option for 3.54 which I think I may have, at some point I will just crack the punkin open and look for myself.
Old 02-26-2016, 04:18 PM   #2712
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
I probably asked this already... Do you have the SPID label or even better was the build sheet still in the seat springs?
The axle ratio RPO usually starts with G
According to page 23 of this document from the GM Heritage Ctr.
C10 chassis...
GT4 3.73:1 was standard with the LD4 250 I6
HE4 3.40:1 was standard with the LF5 & LS9 350 except the LS9 with the M40 TH400.
HE3 3.07:1 was standard with the LS9 350-w-M40 & the LF8 454
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 02-26-2016, 05:28 PM   #2713
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I did not see anything related on the SPID plus lots could have happened in 40 a years
Old 02-26-2016, 06:07 PM   #2714
Junqueboi
Junqueboi's Avatar
Re: Restoring Rusty
Oh wow, that build sheet is SO close..... I see two of the three digits of the rear axle RPO code... HEx where "X" is the missing number. It's in the second column of RPO codes on the build sheet. There's a chance that missing piece is laying on the floor somewhere...maybe you could match it up.
Jel
Junqueboi is offline   Reply With Quote
Old 02-26-2016, 09:04 PM   #2715
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
Only on the SPID if it's optional equipment. If it's not on the SPID then it shipped with the standard axle ratio. LS9 with a gearbox other than the TH400... HE4 3.40:1
So close to having the build sheet too... At least you have some of it.
Old 02-27-2016, 03:43 PM   #2716
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
T r u c k !
Old 02-27-2016, 09:18 PM   #2717
flashed
Re: Restoring Rusty
And some say you cant haul anything with a short bed ,and it looks good doing it too.
Old 02-27-2016, 11:19 PM   #2718
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Work Benches
Thanks, gonna make two of these tall work benches out of it in preparation for March Madness. Nice and tall, 42"
Old 02-27-2016, 11:22 PM   #2719
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
You Know What Time It Is !!!
picked up this engine hoist and engine stand from Pontiac Mike, March Madness is around the corner
Old 02-27-2016, 11:27 PM   #2720
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
going to finally replace my rusted radiator support, mine has lost about 18 inches from the bottom under the battery section, picked up this one from Pick N Pull a few months ago, it only has surface rust, having this piece out will sure make pulling the engine out easier
Old 02-27-2016, 11:28 PM   #2721
flashed
Re: Restoring Rusty
What is this March Madness you speak of ,something sports related I guess .
Old 02-28-2016, 12:42 PM   #2722
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
MARCH MADNESS is where The Greg takes on a massive truck project or a series of projects. Here's a taste of what he plans on doing next month.
1. Engine Performance Top End Swap
2. Overdrive Manual Transmission Swap
3. Flowmaster 40 Series Exhaust Upgrade
4. Fix / Eliminate Massive Oil Leak
5. Relocated Alternator To Mid Engine
6. Rusty Radiator Support Swap
Old 02-28-2016, 12:54 PM   #2723
daddyjeep
daddyjeep's Avatar
Re: Restoring Rusty
March Madness sounds like a good time.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-28-2016, 02:04 PM   #2724
flashed
Re: Restoring Rusty
My March Madness will involve some of that .
Old 02-28-2016, 02:17 PM   #2725
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Sweet, so I'll represent the West and you represent the South, and if two more guys join we'll have our very own tournament bracket NCAA basketball style, LOL
