Old 07-30-2017, 01:11 PM   #251
ChuckLee
Re: 71 C10 6.0 LS ground up build
Amen to that! Even if you're short, the other person driving may need the leg room. Those are super nice for the limited space you had to deal with.
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 07-31-2017, 12:25 AM   #252
Jason7121
Jason7121's Avatar
Thanks chucklee I'm happy with them shouldn't effect leg room either.
Jason7121 is offline   Reply With Quote
Old 08-05-2017, 12:11 AM   #253
sprint_9
sprint_9's Avatar
Sound system looks excellent, subwoofer box really turned out nice with the vinyl wrap.
sprint_9 is offline   Reply With Quote
Old 08-05-2017, 12:29 AM   #254
Jason7121
Jason7121's Avatar
Thanks I'm happy with how it turned out.
Old 08-12-2017, 02:36 AM   #255
Jason7121
Jason7121's Avatar
Having issues with the Tmi door panels like mentioned in previous post. The lock knob holes in door panel won't line up perfectly and knob gets stuck. Door lock motors won't pull knob down or up. I enlarged the hole in both panels and ordered billet knobs in hopes that there thinner than the plastic knobs.
Old 08-12-2017, 11:29 AM   #256
meenaggie
I sent you a PM. The billet door lock pulls are generally larger in diameter than the plastic OEM ones. At least that was the case for the Ring Brother ones I ordered. The Ring Brothers door lock pulls would not even go in the original hole in the metal door skin.
meenaggie is offline   Reply With Quote
Old 08-22-2017, 03:41 PM   #257
Jason7121
Jason7121's Avatar
Finally got my tmi seat and door panels installed. Had fitment issues with door panels and tmi stopped returning calls and emails. I used smaller biller lock knob and biller inside handels to get it all to work properly. Anyway hers a few pictures. Also got my radiator cover done. Painted it body color and pUT stainless mesh being it.
Old 08-22-2017, 05:04 PM   #258
lowrodderchev
lowrodderchev's Avatar
looking good cant wait to see it on the road
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 08-22-2017, 07:18 PM   #259
builtbyKane
builtbyKane's Avatar
That is all looking amazing.
builtbyKane is offline   Reply With Quote
Old 08-23-2017, 05:39 AM   #260
rob32472
Looks fantastic! I will be installing A TMI interior as well, what exactly were your issues?
rob32472 is offline   Reply With Quote
Old 08-23-2017, 09:58 AM   #261
Jason7121
Jason7121's Avatar
Main issue was where door panel fits around lock knob hole. Had to drill out hole in door so knob would align. Also grind hole in panel larger. Had to drill holes in panel around inside door handel and install trim screw to hold panel tight against door.
Old 09-15-2017, 12:35 AM   #262
Jason7121
Jason7121's Avatar
Decided to take off the vacuum booster and master cylinder and install a hydroboost system from Cpp. I flipped the hydroboost over so all fittings and hoses are on bottom side .
Old 09-16-2017, 10:55 PM   #263
sprint_9
sprint_9's Avatar
Looks clean.
Quick question, Im in the process of filling holes in my firewall, what are the two wires you have coming out above your main fuse block connection? I was going to fill all those smooth but Im kind of running in the dark with what holes I should fill and keep or re-purpose to another use.
Old 09-16-2017, 11:45 PM   #264
Jason7121
Jason7121's Avatar
I used those for the drive by wire throttle pedal wires and also cruise control.
Old 09-17-2017, 01:04 AM   #265
sprint_9
sprint_9's Avatar
Cool, thank you for the info.
Old 09-17-2017, 01:37 AM   #266
Jason7121
Jason7121's Avatar
No problem can't wait to see your build come to life.
Old 10-01-2017, 12:27 AM   #267
Jason7121
Jason7121's Avatar
Been driving the truck here and there and working out small issues. Ended up putting some beltech sport shocks on it the kyb shocks were a little to bouncy. Put it up on the lift today and inspected everything. Got all the dust off underneath as well. Had alignment set this week also.
Old 10-01-2017, 12:39 AM   #268
lowrodderchev
Looking good glad its on the road finally
Old 10-01-2017, 12:49 AM   #269
sprint_9
sprint_9's Avatar
Thats one nice looking undercarriage.
Old 10-01-2017, 11:45 AM   #270
Jason7121
Jason7121's Avatar
Thanks guys appreciate the feedback
Old 11-13-2017, 11:04 PM   #271
Jason7121
Jason7121's Avatar
Decided to install a quick performance Ford 9" rear axle with 3.70 gears and wilwood disc brakes to match the front ones.
Old 11-13-2017, 11:19 PM   #272
builtbyKane
Oh man that looks sweet.
Old 11-15-2017, 09:49 PM   #273
jeh
jeh's Avatar
Sweet looking truck, the interior looks great!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 11-16-2017, 01:40 AM   #274
Jason7121
Jason7121's Avatar
Thanks jeh appreciate it.
Old 11-16-2017, 10:12 AM   #275
Ilikepie
Truck looks great. Do you have any pictures of the throttle pedal install?
Ilikepie is offline   Reply With Quote
