Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-20-2014, 10:33 PM   #251
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: Attempting my first build 72 K5
Originally Posted by IronCanine View Post
I was disappointed to here this Mike. I ordered a set of black ones that got here yesterday just because I saw yours on your build thread. I can't imagine there's any more space behind a 15x6 steelie. Guess it's back to a stock single piston.
Yes, very disappointing. Even on Wilwood site, it says the D52 will fit 70 and up K5 blazers 4x4. I think Wilwood, along with other aftermarket companies, stop bundling parts for our Blazer's with C10's, K10's, suburbans, etc etc
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 11-22-2014, 12:49 AM   #252
mx289
mx289's Avatar
Originally Posted by 72K5CSTDarkOlive View Post
Thanks MX289
I tired to looking for the wood veneer tape on 3M's site, but their search bar sucks. Could you send me a link?
I honestly forget where I seen it.
I think it was a online wood veneer supplier for furniture ,cabinets.I will try to find it again.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 11-22-2014, 08:49 PM   #253
IronCanine
I'm trying....
IronCanine's Avatar
Question - do the doors on our trucks separate or was this cut?
Attachment 1323915
Sorry I missed this post Mike. Like the rest of the truck, the doors were made out of pieces of stamped metal, but here, the outside is cut off so a repair panel/skin can be welded to replace the damaged section.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 01-08-2015, 06:10 PM   #254
72K5CSTDarkOlive
I have finally figured out the modifications the PO (original owner) did to install the 36 gallon gas tank.
1. He removed the rear cross-member that has the 2 fuel lines going across the top of it.
2. He tack welded threaded nuts to the inside bottom of the frame rail so he could hold the tank with the straps that where on there.
3. He welded a cross bar going from the 2nd to last body mounts to compensate for the loss in reinforcement for removing the original rear cross member that sits in between the frame rails.
I cut off the threaded nuts using a sawzaw and dremel. Now I have to figure out a solution for the cross bar that welded to the body mounts.
If you're wondering why the 2nd to last body mounts are removed from the frame is because this part was riveted to the body so we had to cut them to get the body off the frame.
1. Do I try cutting it off?
2. Find some replacements and rivet or bolt on new (used) one on? Anybody know where I could find a set?
Old 01-08-2015, 06:19 PM   #255
72K5CSTDarkOlive
Threaded nuts that where welded to the inside of the frame rails on each side. There was a total of 4
Old 01-08-2015, 06:19 PM   #256
72K5CSTDarkOlive
Pics this time
Old 01-08-2015, 06:31 PM   #257
IronCanine
I'm trying....
IronCanine's Avatar
I have finally figured out the modifications the PO (original owner) did to install the 36 gallon gas tank....
For the level of build you're doing, I'd vote to put it back like it came...and I think you could with not too much effort. My frame was hacked on and cracked. We had to do a fair amount of prep work on it too. Attached is a pick of the frame I bought my exhaust hanger off of. The whole frame is for sale for $500. I called and asked if he'd sell me the hanger...and he didn't blink. Might be worth a call to see if he'd take off your pieces too. Also, member Uncle had a 72 frame for sale/part out forever. It was very rusty, but that cross member might be workable if he's still got it.
Here's the website with the frame for sale (just scroll down when you get there):
http://www.billstruckshop.com/67-72used.html
Old 01-08-2015, 06:49 PM   #258
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I'd replace the missing OEM support with grade 8 bolts and thread loctite and call it a day. I need to look and see what if any work was done to install the Hickey tank in my Blazer.
Old 01-08-2015, 07:24 PM   #259
72K5CSTDarkOlive
I did source an original cross member from a pickup that will fit exactly the same. If he could sell me just the hangers that would make everything a lot easier.. I'll give him a call and see what he says.
Old 01-08-2015, 09:10 PM   #260
sockalaminski
Looking like progress brother. I'd go with the suggestion of putting it back the way it came from the factory also.
sockalaminski is offline   Reply With Quote
Old 01-09-2015, 05:05 AM   #261
72K5CSTDarkOlive
Sockalaminski - Agree 100%..
Old 01-09-2015, 10:31 AM   #262
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Me too. 100%
Tom Vogel is offline   Reply With Quote
Old 01-30-2015, 09:14 PM   #263
SeventyOne
I know you got an update worthy of pics - let's see em!
SeventyOne is offline   Reply With Quote
Old 02-04-2015, 07:52 PM   #264
72K5CSTDarkOlive
It's been a while so I thought I would update with a few more progress pics.
The PO made some modifications to the frame that required some minor work to put this back to its stock form.
First was the custom tow hitch that was welded to the outside of both sides of the frameName:  frame 14.jpg
He also made some bad drill holes on the top side of the frame, so I patched that up to make it look decent enough. I'm not even sure if there is supposed to be a hole there or not.
The rear cross member was drilled out to compensate for the larger gas tank and he welded a cross bar to the hangers for the body mounts. I cut that off using a sawzall. Then I cut the rest of cross bar as close as I could to the hangers off and then finished it off with an angle grinder and flap disc to smooth it down.
Old 02-04-2015, 07:54 PM   #265
72K5CSTDarkOlive
managed to save the hangers and then drilled out the rivets.
Old 02-04-2015, 07:57 PM   #266
72K5CSTDarkOlive
Thanks to Seventy one who came over and helped me tack weld this piece of the front leaf spring where I accidentally cut into when I had to cut out the spacer that wouldn't budge when removing the leaf springs
Old 02-04-2015, 08:01 PM   #267
72K5CSTDarkOlive
I absolutely hated the look of the painted front end of the frame and front axle..So I had them powder coated to match everything else.
Old 02-04-2015, 08:03 PM   #268
72K5CSTDarkOlive
more close up shots
Old 02-04-2015, 10:04 PM   #269
IronCanine
I'm trying....
IronCanine's Avatar
Mike that looks great!!!!
Old 02-04-2015, 10:24 PM   #270
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Nice!
Old 02-04-2015, 11:58 PM   #271
SeventyOne
Awesome! Powder coat is the best.
Hopefully the areas we worked on look like they were never messed with now that it's coated.
Old 02-05-2015, 01:23 PM   #272
1956cameo
1956cameo's Avatar
Great build! Way back on page one you were asking about the heater core and where you could get a replacement because LMC didn't carry it. The Truck Shop in Orange, California sells new ones. They are $59 if I'm not mistaken.
I don't always drive trucks; but when I do I prefer Chevy's. Stay driving my friends.
'72 blazer 2wd build
67-72 Factory Big Block Registry
1956cameo is offline   Reply With Quote
Old 02-05-2015, 08:27 PM   #273
72K5CSTDarkOlive
Thanks guys!
Cameo - I think I'm going to just have mine refurbished. I've been talking to the guys at Classic Auto Air
Old 02-05-2015, 09:06 PM   #274
1956cameo
1956cameo's Avatar
Probably a smart move. I am sure they will make it better than the new Chinese reproduction stuff.
Old 02-06-2015, 06:17 AM   #275
tristan
I now have a bad case of frame envy - just beautiful.
tristan is offline   Reply With Quote
