Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 04-16-2018, 05:18 PM   #2926
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by zicc1835 View Post
Thanks Jim May take the easy way out this go around use what’s there ..will see I won’t need an excuse to to take an ride out for a visit when weather finally turns
Always welcome Jess, might be some other parts around here you can use,MSC 6A1, FAST Dual Sync distributor
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-18-2018, 10:51 AM   #2927
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/26e9jkb]20180418_104435
[url=https://flic.kr/p/Ja8hRQ]20180418_104540
sides look alittle bulky, will have to machine some slots or trapazoids
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2018, 12:13 PM   #2928
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
ill give you a warning beforei head out hoping for a nice sunny day......
zicc1835 is offline   Reply With Quote
Old 04-18-2018, 04:19 PM   #2929
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Do you need my cell number?
SAFETY FIRST
AS usual, off topic
Jim
Old 04-18-2018, 08:48 PM   #2930
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
Thanks Jim.....just looked thru my contacts thought i may have had it from my visit please PM to me ill lock it in and PM mine back....
Old 04-23-2018, 01:30 PM   #2931
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Started to work on my harness, found out there is a late and early version of harness, so my TPS and IAC connecters are wrong, plus location with in connecters. Wiring diagram shows this.
While I was working on the harness, found out I was putting the seal on wrong, so, I cut the tabs shorter, maybe a 1/16" or 1/8" and wrapped the tabs around the wire, then slid the seal on, much easier then trying to crimp the seal, as I would cut the seal. Having the right crimper also made the job easier. I like to pre-crimp with a larger size and then do a final crimp. I may go back and solder.
Also, having the right pin tools, is a must, can't remove without releasing lock on the pins
[url=https://flic.kr/p/26oYwbW]20180423_120857
sorry no pics of late style connecter, as I destroyed it on removal
SAFETY FIRST
AS usual, off topic
Jim
Old 04-23-2018, 01:32 PM   #2932
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/256HNBz]20180423_121452
[url=https://flic.kr/p/23GQLvN]20180423_125720
[url=https://flic.kr/p/Jk3sgb]20180423_125807
The larger crimp puts a hex crimp but the narrower crimp tool fits better on the pin, and does a factory style crimp
SAFETY FIRST
AS usual, off topic
Jim
Old 04-24-2018, 10:32 AM   #2933
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
These are the pins and tool that I'm working with. Since all the wires pulled out of the pins, I will solder them
[url=https://flic.kr/p/GQxatM]20180424_102116
SAFETY FIRST
AS usual, off topic
Jim
Old 04-25-2018, 10:47 AM   #2934
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Did some soldering of my pins, s/b a better connection, just don't go crazy with solder, I use a very small diameter! Just on the crimp
[url=https://flic.kr/p/25a5mXt]20180425_103313[
While I was researching Jess's Sniper EFI, I found a clamp on O2 senser mount, hope it works as I suck a welding
TPS is locked and finished
[url=https://flic.kr/p/25a7kYk]20180425_105519
SAFETY FIRST
AS usual, off topic
Jim
Old 04-25-2018, 01:13 PM   #2935
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
TPS and IAC are done now onto MAP
[url=https://flic.kr/p/Jph5hQ]20180425_131006
SAFETY FIRST
AS usual, off topic
Jim
Old 04-26-2018, 10:34 AM   #2936
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Last conversion from late model to early connecter- MAP
[url=https://flic.kr/p/GUyec2]20180426_094705
SAFETY FIRST
AS usual, off topic
Jim
Old 05-03-2018, 02:07 PM   #2937
lleff
Re: PO has me PO'd
managed to read through most of your build thread, you do some fantastic work, on a side note im in the industrial maintenance profession my self, im still green compared to you tho with only about 8 years of experience. looking forward to more updates great work so far
lleff is offline   Reply With Quote
Old 05-03-2018, 11:05 PM   #2938
franken
Re: PO has me PO'd
The tool to compress the tangs on the terminal is a pin pusher.
Your crimpers look to be incorrect, sadly there are many kinds.
If the wires pull out of the terminal after crimping, the crimper is not the right one, or the crimp was incorrect. Sorry...
Ref the pic in post #2933. The crimp of the big end (closest in the pic) is in the insulation to help hold the terminal; the next one is in the bare wire and provides the electrical connection. The crimper should roll the tangs of the terminal in a bit, not just fold them over. If the crimper has U shaped patterns and not rounded W patterns, it aint right. Also, with a less expensive crimper you may need to crimp a few times on the different spots.
The next bits sticking up slightly are what hold the terminal in the connector and what the pin pusher releases to allow the terminal to be removed.
