Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 01-23-2011, 06:18 PM   #251
kev2809
low n' slo
kev2809's Avatar
Re: The '67 Burb Build Thread
wow...125 a pair, much better lol
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 01-23-2011, 06:26 PM   #252
project 67 sub
project 67 sub's Avatar
haha yup lol. not a bad price at all, i have had mine since 06 and they are still nice and not all dried out or anything, so i would call it pretty good quality stuff. i also bought their tailgate/lift hatch seals and the seal for the hatch glass at the same time
project 67 sub is offline   Reply With Quote
Old 01-23-2011, 08:26 PM   #253
Dchtlh
Dchtlh's Avatar
sorry to barge in hear but does anyone know where to get the right rear quarter glass? I need to get one soon.....Thanks
Dchtlh is offline   Reply With Quote
Old 01-24-2011, 03:21 AM   #254
project 67 sub
you can check on ebay, i think they have some for sale on their.
Old 01-24-2011, 03:34 AM   #255
project 67 sub
did some cutting of uneeded under dash wireing and some wire wheeling, then i sprayed some rust converter around where the windshield rubber goes, behind the dash/inside fire wall, and above the inside of windshield, and started wire wheeling the paint and bondo off of my replacement fender so i can fix/redo it.
Old 01-24-2011, 09:43 AM   #256
67chevy1series
67chevy1series's Avatar
dayum youve been busy! i miss those day when i neede to take somthing big off i still need to do that just not where i live garage is to small...looks AWSOME!!!
67chevy1series is offline   Reply With Quote
Old 01-24-2011, 04:30 PM   #257
project 67 sub
haha thanks, and yah ive been busy lol.
Old 01-25-2011, 02:39 AM   #258
project 67 sub
finished wire wheeling the paint off of the front side of the fender.
Old 01-26-2011, 03:41 AM   #259
project 67 sub
pulled both front fenders, realigned driver dorr as best as possible, and rehung and aligned drivers fender. also installed my other block off plate i made.
Old 01-26-2011, 10:55 AM   #260
67chevy1series
looks good i will be doing somthing similar to you when i do a conversion to AC
Old 01-27-2011, 12:38 AM   #261
project 67 sub
wire wheeled and painted one coat of paint on one side but ran out of paint, and took a pic of what i did last night. realigned the door and installed the fender, the door gap is real close at the bottom, but nothing touches. also decided to take a ic of the original spid
Old 01-27-2011, 01:16 AM   #262
67chevy1series
i wish i had the new pass. fender! what is wrong with the old fender?
Old 01-27-2011, 01:26 AM   #263
project 67 sub
they are both 68 fenders, but the new one is in way better shape and the marker weld job is done way better lol. the one i took off is warped aorund where the marker light was welded in due to using a cheap flux core welder and kept blowing through the cheap aftermarket metal being welded in. also it is messed up in the rear lowe corner due to a jack stand lol. dont ask how that one happened haha
Old 01-28-2011, 01:38 AM   #264
project 67 sub
drilled out the rivets and removed these from my grille as i have decided that i am no longer going to use them, cut the center grill support to make it look cleaner behind the grille since i will not be using the grill insert things. also drilled a 1/2" hole and cut a notch in the side of the dash to slide around the wiring that comes out through the bottom of the drivers side a pillar, then i cut out the backside of the replacement front fender for tire clearance
Old 01-29-2011, 12:25 AM   #265
project 67 sub
painted around the windshiel area inside and out, finished painting the splash pan, painted the radiator core support, radiator, frame rails, also painted the drivers side fender. i also installed the grille trim and started installing the grille. also purchased some headlight and wiper switch knobs and bezels from sharpie
Old 01-29-2011, 12:26 AM   #266
project 67 sub
oh, and i sprayed some rust reformer paint on the inside of the replacment passanger fender
Old 01-29-2011, 12:29 AM   #267
67chevy1series
wow it looks clean....
Old 01-29-2011, 12:40 AM   #268
project 67 sub
haha thanks, i like the way it looks without the grille inserts and turn signals in front. still need to finish the other fender so i can put it on and finish bolting the grille down and bolt up the splash pan.
Old 01-29-2011, 12:53 AM   #269
67chevy1series
are you gonna run the turn signals in the bmper 71 72 style?
Old 01-29-2011, 01:02 AM   #270
project 67 sub
ewwe heck no lol. might not run any, not sure yet. but if i do they will not be the stock ones. also i plan on running some wire mesh behind the grille openings. will then have to make an extension rod to open the hood. but if i do that i might hide the turn signals behind the wire mesh.
Old 01-29-2011, 01:11 AM   #271
kev2809
low n' slo
kev2809's Avatar
what did u use for paint on all that?
-_--_--_ _________
Old 01-29-2011, 01:18 AM   #272
project 67 sub
everything is all done in rattle can. which part and color are you refuring to so i can tell you what brand and kind of paint?
Old 01-30-2011, 12:30 AM   #273
project 67 sub
installed the door hinge that i got from sharpie, notched my dash mount, welded some studs to the bottom of the dash, and installed and painted the dash (will do body work on the center later), also aquired some new mirrors for my burb
Old 01-30-2011, 12:31 AM   #274
project 67 sub
here is some other pics of me test fitting the dash and stuff and the studs that i welded on.
Old 01-30-2011, 12:45 AM   #275
67chevy1series
wow this is a cool idea about how to put the dah in with out welding it in
