Old 04-01-2010, 11:03 PM   #251
scotts62
One day...
scotts62's Avatar
Re: MY build thread...
Well you did a good job at the teasing so now ill have to wait for the pics..
Scott
93 crew cab build
Project 62
Old 04-01-2010, 11:17 PM   #252
shortbed70
shortbed70's Avatar
Alright here you go not much still not bolted in but its there kind of. After over a year its back in the truck.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-01-2010, 11:40 PM   #253
daverod
SSN 706
daverod's Avatar
Looks sweet. Do you have any problems with it hitting the firewall? What mounts did you use?
daverod is offline   Reply With Quote
Old 04-01-2010, 11:50 PM   #254
shortbed70
shortbed70's Avatar
Stock mounts and its close to the firewall but I still need to move some things around and see where it sits. but its close to where it is. Thanks it means alot this has been along time coming getting this thing going back togather.
Troy
Big Red Dog build
Old 04-01-2010, 11:55 PM   #255
daverod
SSN 706
daverod's Avatar
I'm getting close to test fitting mine. I've heard people having trouble with the HEI or the valve covers. I was going to see if stock mounts would work but I guess I'll just watch you. Did you notch your cross member to get to the top of your bags? It's hard to see. I don't know if you have to or not?
Old 04-02-2010, 12:27 AM   #256
shortbed70
shortbed70's Avatar
No Im running the bolt in top plates and ptc fittings so I will mount bag to plate then feed line through the frame hook up then bolt plate togather. I dont really want to notch the frame. The VC are close but I am running tall covers and havent got the placement correct yet I might move the holes some or modify the stock mounts to get the motor where I want it.
Troy
Big Red Dog build
Old 04-02-2010, 01:48 AM   #257
Captainfab
60-66 Nut
Is it just the valve cover clearance? I see you already have the motor mount brackets in the forward holes, but your engine seems to sit farther back than it should with the brackets in the forward holes. Are you using the '68-'71 big block brackets?
Old 04-02-2010, 02:12 AM   #258
shortbed70
shortbed70's Avatar
This truck was actually a inline 6 motor but had a 350 already in its place with a pg trans. I looked alittle closer and where it sets now I have about 1" clearence on drivers side cover but the pass side tucks back in the firewall some but still doesnt hit. My dizzy is about 5" off the firewall.I am going to move the trans mount back then see if it sits where my other truck did. I also need to put my drive shaft in and see if it has enough slip in it.
Troy
Big Red Dog build
Old 04-02-2010, 06:01 PM   #259
shortbed70
shortbed70's Avatar
Well ran into the next problem I cant go back any further back then where it sits nowso I need to get a longer driveshaft. My other truck the mounts were in the back position and it fit with short covers but I like these covers and want to keep them so anybody close have a turbo trans shaft from shortbed truck? I had mine shortened 3" and now is about two inches too short and I dont want it breaking the tailhousing or vibrating. SO I have to drill one hole in the frame for the front motor mounts (on the crossmember) get new tranny lines,and a longer shaft BUT i have more clearence for dizzy! OR I could sell my VC and get short ones.
Troy
Big Red Dog build
Old 04-07-2010, 10:22 PM   #260
shortbed70
shortbed70's Avatar
Well bought some motor mounts and bolted them in now need the driveshaft. Next chore is to get the front bags in and bolted down.
Troy
Big Red Dog build
Old 04-07-2010, 10:41 PM   #261
baggedout81
Originally Posted by shortbed70 View Post
well bought some motor mounts and bolted them in now need the driveshaft. Next chore is to get the front bags in and bolted down.
sat.?????
baggedout81 is offline   Reply With Quote
Old 04-07-2010, 10:53 PM   #262
shortbed70
shortbed70's Avatar
Yea I think I'm going to put the bags in the front and set it on the ground and I need to cut the bolts off the track bar and get it taken off for a longer one. I have to work in the morning till mid afternoon.
Troy
Big Red Dog build
Old 04-08-2010, 08:41 PM   #263
shortbed70
shortbed70's Avatar
OK guys I got the motor mounted and finalized so I decided to set it on the ground and start looking at other things like all the mounting hardware for the frontend and still need to extend the rear brakeline for duel pot master cylinder. Heres a couple pics. I need some money now...
Troy
Big Red Dog build
Old 04-08-2010, 08:53 PM   #264
scotts62
One day...
scotts62's Avatar
Hey looking good!
Scott
93 crew cab build
Project 62
Old 04-08-2010, 11:06 PM   #265
protrash64
Resistance is Futile
protrash64's Avatar
Originally Posted by scotts62 View Post
Hey looking good!
I agree!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-09-2010, 01:40 AM   #266
Captainfab
60-66 Nut
x3
hey looking good!
Old 04-09-2010, 07:36 PM   #267
shortbed70
shortbed70's Avatar
Thanks guys I'm trying to keep this build rolling but funds are getting tight.
Troy
Big Red Dog build
Old 04-09-2010, 10:02 PM   #268
scotts62
One day...
scotts62's Avatar
You arnt the only one my friend..
Scott
93 crew cab build
Project 62
Old 04-18-2010, 07:24 PM   #269
shortbed70
shortbed70's Avatar
Well got the bags mounted front and rear and hooked up the torque convertor to flexplate and took off the front drums to clean out the rust and stuff from sitting. Also started fabbing a long track bar and mount so the rear stays centered. Now on to the bed...
Troy
Big Red Dog build
Old 04-18-2010, 09:41 PM   #270
billysbowties
billysbowties's Avatar
Great skills man, I like everything you have done so far great work. I would like to ask you where you got the brake, I am looking for one just like you have.
billysbowties is offline   Reply With Quote
Old 04-18-2010, 11:07 PM   #271
shortbed70
shortbed70's Avatar
Thanks man. I got the brake from harbor freight online and I haven't used it yet I'm kind of upset I spent the money on it But I'll find a use for it soon.
Troy
Big Red Dog build
Old 04-23-2010, 10:33 AM   #272
shortbed70
shortbed70's Avatar
Well track bar is done,painted and mounted and decided to paint the steering column so I scuffed it and primed with etching primer and crows feet all over so I broke out the wire wheel,scotchbright,sandpaper and buffer and heres what I ended up with.
Troy
Big Red Dog build
Old 04-23-2010, 12:47 PM   #273
REDNOSE65
REDNOSE65's Avatar
...Man I hear you on that one!!!
Just outta curiosity...are you keepin these wheels???
RED NOSE '65
LOS HITTERS C.C
DALLAS, TEXAS
The making of a Red Nose...
http://www.67-72chevytrucks.com/vboa...d.php?t=396518
REDNOSE65 is offline   Reply With Quote
Old 04-23-2010, 12:56 PM   #274
shortbed70
shortbed70's Avatar
They might already be sold to my father in law but unsure yet
Troy
Big Red Dog build
Old 04-23-2010, 09:13 PM   #275
jkb
What are the wheel and tire sizes? Looks great
"All Alone Meet & Greet 2010."
http://67-72chevytrucks.com/vboard/s...d.php?t=393754
jkb is offline   Reply With Quote
