Old 04-20-2010, 07:57 PM   #276
Bruce88
Bruce88's Avatar
Re: It’s Just A Pickup
Not as strong as I use to be
Had to invite a friend over for a hand to torque the U bolts to 145 foot pounds.
Assembling the rear suspension and checking that everything has clearance thru out the complete suspension travel. With the shock relocator mounts and air shocks just wanted to make sure everything cleared, and it did. Plus with the coil springs not installed I could center the rear end and set the (LMC – 37-8541) Adjustable Tracking Arm at the proper ride height without having body weight on the frame. I also installed some control arm bushings (7-301-BL Prothane Motion Control).
The one thing that I would change if I was to fabricate the shock relocator mounts again is to make the ½ inch spacer out of aluminum instead of steel. The largest drill bit that I have is ½ inch and had to bring the holes up to ¾ inch plus with a step drill (not really made to drill in this thick of metal) and if it had been aluminum it would have been a lot easier.
May you have all the strength needed for your build or friends to help (smile). Enjoy your build
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 04-20-2010, 08:15 PM   #277
jojo
printing is my trade
jojo's Avatar
LOL I'll need some friends help soon enough.
I can't remember which came first, my bad shoulder or that old pick up truck.
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184
jojo is offline   Reply With Quote
Old 04-29-2010, 01:50 PM   #278
Bruce88
Bruce88's Avatar
On four wheels again
The frame and suspension components are back together. At least it’s easier to move around (smile).
Looking thru some old reseats for suspension parts that I used to lower the truck a few years back and found some of the part numbers I used.
Parts obtained thru Sport Truck Direct (2.5/4 Deluxe Drop Kit)
Drop Spindles --------- 2-1/2 drop C10 (#1001 Western Chassis)
Rear Drop Coils ------ 4 inch drop (#3828 by ?)
Front Shocks ---------- #4052G Doetsch Nitrogen Slammer Shocks
Front Sway Bar ------- 1-1/8 DIA #7423 Hellwig sway bar
Rear Sway Bar -------- 1-1/8 DIA #7401-D Hellwig sway bar
(Note parts may not be still available or part numbers may have changed)
(More parts like ball joints, tie rods and A arm shafts where used to rebuild the front end a few years ago was unable to locate the reseats) O well that happens over time (smile).
My truck didn’t come with any sway bars. The Hellwig sway bars where a clamp on stile (no drilling to install). I didn’t like the clamp on stile so I converted them to bolt on with grade 8 nuts & bolts.
With it being on its wheels again it was definitely a good time to roll the frame outside to clean up the shop and take some pictures
With the shop cleaned up and the parts somewhat organized a never ending battle (smile). It’s definitely a good time, turning the corner where final assembly of all the parts on the frame begin. Enjoy your build
Old 04-29-2010, 03:11 PM   #279
VA72C10
VA72C10
VA72C10's Avatar
looking good! nice progress
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-29-2010, 03:52 PM   #280
Mt Man Chad
Mt Man Chad's Avatar
What size tires are those?
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 04-29-2010, 04:02 PM   #281
Bruce88
Bruce88's Avatar
P255/60R15 Radials
Old 04-29-2010, 04:11 PM   #282
Mt Man Chad
Thanks, thinking of 275 60R15 BFG's for the 68 I'm finishing
Old 04-29-2010, 07:56 PM   #283
C-10 Addict
looking good bruce! big day back on 4 wheels
C-10 Addict is offline   Reply With Quote
Old 05-08-2010, 09:26 AM   #284
Bruce88
Bruce88's Avatar
A little massaging, a little caressing and it finely fits
The stainless steel brake lines are installed
Added a few more clamps than a stock installation and used 5/16 - 18 x ¾ long stainless steel nuts and bolts instead of the stock steel ones. The forward brake hoses are stock but the aft brake hose is a custom 12 inch long hose from Inline Tube. Even when the truck was at a stock ride height I thought that the stock aft hose was to long (stock hose 18 inches long) and with the truck lowered the stock hose was really twisted up.
All in all the pre-bent stainless steel brake lines from LMC fit pretty good with minimal adjustments for fit for this stock 72 truck installation.
Ill let you guess where I added clamps over the stock installation (smile)
Not shown in the pictures below I also installed the tail light wiring harness along with a 18 gauge wire for the relocated gas tank along the LH frame rail using the similar fastener locations as the brake line run on the RH frame rail.
Onto the gas tank installation and more pluming of the fuel lines to do. Enjoy your build
Old 05-08-2010, 09:41 AM   #285
robmrtnbb5
robmrtnbb5's Avatar
lookin good
bondo bob
http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build
robmrtnbb5 is offline   Reply With Quote
Old 05-08-2010, 09:47 AM   #286
VA72C10
VA72C10
VA72C10's Avatar
nice, clean install....keep at it!
Old 05-08-2010, 09:49 AM   #287
sourkraut
sourkraut's Avatar
good job bruce! when would you like to do mine!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 05-08-2010, 10:22 AM   #288
Bruce88
Bruce88's Avatar
Thanks for the complements guys. sourkraut I wouldn’t want to rob you of the self satisfaction of doing it yourself (smile)
Old 05-08-2010, 08:13 PM   #289
sourkraut
sourkraut's Avatar
thanks buddy! i will have to get busy on mine shortly.
