Closed Thread
Old 09-25-2011, 03:46 PM   #2851
Shyguy
Junior Member
Shyguy's Avatar
Re: What did you do to your truck today!
Stopped by my son's house and we did a little work on the '67 swb. Had to stop early so he and his wife could go buy a new clothes drier.
He got the front cab support slip-ons fitted and welded while I scrapped the sealer out of the drip rail and removed the old door seals. Then we took the windshield and rear window out. The gaskets appeared to be original, so it took a lot of cutting of them to get the window and windshield out. I almost forgot we took the doors off since we finished the outer rockers and they were just in the way. We will be using different doors.
The more work we do on the cab the more rust we find that needs to be repaired, it seems. Oh well it is ok, that way my son and I will be able to spend more time together.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 09-25-2011, 05:02 PM   #2852
aintmisbehavinn
Installed my Level 3 700R4, what a difference. Should have done this long ago. Love the 2000 stall and overdrive. Going to take a while to get used to this...
aintmisbehavinn is offline
Old 09-25-2011, 05:33 PM   #2853
scooterskoolkustoms
scooterskoolkustoms's Avatar
I put disc brakes on the rear of the burb today now just need to buy new hoses to hook them up
big old burb in primer.lot of work to do.
scooterskoolkustoms is offline
Old 09-25-2011, 06:25 PM   #2854
Big Block
Big Block
Big Block's Avatar
I don't post much on this part of the board, mostly on the 69-72 Blazer side. But I finely put shocks on my 1970 GMC. It still had the original ones on it. Well at 72,000 miles and 41 years I guess it was time for new ones! You old timers know what the original shocks look like, but you young guys may not. Here is a picture of the original shocks. Here is a original T-3 head light I had to replace while I was working on it. Sorry, it's bad picture of the T-3. (the flash was on when I took the picture) You can barely make it out the T-3 in the center of the blub. It rides a lot better with the new shocks but it still needs sway bar up front. I have one ready to go on but that will be project for another day.
Big Block is offline
Old 09-25-2011, 06:39 PM   #2855
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
Cut the nasty Aux fuel tanks off of my truck today. Looking forward to working on my new to me AC cab.
Never argue with an idiot, they will bring you to their level and beat you with experience..
indianbullet is offline
Old 09-25-2011, 06:58 PM   #2856
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Been workin on getting the new rear bed piece welded on what a pain in the arse.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 09-25-2011, 08:00 PM   #2857
hayhauler71
hayhauler71's Avatar
Me and my 11 year old daughter took the 71 to the cemetery to visit some long lost friends as we sat there in the sun I could not believe how many people stopped and looked at the truck. I probably had more views there than at the car shows
Fuzzy
hayhauler71 is offline
Old 09-25-2011, 09:19 PM   #2858
willys72fleetside
willys72fleetside's Avatar
Got the buffing done, now looking foward the the next step. Still not sure what thats going to be.
A USED TRUCK IS A LOVED TRUCK!
willys72fleetside is offline
Old 09-25-2011, 09:27 PM   #2859
litew8
litew8's Avatar
Not that old and mine has the originals too! (not for long) Actually, someone a little older than me told me they were original spirals.
project: "my happy mess"
litew8 is offline
Old 09-25-2011, 09:29 PM   #2860
litew8
litew8's Avatar
Is that medium bronze willy?
litew8 is offline
Old 09-25-2011, 09:47 PM   #2861
67Slider
67Slider's Avatar
Installed the remote starter solenoid to combat the heat soak starter issue I have been having. Cost about 30 bucks. Now I'm gonna have to drive it on a couple of hot days to see if it is fixed.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2011, 09:51 PM   #2862
Big Block
Big Block
Big Block's Avatar
You are correct they were used on all GM cars and trucks during the 60's thur early 70's.
Old 09-25-2011, 10:09 PM   #2863
ryanroo
ryanroo's Avatar
removed the steering box, removed the transfer case. turns out that ignorant youth makes it alot easier to remove a 205 by yourself. when did they get so heavy? it used to be easier.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline
Old 09-25-2011, 10:33 PM   #2864
RossRinSD
RossRinSD's Avatar
I've got to do something about mine, too. I considered just putting a new starter in. Is it just the heat in the solenoid that caused that? When mine does it, it sounds like the battery is almost dead, the starter barely turns over. I usually bump the key over to start a couple of times until it turns freely. At least the truck is warmed up and it'll start right away when it does that.
Where did you pick up your remote solenoid, and you'll have to let me know how it works.
