Old 12-29-2010, 02:39 PM   #251
brossow
Amateur Rust Fighter
brossow's Avatar
Re: Silver Dollar
Originally Posted by jgrisafi View Post
Did you ever say the name of the color paint you used on the truck? Just curious.
http://67-72chevytrucks.com/vboard/s....php?p=4292611
Brent
'72 Chevy SWB stepside - [ Build Thread ]
'79 ChevMC SWB fleetside - [ Build Thread ]
'64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...)
brossow is offline   Reply With Quote
Old 12-29-2010, 03:36 PM   #252
Ipaintgrt
Re: Silver Dollar
Did you ever figure out the brakes?
Ipaintgrt is offline   Reply With Quote
Old 12-29-2010, 08:19 PM   #253
mrhino
Re: Silver Dollar
it was a mix of House of kolor Galaxy Gray and Orion silver. "Orion's galaxy" is what I called it.
no the proportioning valve still is leaking at that little rubber plug. i have No idea
what the hell that is for. if anybody know please enlighten me. I will be drilling it and plugging it tomorrow. its really starting to piss me off now.
mrhino is offline   Reply With Quote
Old 12-30-2010, 06:40 AM   #254
Ipaintgrt
Re: Silver Dollar
I wonder if you could get a proprotioning valve from a similiar vehicle, maybe a 90 SS truck or something with 4 wheel disk brakes and use that for your application? Good luck, you have done a great job.
Old 12-30-2010, 08:43 AM   #255
menace121978
menace121978's Avatar
Re: Silver Dollar
http://www.classicchevy.com/chevy-di...LL-_-20-32-_-X
or just get this. i have this one and it works great so far
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 12-30-2010, 06:19 PM   #256
mrhino
Re: Silver Dollar
Thats the one I have, Iv used them before with no problem. but this one is being a difficult.
I removed that rubber plug. and drilled and taped the hole to a 6-32 used a set screw with a little thread sealer/locker and then filled the rest with epoxy. I'll wait for that to set up and try again.
Old 01-02-2011, 08:22 PM   #257
mrhino
Re: Silver Dollar
Sorry its taken me so long to get back to the truck, with the kids and the wife off for the holidays, its hard to get anything done on it. but I did get to work on those damn brakes this weekend, and I think I got it. as you know i pluged the stupid rubber thingy that was leaking all the time, replaced a cracked line and have had to re tighten every connection I made. This time I had to bleed the master again, and took the proportion valve apart one more time here are some photos of that. this time I did it still hooked up to the M/C
with everything out of the valve you can see right through it.
next was the main plunger, stick it in and make sure that concaved part is right in line with the switch hole
then goes in the rear spring thing
then the front one, followed by the nut and washer.
then the switch
and finally the rear line adapter, and screw in the line
ok, now its time to see if they work with out leaking. started bleeding in the rear, got some air out, wife says the pedal is getting firm. Then it went down to nothing. Im thinking, what the hell now. Check the proportioning valve, its not leaking, WTF! I pulled the cap off. out of fluid. SOB filled it back up and a quick on the truck bench bleed and were back in business . finally got all the air out. then she says they feel firm and then go soft. we bleed them again, no air. firm then soft. well we played this game for a few more minutes. I could see the rear calipers working. I spun the rear rotor while she slowly applied the brake, they grabbed fairly quickly. when I let go, she said it went soft again. Then I noticed it, the calipers were clamping hard enough to move the other end of the rotor out and thats what she was feeling. The pedal wasn't going soft it, would just move down a little from the rotor moving back and forth. I took a lug nut and tightens up the rotor to simulate the wheel being bolted on and the problem was fixed. check everything again no leaks and it looks like everything is working. will see if she stops under her own power in a few days. tomorrow Im working on the door panels
Old 01-02-2011, 09:13 PM   #258
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
Really nice prop valve break-down. I know a lot of us really appreciate the effort it took to post that in such detail.
67 5.3L Build
67C10BUB is offline   Reply With Quote
Old 01-02-2011, 09:56 PM   #259
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
nice job! Glad you got it fixed.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 01-02-2011, 11:56 PM   #260
kvn1011
Kvn1011
kvn1011's Avatar
Re: Silver Dollar
Wow just read from page one to 11!! awesome build!!!
you are getting pass these hurdles!!
subscribed!!
kvn1011 is offline   Reply With Quote
Old 01-04-2011, 08:35 AM   #261
mrhino
Re: Silver Dollar
subscribed!!