Old 05-10-2010, 12:42 PM   #290
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Wow. Bruce, I've spent the last couple of days looking over this build thread. I am a fairly new member here, don't have any experience in body repair but have work experience in tool and die, fabrication and design (water heaters ). I could say this is about as detailed or more than some of the college courses I've taken. Absolutely amazing work you do with that shop. It's been a while since you posted the story, but glad to hear that you're ok after that breakin. It goes to prove that a level head will get you much farther than being young & dumb with a weapon. I would be proud to have a neighbor like you with or without trucks!
Take care from the other side of the country.
And if you still have that cab, feel free to send it on the wings of some big bird to drop in Ada, MI! It looks flawless to my partial cab I'm using for my build!
propanemudtruck is offline   Reply With Quote
Old 05-11-2010, 12:37 PM   #291
Merki
Bruce, I found your build thread last night. I have to say it is one of the best I have found in the last year of research. There is only one other that was in your catagory for clarity, planning, organization and great photos. Your photos are great and leave no doubt as to what is being done even for shy beginners like me. I am encouraged. I should have realized sooner that you had a background in aviation. I used to work in aviation in Europe before moving back to Canada so I saw a lot of quality repairs being done and your work is the epitome of those skills in auto rstoration.
Thank you for sharing your progress and making it seem less daunting for us newbies. I hope my dream plans for my 1949 Chevy 5 window are someday as good as your work. You make it seem attainable.
Merki is offline   Reply With Quote
Old 05-11-2010, 03:44 PM   #292
Bruce88
Bruce88's Avatar
Look what I found while wandering thru the auto parts store
Something new to me at least and a improvement to towing wiring that I wanted
I plan on doing some trailer hauling nothing big that would require trailer brake wiring just a basic trailer flat 4 pin wiring. The plug-in trailer wiring has been around for a long time and I have used it in the past and consider it the way to go instead of splicing in wires (when a wiring kit exists for the vehicle I’m working on) and a wiring kit exists for 68-84 Chevy pickups part # 41105 by Hopkins.
Always thought it would be nice to be able to mount the flat 4 pin connecter instead of just using a clamp on the wires and letting the connecter just hang down. Now I’ve found the Adapter part # 47605 by Hopkins that allows the connecter to be mounted in a 1.25 inch hole with a bracket or in some hitch wiring mount holes. As far as I’m concerned this is something that’s been needed for a long time and maybe it has been around but I just found out about it (smile).
Wandering thru the auto parts store can score something you didn’t know existed or something you wanted to exist and today was my day. Enjoy your build
Old 05-11-2010, 03:56 PM   #293
nightmare
nightmare's Avatar
Attachment 583202
I've enjoyed watching your build as you progress. Has given me some good ideas as to what to do for mine. Anyhow, you may want to test that 41105 adapter to make sure there are no problems with it. I bought one from O'Reilly's and had to return it. It caused feedback in the system somehow, and when I would step on the brakes, the dash lights would come on. When I tested it with a multimeter, two of the lines were interfering with each other, causing the said problems. I tried another one from Advance Auto, but it was the same thing. I finally made one myself that works properly. Just a heads up, may not be the case with the one that you bought though.
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 05-11-2010, 04:23 PM   #294
Bruce88
Bruce88's Avatar
Thanks for the heads up (nightmare)
Just went out and did a ohms check on the complete wire run thru the wiring kit and the adapter and found no crossed wires. Looks like there will be no problems with mine but as can happen with any thing there can be a bad batch, always a good thing to check ahead of time rather than try and figure out the problems later. Thanks again
Old 05-14-2010, 01:10 AM   #295
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Hi Bruce, I just joined the site a week or so ago and tonite I found your build project. You have done some fantastic things to this truck with great detail. I look forward to seeing more. Keep up the great work
chevytruckluver is offline   Reply With Quote
Old 05-18-2010, 09:30 AM   #296
my67chevytruck
Under Construction
my67chevytruck's Avatar
Bruce, I have some wiring looms like you have mounted on your engine. I was wondering if you had to shim/use spacers to get them to clear the ramhorn exhaust? My ramhorns interfere with the mounting. I can bend the tabs to make it clear, but it looks funny with the looms not level.
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 05-18-2010, 12:06 PM   #297
Bruce88
Bruce88's Avatar
The plastic spacer came with my wire looms to raise it above the exhaust manifold, of course a longer bolt was required.
If you’re going to make some spacers I would probably make them out of aluminum tube/pipe. If your unable to find some tube/pipe to fit your needs locally I found a online company to order raw stock material (they do no machining) that they will cut to length and ship to your door. The cost is a little high but when you’re looking for a small peace of metal to work it comes in handy I’ve used them and find it a benefit. The company is Online Metals ( http://www.onlinemetals.com/ ). Finding aluminum tube/pipe with thicker wall thickness can be hard some times just order a little more than you need and cut it to the lengths needed.
Hope this helps you out
Old 05-18-2010, 12:14 PM   #298
sparkydog
sparkydog's Avatar
McMaster Carr (and others like them) carry a variety of standoffs/spacers. Here is a link to their "selection" menu.
http://www.mcmaster.com/#spacers-and-standoffs/=7571wy
From there you can narrow down by shape, size, material - whatever you want.
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 05-18-2010, 12:39 PM   #299
my67chevytruck
Under Construction
Attachment 586122
Thanks Bruce, that helps alot, i was thinking you used spacers, thanks for the pics and info.
Thanks for the info.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 05-18-2010, 12:44 PM   #300
Bruce88
Bruce88's Avatar
Thanks for the added info on another place to look for parts I will be adding them to my list of places to look in the future.