RossRinSD is offline
Old 09-25-2011, 10:43 PM   #2865
RossRinSD
RossRinSD's Avatar
Didn't get a ton of work done today, had to fix a lawnmower for my dad, and promptly busted a sprinkler head testing it out...
I mounted the winch box and tested the winch out and stretched out my cable. I got a little done on the mockup, but I'm not sure which way to proceed just yet...
Old 09-25-2011, 10:49 PM   #2866
TRC911
put a delta toolbox on, a weatherguard headache rack, and some eagle eye off road lights.
TRC911 is offline
Old 09-25-2011, 10:56 PM   #2867
Bull72
Bull72's Avatar
Originally Posted by Tmwoodall View Post
Installed this. This is just a dress rehearsal, push rods get here tomorrow then I can bolt down the intake, carb, etc.
Tmwoodall dude this looks freaking sweet! After a while (when i get more money of course) I'm going to put a similar setup in front of my 355 as well.
Thank you god for all your blessings!
My mini build (I had a great starting point)
http://67-72chevytrucks.com/vboard/s...d.php?t=440743
Bull72 is offline
Old 09-25-2011, 11:00 PM   #2868
Bull72
Bull72's Avatar
Originally Posted by doubleb's69 View Post
Pinstriped my glove box door. I was bored so what the heck. The blue was a litttle over reduced. Oh well.
Nice work, if I could pinstripe like you, I would do the same thing all over my truck
Bull72 is offline
Old 09-25-2011, 11:04 PM   #2869
67Slider
67Slider's Avatar
When I get heat soak my starter will do nothing. Dash lights will come on, no click, nothing. Bumping didn't get it either. I put a heat shield on early this summer and hadn't had any problems until last Thursday. If this doesn't solve it I will keep the solenoid setup but install a mini starter next.
The solenoid was 14 bucks at Autozone. I will keep ya posted on it
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-25-2011, 11:28 PM   #2870
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
After we got the front clip on yesterday, I couldn't help myself. Even tho it was Sunday, I had to go over to the shop to check it out. Well, I came dragging a$$ home five hours later after fixing some stuff..
....finding out what I needed to re-do, and then doing some wiring.
More cracks in the old brake lines. LMC gets another $150 for ss lines..... I bent one myself (to the back...it's not leaking). Gotta make a new hard line for the fuel pump to the filter. It got "nastied" from the install of the front...
hung up on the passenger side (of course) inner. Both trans lines had to be re-bent. They would have scraped the harmonic balancer until...well, more leaking river of trans fluid. The top rad. hose is 5" too short.
I'll look for something.....That kind of stuff happens, 'eh?
My friend is making a plate for the firewall for the Vintage Air/Heater inlet/outlets. Design is under way.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 09-25-2011, 11:28 PM   #2871
DJMAN
DJMAN's Avatar
Romoved front clip, glass and interior. How do I remove key bezel without key? Also many of these parts will be going up for sale....and complete AC.
Why does this cab have a high hump?
DJMAN is offline
Old 09-26-2011, 12:11 AM   #2872
dmxxpert
dmxxpert's Avatar
Started our budget emblem restoration.
Steel Wool + Patience = Shiny
Patience + Paint = Not too bad!
I am thrilled with how the first one turned out.
They are not perfect, some are pitted worse than others,
but for a driver they are gonna make a hige difference.
Thanks for listening,
Jeremy
dmxxpert is offline
Old 10-01-2011, 07:15 PM   #2873
Slick67
Sofa King Crazy!!
Slick67's Avatar
Cleaned my frame, waxed the engine bay, stuck my bike in the back and finally talked my girlfreind into sitting in it, then I couldn't pry her out with a crowbar.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline
Old 10-01-2011, 08:40 PM   #2874
big_al_71
big_al_71's Avatar
Originally Posted by red71c10 View Post
I notice your tailgate doesn't have the lower molding. Is that by choice or was it always that way? I'm asking because I just got a used tailgate for my truck and it has holes for the upper molding but not the lower. I always thought it was all or nothing.
my truck is a plain c10 so I added all the moldings on there, I also noticed that there is a lower molding all the way at the bottom but decided not to buy it for now who knows I may get it in the future.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline
Old 10-01-2011, 09:23 PM   #2875
longbed67
longbed67's Avatar
Pulled the engine, trans, tore down the engine, speced the parts, and took parts to the machine shop. Next week I'm picking up the disc brakes new rear end and a sport bumper!
longbed67 is offline
Closed Thread
