10-14-2016, 07:18 PM | #251 |
Re: Ian's Tennessee Honey '64 Short Box Step-side - England
That tin worm gets every we're don't know what I'm gonna find when I start mine.
Great progress |
10-15-2016, 11:26 AM | #252 | |
This bracket bolts to the top of the fender and actually looked great until I hit it with a wire brush, nothing else for it, I had to make one. The tin worm in the L bracket that holds the fender seal was a little easier to spot had to make one of these too Thing is they're not flat, but luckily for me the one part that hadn't completely disintergrated was the shaped part, which gave me something to use as a pattern. Came out Ok in the end
Getting old sucks.............but it sure beats the alternative |
10-15-2016, 01:55 PM | #253 |
I had the same with my rear fenders along the bottom edges,
I did fix them but there is some filler in them so didn't strip them all the way back until I rebuild the old girl fab work looks good i am sure I will be doing Some of that lol |
10-15-2016, 07:03 PM | #254 |
Nice job fabricating those parts Ian. Probably fit better than repops and cost you less
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
10-19-2016, 01:26 PM | #255 | |
Before I refit the fender I'll have to fit fresh seals. The original seals are stapled in place. I discovered that the factory staples have exactly the same pitch as T50 staples that you would use for upholstery DIT and the like. I don't have a staple gun man enough to punch through steel, but I had a cunning plan I glued the new rubber seals to the steel mounting plates with a contact adhesive (I would not recomend this as it reacts with the paint ) Luckily it's hidden under the seal Then using the original staple holes ran a 1/16" drill through the new rubber seal. After that it was a simple job to push some new staples throught both steel and rubber and clench them over with a paralell punch. Before and after
10-19-2016, 02:03 PM | #256 |
I could find a match for the original clips to mount the fender seal here in the UK so I used these "fir tree" clips.
Because they're a paralell clip you have to enlarge the holes on the seal bracket to the same size as the ones in the fender support (from 5/16" to 3/8") They're a tight fit so you'll need a mallet to tap them in And they're plastic so no rust issues
12-03-2016, 03:48 AM | #257 |
A quick progress update, (well probably about 4 updates back to back )
I have now finished the passenger side floor repairs so while painting the fender seal bracket I gave it a quick coat of body colour. I trial fitted the fender which still fits well, before beginning the door repairs. First job on the door was the rear corner, the blasting revealed a couple of holes but the door seams were good so I only removed the rusted area preserving as much of the original door (and door profile) as possible.
Getting old sucks.............but it sure beats the alternative Last edited by ibrown50; 12-03-2016 at 04:00 AM. |
12-03-2016, 03:54 AM | #258 |
The front skin needed a small repair too
The front corner proved to be a little worse, with the rust extending into the hinge area and beyond the area covered by the repair panel. I had a full door bottom but decided to only use a small section as the rest of the door bottom is in good shape.
12-03-2016, 04:00 AM | #259 |
I made the upper section which turned out ok.
12-03-2016, 04:05 AM | #260 |
The next job was the speaker hole, Don had given Rian a section from one of his old doors to use as a repair panel luckily for me (thank you gentlemen) the panel came with the door.
I have to say getting it lined up was just about the most “fiddly” job I’ve ever done It’s still not finished but this is what it looks like at the moment,
12-03-2016, 05:33 AM | #261 |
Ian, I have to admire your skills and problem solving solutions when parts just are'nt available off the shelf
12-03-2016, 07:21 AM | #262 |
Just taking my rear brakes apart. First time on the truck in a while.
That is a massive amount of time and progress Ian. Well done. I still have a hole to correct on my drivers door, and suspect I will find as much rust and damage to repair. I know my rear bed panel has up to 10mm of filler...... Really good to speak with you yesterday as well.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
12-03-2016, 07:23 AM | #263 |
Great work mate! Glad I could be a contributor even in a roundabout way...
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
12-03-2016, 06:25 PM | #264 |
Looking good Ian lots of progress dreading what I will find when I pull mine apart got some holes in the same places
12-03-2016, 06:44 PM | #265 |
Nice work Ian. Your getting there.
Beginning to wish id done what your doing rather than take the easy way and reksin and whole bottoms. May have needed less filling and sanding!!! |
12-04-2016, 05:07 AM | #266 | ||||
Thanks Bill, I still have a fair bit of filling and sanding to look forward too, I've tried all different sorts of filler and tools but it's hard work no matter what you do
12-12-2016, 07:46 PM | #267 |
Nice job on the doors Ian . The floor looks great . You'll have it back on the road soon at this rate .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST MY BUILD THREAD: http://67-72chevytrucks.com/vboard/s...d.php?t=611614 |
12-30-2016, 04:59 PM | #268 |
The following post is definitely the most pictures for the least amount of time spent on a job I have posted so far
I am still doing repairs to the passenger door, one of the little jobs that needed doing was to replace the captive nuts that hold the inner door panel in place. A common fault on our trucks, some of the screws had rusted in place and had to be drilled out to remove the panel. Now your probably thinking 1/4" x 20 unc captive nuts.... no big deal, well in Europe they are a lot less easily available than you may think, we're all metric over here .....(I blame the French it's all their fault ) This whole job took 20 minutes start to finish and was done with stuff I had lying around so cost $0.00. I started with a piece of 1" x 1/4" flat stock marked at 3/8" and centre punched, Drilled out to 0.2" I then ground a step on each side (using a 24 grit disc) leaving a 3/8 raised section down the centre and then cut it into 3/8 "strips"
12-30-2016, 05:02 PM | #269 |
these were then tapped to 1/4" x 20
I was originally going to spot weld these in place but decided JB Weld would do the job A little dab on each end and "presto" So 20 minutes later another job ticked of the list
12-30-2016, 05:50 PM | #270 |
Got any Spares?
12-30-2016, 06:54 PM | #271 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Very clever work!
a few of mine had twisted out on disassembly, but I only needed to run a tap through them & epoxy them back into place. Ingenuity at its finest!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
12-31-2016, 03:03 AM | #272 |
Thanks for sharing Ian.
I had a few of mine self destruct, despite my most gentle effort Will most certainly remember this post when I get to this point.
01-08-2017, 03:43 PM | #273 | ||
Not at the minute but I'm sure to be making some more how many do you need ?
Today I had a couple of hours of truck time, so decided to tackle something that’s been on my “to do” list for a while. It was one of those jobs that you know is just going to end up bigger than it looks. The truck had a few bubbles on the top of the passenger side B pillar, which turned out to be holes Which turned out to be a bit of a “tin worm” infestation. Nothing else for it keep cutiing until you find good metal I folded the inner piece first which was tacked and then finish welded. Welding under the gutter was tricky, I after ginding the weld to blend it into the gutter I found a couple of holes, access wearing my welding helmet was arkward so I ended finishing the welds using the position the torch, close your eyes, pull the trigger method. Please don't mix up the steps as I did once, you'll find position the torch, pull the trigger (forget to) close your eyes, will leave you blind for a good 10 minutes
01-08-2017, 03:45 PM | #274 |
Did the same for the outer piece, I include a few “spot weld” holes so that the finished repair will match,
I got it to here ………….and then ran out of gas
01-08-2017, 04:15 PM | #275 |
Looking good Ian. I love how a paint bubble ends up being a 2 inch hole by the time you find something to weld to