It might be too late, so if you soldered, make sure to try and minimize vibration, wobbling, movement, whatever at the connection. A soldered joint is brittle and more prone to failure when stressed. A soldered joint also depends on a good mechanical connection; solder is an alloy of lead and tin, neither of which are strong.
Sorry if that was TMI.
franken is online now   Reply With Quote
Old 05-04-2018, 09:29 AM   #2939
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for reading, has been a long road, but fun! Started out as a tool and die operater, after Vo-tech, but was bored standing in one spot all day
My career in industrial man. was rewarding and I enjoyed going to work every day. Ya just never knew what fire you would have to put out, on any given day, and that was the interesting part, never boring. Something broke all the time in the factories I've worked at.....
Pay was great, and overtime was always there. Papermills were the most fun as everything was HUGE. Pharmicueticals not so much as everything had SOP's
Gotta get my spell check working again!
SAFETY FIRST
AS usual, off topic
Jim
Old 05-04-2018, 09:43 AM   #2940
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks for posting up, I agree with all of what you said, except the wire that pulled out was a factory crimp from FAST. I always pull on my crimps to check if they are strong. Just recently, started using solder,and agree on making the connection brittle
Using the right crimper is also key, as you state , a "W" shape is the one to use of the correct size
Information is key, to a buildthread, and I hope it helps young builders in the future, past when I have long gone
SAFETY FIRST
AS usual, off topic
Jim
Old 05-04-2018, 10:01 AM   #2941
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Newest adventure, step up resister to crank trigger- 5v-12v across signal and power wire
[url=https://flic.kr/p/26KxEf5]20180504_095233
SAFETY FIRST
AS usual, off topic
Jim
Old 05-10-2018, 10:42 AM   #2942
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ref: post 2896. repin connecters and terminals for FAST to EFI Connections. Connectors from FAST would not fit sensors from EFI, plus terminal locations are in a differant oreintation, with information provided by EFI and the schmatic from FAST, I was able to repin the connectors to plug in to the sensors on the cam and crank with out the jumpers from EFI Connection, SOOOO, wires go in and out the same colors
Terminal release tool goes in the little rectanguler slot at the top of the connecter. First remove white lock on connector, then you are able to remove wires and metal terminals. Don't forget to rebend locking tab up
Photos to follow, flickr not working, or operater error
SAFETY FIRST
AS usual, off topic
Jim
Old 05-10-2018, 11:38 AM   #2943
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/HmZ71T]20180510_101426
[url=https://flic.kr/p/HmZbNi]20180510_101519
this is the portion of the schmetic I'm working on
[url=https://flic.kr/p/25DujVB]20180510_103855
SAFETY FIRST
AS usual, off topic
Jim
Old 05-11-2018, 07:24 PM   #2944
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
You make it look so easy Jim.
low'n slow is offline   Reply With Quote
Old 05-12-2018, 07:02 AM   #2945
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Doug, but the hard part for me will be having my computer talk to the system, I have no idea how to do that! Lucky for me I've had people to talk to, Jim at TPIS and the techies at FAST, and Chris at EFI Connections, they answered all my dumb questions
Hav'nt seen anyone else on these boards using FAST, so I'm on my own, just me and my computer
SAFETY FIRST
AS usual, off topic
Jim
Old 05-24-2018, 12:28 PM   #2946
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just picked this up from E-bay for 25.00 or 30.00. Thanks to the heads up from long standing member John H. Great forum when guys look out for one another
[url=https://flic.kr/p/27u8n1e]20180524_121406
This thing looks brand new, date on box says 1995, so I hope it's not for a newer truck, guess I'll have to wait and see
SAFETY FIRST
AS usual, off topic
Jim
Old 05-25-2018, 12:23 PM   #2947
John H.
John H.'s Avatar
Re: PO has me PO'd
Jim,
Great buy! Here are some older gauges and boxes with same part numbers on the box and the gauge.
John H. is offline   Reply With Quote
Old 05-29-2018, 07:54 AM   #2948
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by John H. View Post
Jim,
Attachment 1787369
Thanks John for all the help, glad the numbers match. I thought the price was reasonable also
SAFETY FIRST
AS usual, off topic
Jim
Old 06-07-2018, 10:32 AM   #2949
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
It's alive and well, buddy came over to help figure out 2 phase
[url=https://flic.kr/p/26QMHWN]20180606_114651
SAFETY FIRST
AS usual, off topic
Jim
Old 07-17-2018, 09:08 AM   #2950
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/299Mhsf]20180717_085848[
ANyone know size of these four bolts??????????????
Putting A/C in a non A/c truck, bezel to nice not to use
SAFETY FIRST
AS usual, off topic
Jim
