Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-15-2012, 11:45 PM   #276
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
I received your payment today. I will get those shipped out on Monday.
You do realize that the D52's are the only caliper that will bolt up to these brackets, right?
Originally Posted by MJs69CST View Post
Good morning Captain. I am going to place an order this morning for the Astro brackets--I will be using the D52 calipers eventually.
Thanks.
Old 12-15-2012, 11:51 PM   #277
Captainfab
60-66 Nut
I have not had that issue with what I have mocked up here. One other customer has had that issue, but he has not gotten back to me with the measurement I need to determine what needs to be done to correct the situation. I don't want to just move the caliper out farther, and have the pads hanging past the outer edge of the rotor, if I don't have to. I just need someone to help me out with the measurement I need.
Originally Posted by gringoloco View Post
Was there ever a solution to the pad rubbing the rotor hat issue? Mine are scoring pretty hard...
Old 12-15-2012, 11:52 PM   #278
gringoloco
A guy with a truck
gringoloco's Avatar
Let me know what you need and I'll try to get it for you
gringoloco is offline   Reply With Quote
Old 12-16-2012, 12:54 AM   #279
Captainfab
60-66 Nut
I don't have a pic of the dimension I need, on this computer. I will get it from my shop computer tomorrow and post it here.
Old 12-17-2012, 12:14 AM   #280
Captainfab
60-66 Nut
Here is a pic showing the dimension I need from those that have had a brake pad to rotor hat interference issue. Once I know what you have I can make the necessary change, and get you a set of brackets to correct the issue.
Old 12-17-2012, 02:46 PM   #281
gringoloco
A guy with a truck
gringoloco's Avatar
You need the 3.5182 distance? I'll see what I can do this eve...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
Old 12-18-2012, 12:29 AM   #282
Captainfab
60-66 Nut
Yes, that is the measurement I need. Yours may or may not measure 3.5182. Once I know what yours measures, I can have a set made that will solve the pad rubbing issue.
Old 12-21-2012, 01:58 AM   #283
Captainfab
60-66 Nut
Thanks for the purchase, and the compliment
Brackets arrived! Quality stuff. Thanks Capt!
Old 01-02-2013, 07:47 PM   #284
Hazieview
Building Dreams out of Dimes!
Question Re: D52 Caliper Rear Disc Brake Brackets
Will these parts work with the D52 brackets? Just checking before I order them.
ROTORS:
http://www.summitracing.com/parts/eb...ro?prefilter=1
CALIPERS with ebrake:
http://www.summitracing.com/parts/aa...model/eldorado
I know i will have to get one for the passenger side and one for the driver side but I wanted to make sure I had the right ones.
Thanks guys!
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 01-03-2013, 12:37 AM   #285
Captainfab
60-66 Nut
Those look like the right parts......
Old 01-24-2013, 10:12 AM   #286
EZURCC
EZURCC's Avatar
Cap'n,
Any news on the e-brake levers for the Eldo calipers? I'm waiting on the availability of those levers. As soon as they are, I'll be placing my order. We need an e-brake in TX to pass inspection. Thanks.
EZURCC is offline   Reply With Quote
Old 01-25-2013, 01:07 AM   #287
Captainfab
60-66 Nut
I don't have them done yet, but I'm trying to find the time to get them finished. I know there are a few of you guys needing them.
Originally Posted by EZURCC View Post
Cap'n,
Old 01-27-2013, 02:27 AM   #288
Captainfab
60-66 Nut
I took some time today and made some progress on the Eldorado caliper levers and cable brackets.
I got 2 sets of levers formed up, but they ended up about 3/16" shorter than the originals. But I think they would still work. Regardless, I am going to order some longer ones laser cut next week. I also got the cable brackets drawn up on AutoCad, and will get some of those laser cut as well.
Old 01-29-2013, 09:01 PM   #289
Hazieview
Old 01-29-2013, 09:05 PM   #290
Hazieview
Got me some astro van rotors but they are way to thick for my Eldo calipers. Has anyone had this problem?
Old 01-30-2013, 12:18 AM   #291
Captainfab
60-66 Nut
Do you have the '76-'78 calipers? Which pads do you have?
Old 01-30-2013, 12:13 PM   #292
truckzilla
truckzilla's Avatar
You rock Captainfab!
truckzilla is offline   Reply With Quote
Old 01-30-2013, 06:30 PM   #293
Hazieview
Yes I have the 76-78 calipers and I got Wearever silver brake pads. MFG NAD 122
Duralast Rotors
Bolt Pattern Diameter (mm): 127
Rotor Bore Diameter (mm): 78.5
Rotor Initial Thickness (mm): 32.70
Rotor Outside Diameter (mm): 295
Rotor Overall Depth (mm): 83
Wearever Silver Brake Pads - Rear
Friction Material Thickness, Inner Pad: 0.4 in
Friction Material Thickness, Outer Pad: 0.43 in
Front or Rear Brakes: Rear
Fenco Disc Brake Caliper, Rear Right & Left
I can not figure it out. I mean the rotors will NOT fit in the calipers with the brake pads installed....? The rotors are like .25 in too big..?
Old 01-30-2013, 11:47 PM   #294
Captainfab
60-66 Nut
Did you check to see if the shaft is rotated as to engage the parking brake function of the caliper. If not you might try turning the shaft coming out of the back of the caliper. A box end wrench or a deep socket should work to grab it. I just don't remember what size off hand.
Old 01-31-2013, 07:00 PM   #295
Hazieview
The parking brake is not engaged. The caliper piston is all the way back. The rotor will not fit with the brake pads installed. My rotors are 1.29" thick. Have you ever heard of this issue before? What is the inside width of your calipers and how thick are the brake pads you are using?
Old 01-31-2013, 11:48 PM   #296
Captainfab
60-66 Nut
I have a pair of used calipers at the shop. I'll check out the fitment tomorrow and post my findings here. I have not heard of this issue from any of my other customers.
Old 02-01-2013, 06:07 PM   #297
Hazieview
Do you know of any customers that we can contact? Perhaps they can be of some assistance too. What size rotor, caliper inside width, and brake pad width and what brand they went with is all I need.
thanks!
SB400 350th
Old 02-01-2013, 09:26 PM   #298
notagain
notagain's Avatar
Would this work on a 69 Suburban C20 rear axle (8 bolt drum)
notagain is offline   Reply With Quote
Old 02-01-2013, 11:42 PM   #299
Captainfab
60-66 Nut
Right now I can't think which of my custromers that have bought these brackets are using the Eldorado calipers.
I can not get a set of the D122 pads until tomorrow, but I did put a set of the D52 pads in a Eldorado caliper today. With the piston all the way retracted, there is 1.312" (1-5/16") between the pads. The pads I used were each about 9/16" thick. I'll check again tomorrow when I get the D122 pads.
thanks!
Old 02-01-2013, 11:45 PM   #300
Captainfab
60-66 Nut
No, These only work with the '64-'82 GM truck 12 bolt and '80-'87 truck 8.5 10 bolts.
Does your Suburban have the Eaton HO52 or the Dana 60?
