#251 |
![]() Join Date: Oct 2008
Re: 1970 VA Longbed Project
Man, it seems that you do what you gotta do to get things done! The long or short way = true hobby passion.
At first the rattle-can seems questionable, but I have seen great adhesion performance with these cans in the past. I think the only concern will be paint thickness but I see how you use the texture to create more durabillity. Keep it up!
1968 Chevy Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=321717 1959 Chevy Apache 3100 SWB Big Window http://67-72chevytrucks.com/vboard/s...d.php?t=597069 |
#252 | |
VA72C10
![]() Join Date: Mar 2008
![]() ![]() It probably would have only cost me a few hundred more for powder but that will pay for some more custom mods I have planned and I really prefer the ability to touch up the paint easily. I WILL be driving this and will be able to touch up things from time to time if it gets scratched up through use.
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 09-23-2009 at 04:01 PM. Reason: spelling |
#253 |
VA72C10
I also think prep work has a lot to do with how the rattle can stuff works. I grinded the frame to mostly bare metal, wiped it down, blew it off with air, and wiped it with laquer thinner. Then applied the automotive grade rustoleum stop rust primer. Two light coats of that followed by three coats of the hammered finish. I will most likely do two more coats since I have to touch it up now anyways (idiot
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 09-23-2009 at 04:07 PM. |
#254 |
VA72C10
I have drilled through the painted frame with no issues either of chipping or peeling. Then I just shoot the holes with more hammered paint and it's good to go...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#255 | |
If I keep the next project orginial, I might just consider the rattle!
#256 |
Now what??
I really like the two-tone hammer finish look on the frame/suspension. I think I will do something similar. It's coming along good. (Now if I could get the chance to work on mine...
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() |
#257 |
Blaze-Air
Long live the rattle can. Done right, it works great. That wrinkle stuff is great.
![]() Btw, I love the red interior reference pic. Sporty! Shaved firewall will definitely be a nice touch also. ![]() |
#258 |
I like how you cleaned up your cab. keep up the good work.
#259 | ||
VA72C10
I really like that red interior. It won't look the same because I am not changing my dash, but I will be smoothing the center part of the dash between the gauge bezel and the glovebox door. The console will end up flowing up into the dash and to the back and into the sub box behind the seats. Thanks. It took about 6-7 hours to clean the bottom of the cab that clean between undercoating, dirt, and rust. Started with the wire wheel to knock off the most junk and went to the grinder to take it to bare metal.
#260 |
CCTek
I just got to look through your build. Lookin good! Isn't it amazing how one thing affects another? Every idea I come up with makes me have to come up with 10 more to solve the issues I create with the first idea. Man! Keep up the good work.
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
#261 |
VA72C10
thanks!
#262 |
VA72C10
Got the final patch panels needed (other than the passenger door bottom) today as well as the trailing arm bushings and bed bolts. Got them from Athey's truck parts. Thanks Bill! Had them pulled and ready for me to stop by and pick them up.
#263 |
VA72C10
Dropped off the cab patches and inner and outer rockers. Everything looks like a very good fit except the passenger side rear cab support. I had another one and that worked well so whenever he gets time to weld them on, the cab will be done.
I took off the heater box from the cab as step 1 of shaving / smoothing the firewall. Glad to see there was no rust underneath. The heater core had to be brand new when I got the truck. Finished up taking out the rest of the wiring. The only thing holding the wiring in is the ignition switch. I got a little tool that's supposed to help remove that so I will try that tomorrow. ![]() ![]()
#264 |
VA72C10
Thought about the trailing arm bushings after I had painted the arms....so I just picked those up and went to remove the old ones tonight....not fun. Well, honestly, they're not too bad as long as you have a good plan. The first one took an hour with Jason helping me for 15 minutes of that. In reality I wasted 55 minutes and then figured out how to do it. Jason recommended drilling out the rubber in the middle of the gasket. I did that and the pin would come out with a little persuasion. I had smashed the end of the metal sleeve so I then had to push that back into shape then used a socket to knock the sleeve out of the arms.
THe second arm took me literally two minutes. Drilled out holes in the rubber, hammered the pin flush, used the other old pin to hammer it out, pulled the old pin and rubber out, and then 4 or 5 taps with a hammer and appropriate sized impact socket and the sleeve was out. Test fit the bushings and they will be a good but tight fit. Cleaned up the trailing arms a little more, sanded a few rough spots, cleaned and prep'd them, shot them in primer, and then two more coats of hammered silver. Painted the custom transmission crossmember while I was at it. ![]() Out with the old ![]() In with the new (after paint) ![]() I will have to write the size of this impact socket down because it is a perfect fit for when I go to press in (hammer in) the bushings after paint. ![]()
#265 |
VA72C10
Here's the painted arms and tranny crossmember
![]() And a gratutitous action shot I took of myself grinding on the truck last week. I need to ask Jason to take some pictures of me working because the only proof I have are my dirty arm pictures... ![]() ![]()
#266 |
VA72C10
And here's the C-notch finished painted with the provided bumpstop. I still have to get some red loctite to tighten this down but I wanted to show this in case someone is wondering how to do the bumpstop w/ a notch.
![]() Got my holes drilled for my polished stainless battery box. Painted them up last week and got some stainless hardware to attach it to the truck. Should have the box this week. This is one reason I really like spraypainting the frame...I was able to drill these holes after the original paint and in 10 minutes I primed and applied a new coat and you cannot tell that they weren't painted originally. ![]() ![]()
#267 |
VA72C10
Gotta get new bolts for the trailing arms. I am going to mock them up tomorrow to get verify the locations to drill holes for the airbags. Plan on getting those holes drilled, bags mounted, and I also plan on cleaning up the rest of the front end parts and hopefully painting them.
I got the Scotts brake booster/master relocation bracket in the mail today from JLaird. One more step towards a shaved firewall.
#268 |
![]() Join Date: Nov 2008
when i removed my ign switch it sucked. i didn't have the tool! ha ha hopefully it works out for ya.
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] ![]() My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
#269 |
VA72C10
I'll find out tomorrow hopefully. I've been under the weather today and my youngest daughter had a 101 temperature so I've been staying around the house.
#270 |
keep an eye on that temp!
#271 |
VA72C10
Definitely...she's doing better today. I still feel horrible but that hasn't stopped me from working and won't stop me from working on the truck tonight. Have to go get my brother in law's shower fixed first though....
#272 |
VA72C10
Got the trailing arms on, bags mocked, and tranny X-member set in it's approximate position...started playing with the frame mounted brake booster. Pics to follow later...
#273 |
push through the pain ha ha adda boy!
#274 |
I like your bump stop. Was wondering myself how to use bump stops(and if-alot of people do not and let the truck squish the bags). Are you running any for the front?
#275 |
VA72C10
Yep, ya gotta do what you gotta do
![]() The bumpstop with the notches is from CPP. You can get them separate. I am going to get a slightly larger bumpstop to use for the front in place of the factory bumpstop. It will still be much smaller than the factory one...just in case of bag failure to prevent metal on metal. Even though the RE-7 bags have internal bumpstops, I figure safe is better than sorry.
