Old 11-03-2019, 10:30 AM   #251
moregrip
moregrip's Avatar
Re: My 86 build
great work! You're extremely talented!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 11-03-2019, 11:23 AM   #252
TKCR
TKCR's Avatar
Re: My 86 build
Thank you! I never thought of myself being talented, just OCD
Old 11-04-2019, 02:06 PM   #253
TKCR
TKCR's Avatar
Re: My 86 build
Got the Lower Door Panel Carpets done. Put the stainless steel trim on. Dyed the vents Charcoal.
Old 11-09-2019, 09:53 AM   #254
TKCR
TKCR's Avatar
Re: My 86 build
Got the Buckle center belts in. The belts I found were in really nice shape, other than this frayed section. So I cut it off, since it was close to the end, and sewed it back up. That repair is done and all the belts are mounted in the truck.
Old 11-11-2019, 02:33 PM   #255
TKCR
TKCR's Avatar
Re: My 86 build
This has been a long time coming, finally got my Jack & Tools mounted, along with a new sticker.
Old 11-11-2019, 09:34 PM   #256
TKCR
TKCR's Avatar
Re: My 86 build
My Door Panels arrived this weekend. But before I install them, I知 going to replace my door pins & bushings. I知 waiting on a few tools to help aid with the removal of the pins, and the other tool helps with the placement of the bushing.
Old 11-13-2019, 07:08 PM   #257
TKCR
TKCR's Avatar
Re: My 86 build
So the other day, when I installed the Jack Tools where they are mounted on the right side engine room, I noticed the battery try was looking a bit shabby. So I removed it, and I知 going to sandblast it and repaint it, along with the bolts.
Old 11-13-2019, 10:03 PM   #258
nlped
nlped's Avatar
Re: My 86 build
Yep, I did the exact same thing on Belushi.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-14-2019, 08:58 PM   #259
TKCR
TKCR's Avatar
Re: My 86 build
Since I have the tray out, I found a bolt missing, the lower radiator support to the inner fender. Shame Shame😮
Old 11-15-2019, 11:36 PM   #260
superdav
Re: My 86 build
where did you find the stickers? nice truck btw
superdav is offline   Reply With Quote
Old 11-15-2019, 11:57 PM   #261
TKCR
TKCR's Avatar
Re: My 86 build
Well I went to get the receipt to find out, because I致e had the sticker in an envelope for several years. And I just got it out the other day, and the receipt was with it. I must have mistakenly thrown it away, because I can稚 find it now.
Old 11-17-2019, 04:47 PM   #262
TKCR
TKCR's Avatar
Re: My 86 build
Had decent day out, so I sandblasted the Tray and Bolts. Spray the tray with undercoating, since it looked like that痴 what was on it already. Also got a tray mat and new positive connection. I would like to find an original looking, but this will do until then. All back together!!
Old 11-17-2019, 11:19 PM   #263
superdav
Re: My 86 build
10-4 if you happen to remember please let me know
Old 11-17-2019, 11:27 PM   #264
TKCR
TKCR's Avatar
Re: My 86 build
Or if I find the paper, I know I have just misplaced it. I keep everything for my truck.
Update:I found a part # 15594820
https://www.ebay.com/itm/1985-86-CHE...4AAOSwlgJdDnzA
Old 11-19-2019, 08:49 PM   #265
TKCR
TKCR's Avatar
Re: My 86 build
Changing out the pins & bushings on the doors. The PO seemed to think it was easier to tack weld the pins to the bottom of the hinge bracket, rather than just put back the C-clip! My brother came up to help, we ended up taking the door off by unbolting the hinge brackets. That gave us a little more room to use a Dremel and grind off the welds. Several hours later, we finally got the pins out!! Well, one door that is! While the door is off, I知 going to clean up the door jamb and do some spray paint touch ups. Another day we will reinstall the door and start the process over again, with the other door. 🥵
Old 11-20-2019, 08:27 AM   #266
rgunlock
rgunlock's Avatar
Re: My 86 build
That's too bad about changing your pins and bushings turning out to be such a challenge, but the engine bay is looking great with the refreshed battery tray and tire tools!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 11-20-2019, 11:39 AM   #267
GRAY GOOSE
Re: My 86 build
Where did you get your door panels? I am looking for a set of original door panels for my 83. I don't mide if the are not new. I can redo them.
GRAY GOOSE is offline   Reply With Quote
Old 11-20-2019, 12:21 PM   #268
TKCR
TKCR's Avatar
Re: My 86 build
USA1 Industries. They are new
Old 11-20-2019, 01:20 PM   #269
GRAY GOOSE
Re: My 86 build
Thanks so much. I will take a look.
Old 11-22-2019, 04:44 PM   #270
GRAY GOOSE
Re: My 86 build
Look good....Time to start saving my pennies!!!!
Old 11-22-2019, 09:11 PM   #271
TKCR
TKCR's Avatar
Re: My 86 build
I think I知 going to just replace the entire hinges. I was thinking they may be bent. The PO was using a lot of shims. So I ordered some just to compare them with mine, and I think there is a chance that they are bent. I知 not crazy about using aftermarket hinges, but they seem well made and identical to the OEM.
Old 11-22-2019, 09:17 PM   #272
TKCR
TKCR's Avatar
Re: My 86 build
While I was waiting on the new hinges to arrive from Classic Parts, I changed out the SPID in the glove box. I have only had this for about 3-4 yrs. I had it made primarily to change the interior color, from Burgundy to Charcoal, since that’s what I did with the interior. Had the SPID made here: http://outintheshop.com/2.html
Old 11-25-2019, 04:48 PM   #273
TKCR
TKCR's Avatar
Re: My 86 build
Got the hinges sandblasted just enough to etch them. Primed and then paint.
Old 11-25-2019, 05:36 PM   #274
GRAY GOOSE
Re: My 86 build
Nice.. Let us know how they work once installed.
Old 11-25-2019, 05:40 PM   #275
TKCR
TKCR's Avatar
Re: My 86 build
Thank you. I will. I知 anxious to get this door back on, and see how everything lines up.
