Old 11-25-2013, 08:13 PM   #251
eagleuh1
eagleuh1's Avatar
Re: 67-72 Electric speedo
More pics
eagleuh1 is offline   Reply With Quote
Old 11-25-2013, 08:16 PM   #252
eagleuh1
eagleuh1's Avatar
Wish could load more than one pic at a time.
Old 11-25-2013, 08:32 PM   #253
eagleuh1
eagleuh1's Avatar
67C10rustbuket, on you mount bracket, I would recommend you slot the initial three holes you use to mount to gauge console. I missed a step from LS171Nova, where you verify the speedo is centered. Mine came out too far to the right. Unfortunately, I already drilled all the other holes before I checked. Slotting those 3 holes would allow repossissioning the mount before drilling the rest of the mount holes. Otherwise, worked great and definitely glad I went this way. Thanks. Jim
Slot these 3 holes.
Old 11-27-2013, 09:15 AM   #254
67c10rustbuket
67c10rustbuket's Avatar
Slot these 3 holes.
Looks good, I will put mine back together and check the gauge center alignment. When I designed the plate I went off the needle center and combined the hole patterns so It SHOULD be exacttly where the original speedo needle was. The problem with slotting the mounting holes is I would have to slot most of the holes and then it would be less rigid. I made it pretty thick to make sure it was rigid. If there is an alignment issue I will fix it and replace them all. There is a (very) small chance that there was some drift when those were punched on the old turret press. I checked the plates I have at home with my template and they are all dead on. If mine is properly aligned and yours is not I can replace yours or make a special plate and offset the holes for you.
To others: I know several are waiting on me to finish boxes and I have yet to finish them. I have been swamped at work with our new machinery and filling engineer requests. I will try to get them done asap, hopefully the big guys leave me alone today so I can work on them .
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 11-27-2013, 04:19 PM   #255
eagleuh1
eagleuh1's Avatar
I expect it was due to the reproduction gauge housing and back tin. It didn't want to lineup with the new glass or the new console face that it mounts to. Minor adjustment and all is fixed. I just need to pay attention to the procedure steps. Good product anyways. Thanks again for making these. Jim
Old 12-01-2013, 06:37 PM   #256
BigRed76
BigRed76's Avatar
Glad to hear you haven't given up on us
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 12-01-2013, 06:41 PM   #257
BigRed76
BigRed76's Avatar
Getting closer, just have to find the wired light sockets, install the led high beam indicator and attach all the wires.
Are you using an 8k rpm tach?
Zach
Old 12-01-2013, 08:16 PM   #258
eagleuh1
eagleuh1's Avatar
BigRed76, yes, it's an 8k reproduction tach. Jim
Old 12-01-2013, 09:56 PM   #259
BigRed76
BigRed76's Avatar
I thought it looked a little different. Are the numbers and letters on the gauge lense just like the originals? All of the repro 8k tach kits I've seen have lettering on the gauge lense that's different from the original style.
Zach
Old 12-02-2013, 10:11 PM   #260
eagleuh1
eagleuh1's Avatar
Don't know about originals. Never had one or looked at one long or close enough to remember what they looked at. Next time I'm in my shop I'll get a better pic and post it. Jim
Old 12-02-2013, 10:25 PM   #261
BigRed76
BigRed76's Avatar
Zach
Old 01-11-2014, 08:41 PM   #262
69SCSS
69SCSS's Avatar
Originally Posted by ls1nova71 View Post
THey are actually out of a '65 chevy. They are sockets that ground to the tin, just like the heater control light in a '67-'72.
Just a quick question, did you pull the lights out of a gauge bezel from a '65 or did you find a place online you can get them from? I'd like to use those too, so wondering where to grab them. Thanks!
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 01-12-2014, 02:14 AM   #263
eagleuh1
eagleuh1's Avatar
Yeh, Me too. Haven't been able to find any anywhere. Last major hurdle to putting it in the truck. That and some free time. Sorry BigRed, it's going to be a while before I can get that pic of the tach. Back at work. Jim
Old 01-12-2014, 11:09 AM   #264
ls1nova71
ls1nova71's Avatar
Yes I got them off of a truck at the pick n pull. I've never looked for new ones, but I'm sure someone makes them since they make harnesses for all kinds of cars and this kind of socket dates back to the late 20's or so. Ill do some checking and let you know what I find out.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-12-2014, 12:58 PM   #265
ls1nova71
ls1nova71's Avatar
Did a quick interweb search and found these. I've never used this company, so I know nothing about them, but this looks like the socket that will work. http://www.classictruck.com/product/...llaneous_Items
Old 01-13-2014, 12:07 AM   #266
67c10rustbuket
I am going to use these. wired twist lock 194/168 sockets. Just like original but wired. They are not self grounding but the twist lock is the correct size for easy install. They are LED compatible or use original bulbs.
http://www.superbrightleds.com/morei...ket/1150/2737/
Dan <---(my name)
Old 01-13-2014, 12:11 AM   #267
67c10rustbuket
Dan <---(my name)
Old 01-13-2014, 01:21 AM   #268
eagleuh1
eagleuh1's Avatar
Thanks guys> Jim
Old 03-05-2014, 05:06 PM   #269
elf w/capital T
pm sent
elf w/capital T is offline   Reply With Quote
Old 03-06-2014, 12:19 AM   #270
ls1nova71
ls1nova71's Avatar
Originally Posted by elf w/capital T View Post
pm sent
To who? If I can answer any questions just let me know.
Old 03-06-2014, 01:00 AM   #271
LS-K
ls1nova, this is an awesome thread... I haven't seen one like this in a long time in any of the forums I'm a member of. I'm sure the question has been asked before, but is kinda hard reading through 270+ posts; have you guys nailed down this type of retrofitting for the 73-87 trucks? just wondering, thanks in advance, I love seeing people make their ingenuity flourish.
LS-K is offline   Reply With Quote
Old 03-06-2014, 01:13 AM   #272
ls1nova71
ls1nova71's Avatar
Haven't messed with a '73-'87, but then there's really no reason to since you can get the cluster out of a '88-90 Blazer or Suburban since they are the same and come with electric speedometers. The only real down side is that they are only 85mph speedos.
Old 03-06-2014, 08:03 AM   #273
elf w/capital T
that is such a good idea, i am excited to go to the yard soon just for this lol
Old 03-06-2014, 12:15 PM   #274
mcbassin
Still Learning
mcbassin's Avatar
Sorry if I missed it on here but is anyone using LED lamps instead of bulbs for the gauge back lighting? If yes, where are you getting them ? part numbers? thanks
mcbassin is offline   Reply With Quote
Old 03-10-2014, 08:45 PM   #275
elf w/capital T
plate and box still for sale?
