Old 11-21-2014, 10:14 PM   #251
ZouchaR
Re: My 63 Project
One of the challenges is redoing the wiring harness do to the turn signals in the hood. So those wires have to go through the firewall with the engine bundle.
ZouchaR is offline   Reply With Quote
Old 11-21-2014, 10:16 PM   #252
ZouchaR
Re: My 63 Project
I found this material that we call snake skin. It really cleans things up in my opinion.
Old 11-21-2014, 10:20 PM   #253
ZouchaR
Re: My 63 Project
This is the solution for removing the hood in the future. I put some "disconnects" in line.
Old 11-21-2014, 10:22 PM   #254
ZouchaR
Re: My 63 Project
This is my son helping with the routing of the wires. I took advantage of the old air mounting hardware.
Old 11-21-2014, 10:23 PM   #255
ZouchaR
Re: My 63 Project
If you look close, you can see the wireing inside the snake skin running along the inner fender well. It really does clean things up.
Old 11-21-2014, 10:27 PM   #256
ZouchaR
Re: My 63 Project
And after getting the engine bundle and the front end bundle and the hood bundle all in and dressed nicely... I realized that my park brake light wire was in the wrong bundle... OOPPSS... so I had to take most of this apart, but it wasn't too bad to correct it.
Pay attention to where your wires are before you start putting the snake skin on.. it's not fun trying to fish the wires through bundles that are all ready in snake skin and dressed up nice.
Old 11-22-2014, 02:05 AM   #257
ZouchaR
Re: My 63 Project
Well that test fit didnt go as well as I had hoped. These are the short headers that I have, with a little BFH work, they will fit. The long tube headers that I have were not even close. And these short headers have round ports. So that is a problem.
Old 11-22-2014, 02:06 AM   #258
ZouchaR
Re: My 63 Project
Drivers side with the short headers and they are indeed hitting my motor mount. The other side is just barely touching the frame.
Old 12-06-2014, 12:30 AM   #259
ZouchaR
Re: My 63 Project
Anyone got an easy way to fix this one??
Old 12-06-2014, 12:33 AM   #260
ZouchaR
Re: My 63 Project
As you may be able to see from the previous picture, the ignition switch hole has the knotch that keeps the switch cylinder from turning, the flat spot on the bottom of the hole has been destroyed. Now the cylinder wants to turn when I turn the key.
Any thoughts on an easy way to repair this one??
This picture shows the cylinder in the hole.
Old 12-23-2014, 07:47 PM   #261
ZouchaR
Re: My 63 Project
So I got the fuse panel installed.
Old 12-23-2014, 07:48 PM   #262
ZouchaR
Re: My 63 Project
Dim
Old 12-23-2014, 07:49 PM   #263
ZouchaR
Re: My 63 Project
And Bright
Old 12-24-2014, 12:02 AM   #264
Monte's62
Re: My 63 Project
Man, I'm enjoying your build and I can't believe how little rust you have. One pinhole, WOW. Good luck on the rest of the build and I'm subscribed.
Monte's62 is offline   Reply With Quote
Old 12-24-2014, 12:15 AM   #265
Joe Pass
Joe Pass's Avatar
Re: My 63 Project
You can repair your ignition hole by getting some seals/washers (like oil drains plug gaskets) only larger. place one in the back and one under the bezel to sandwich it in.
These washers are available in many diameters and are used to seal fitting and plugs. I have some in soft aluminum and I would think they should form in to the front recess.
Something like these....http://www.summitracing.com/parts/fra-999218/overview/
Joe Pass is offline   Reply With Quote
Old 12-24-2014, 12:40 AM   #266
ZouchaR
Re: My 63 Project
So the way that I repaired it, and I didn't take pictures, I cut a two inch piece of steel and then cut a 1 inch circle inside that. Then I brazed a piece of flat steel on one side to create the flat notch. Then I shaved it down so that it fit into the cutout. Cranked the bezel down and it worked.
Old 03-16-2015, 09:00 PM   #267
ZouchaR
Re: My 63 Project
I am still working on wiring.... still working on brake lines... and having a huge issue...
For some reason, I can not get my brake lines to flare correctly. I have watched about 20 videos... looked at several web sites... followed all of the instructions.. and I just can NOT seem to get my brake lines to flare. And it's not my brake line tools, I am already on the second set. Anyone have any thoughts???
Old 03-17-2015, 12:27 PM   #268
Vics63Chevy
Vics63Chevy's Avatar
Re: My 63 Project
Don't have a suggestion unfortunately but just want to say you got a sweet build going
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
Old 03-18-2015, 08:16 PM   #269
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: My 63 Project
Nice, but I ran all of my front wiring underneath the ridge of the inner fender inside of a piece of nylon air hose, so that no wires or conduit are showing, and unless you take the front tire off, there is no way to even see it....you could probably re-route yours...again...LOL! just kidding!
Modges'66 is offline   Reply With Quote
Old 03-31-2015, 09:16 PM   #270
ZouchaR
Re: My 63 Project
Ordered these today.
Old 03-31-2015, 09:17 PM   #271
ZouchaR
Re: My 63 Project
And a quick shot of the rear tires.
Old 03-31-2015, 09:30 PM   #272
ZouchaR
Re: My 63 Project
I have a question for my followers... The radiator that I pickup up is Aluminum 3 core from a 55 thru 59 Chevy...
It's too tall to put in using the saddles, and it has flanges for mounting flat against the radiator support...
But the height is such that if I don't pull the lower cross member under the radiator, it will not fit...
A friend of mine used this radiator with success and pulled that crossmember...
Any thoughts????
Old 03-31-2015, 09:37 PM   #273
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Re: My 63 Project
Can't help with the radiator, but I can say that's a nice set of rims you ordered. lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-01-2015, 08:12 AM   #274
Nacho_Paras N.L.
Re: My 63 Project
Great Build!! Love the LED parking lights!! One suggestion, paint the master cylinder!! I have the same one from CPP and made the mistake of not painting it. Now it is rusted. I'm going to have to take it back out sand and paint. Unless ofcourse you did paint it silver..
Nacho_Paras N.L. is offline   Reply With Quote
Old 04-01-2015, 06:49 PM   #275
ZouchaR
Re: My 63 Project
Today was about getting the radiator installed.