Thanks, glad you came along for the ride.
Old 01-04-2011, 08:28 PM   #262
mrhino
Re: Silver Dollar
Door panels:
I pop rivet the chrome trim on because my new panels were thicker than the orginals and they wouldn't fit.
When I had my seat redone I had the guy make me some door panels to match my seat. there held on at the bottom with 1/4-20 chrome allen head bolts
Found some cool handles and cranks at a street rod show. unfortunatly I had to do some modifications to them to make the, not so rickity.
each piece is held on with set screws, so I counter sunk each piece, and tapped it out to a bigger screw, so the set screw would hold real good and not turn inside the other.
I wanted something a little diffrent the the stock armrests. It turns out the the 55- to sixty something bolt right on in the stock location and look like a custom piece
pardon my mess
Old 01-04-2011, 09:04 PM   #263
w4625
Re: Silver Dollar
Awesome Job!! I have a 72swb fleet that I will be working on this spring. This thread has been very motivating!!! BTW What's the asking price of the truck?
w4625 is offline   Reply With Quote
Old 01-04-2011, 09:08 PM   #264
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Silver Dollar
so close... lookin nice, must be excited
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 01-04-2011, 09:46 PM   #265
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
That looks great. Nice job improving those handles and the armrest is PERFECT with the look of the rest of the panel!!!
Old 01-05-2011, 05:20 PM   #266
mrhino
Re: Silver Dollar
Originally Posted by w4625 View Post
Awesome Job!! BTW What's the asking price of the truck?
Not sure, I know what id like to get for it, but that may not be whats realistic. What do you guys think? be Honest you wont hurt my feelings.
Old 01-05-2011, 05:26 PM   #267
brossow
brossow's Avatar
Re: Silver Dollar
Let the tongue-in-cheek bidding begin!
Brent
Old 01-05-2011, 06:43 PM   #268
67C10BUB
67C10BUB's Avatar
Re: Silver Dollar
I would think about 25 - 30K in CA, but I think you guys are a little lower in other parts of the country.
67 5.3L Build
Old 01-05-2011, 06:59 PM   #269
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Silver Dollar
Man, nice work on the door panels. That is really cool about those arm rests, thanks for that info! Congrats on getting your brake issues resolved and good luck with getting it buttoned up.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 01-05-2011, 09:24 PM   #270
mcbassin
Still Learning
mcbassin's Avatar
Re: Silver Dollar
those door panels look great! Nice handles and armrests too! Awesome progress!
mcbassin is offline   Reply With Quote
Old 01-10-2011, 12:11 PM   #271
Bennett68C10
Bennett68C10's Avatar
Re: Silver Dollar
Nice progress, can't wait to see how the trucks looks all together shining in the sun.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 01-13-2011, 02:52 PM   #272
coop34
Re: Silver Dollar
Hey Rhino have you had a chance to fill this thing up at the gas station yet? Curious to see if you have any issues getting the nozzle in their with that bend in the fuel filler.
coop34 is offline   Reply With Quote
Old 01-13-2011, 08:19 PM   #273
mrhino
Re: Silver Dollar
No Not yet, Its been so damn cold here i haven't felt like working in the garage. i will post the finding on this and other stuff when I get it out on the road.
Old 01-16-2011, 07:50 PM   #274
mrhino
Re: Silver Dollar
I Finally got that new windshield in. It took hours yesterday, putting it in and then having it pop out. we, my wife and the neighborer, must have done that 20 times yesterday and used half a jar of vasoline, and still never got. The wife say forget it lets pay someone to come put it in. I thought to myself bull****. I didnt just build 99% of this truck to have some A-hole come and put it in in 5 min and make me look like a idiot. so i did what any self respecting man would do. Pleaded with the wife to come out and pull my rope again today. after about 4 times it went in. It didnt pop out. Nor did I break it.
I got the cowl panel and the antenna on today too. tomorrow hopefully I will get the dash pad and the seat in. Man it feels good to get that windshield in.
I dont have any pics of the install. my photographer didn't want to stop watching Sponge bob or Scobby Do or whatever it was she was into. But I though id post some pics of what it looks like as of today.
Old 01-16-2011, 07:54 PM   #275
VA72C10
VA72C10
VA72C10's Avatar
Re: Silver Dollar
Looking awesome!!!
5.3, boss 338, house of kolor, lsx, tank
