Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 07-16-2011, 09:15 PM   #276
bruin_d
bruin_d's Avatar
Re: 72 Suburban Build
Ready to move into its old home after the renovation
Now, if I could find someone who sells inner fenders, I'd be set.....
bruin_d is offline   Reply With Quote
Old 07-17-2011, 06:19 PM   #277
67cheby
67cheby
67cheby's Avatar
ya...what he said !! I went to his place of business friday morning at 7 am, he was quite supprised to see me, well he had told me a week ago that he had the molds done and would have me parts ready last week...well no parts so i showed up the molds are 90% done and he promised that he would work on them all this weekend to get them done !!so we will see what next week has in store for me , i have already contacted another "BACKUP" company that said if i bring them the molds this guy has made they will start making me parts immediatley, if i have no parts in my hands by this friday i will be picking up my molds and taking them to the new guy !! motor looks great by the way !!!
67cheby is offline   Reply With Quote
Old 07-17-2011, 08:02 PM   #278
bruin_d
bruin_d's Avatar
Pretty good progress today. Motor and tranny are in and tranny cross member is mounted. I need to do some "persuading" on the passenger side to get the header to fit but other than that, everything went pretty smooth. I also need to email Nate (unless he chimes in here) to ask about the cross member that the carrier bearing bolts to. I'm not sure if I'm supposed to shim it up or get a different (taller) carrier bearing. Just seems like its a a steep angle from the tranny which adds to the angle of the rear driveshaft. I'll try to take a picture of it later.
Old 07-17-2011, 08:05 PM   #279
67cheby
67cheby
67cheby's Avatar
WOW...that looks KILLER !!!
Old 07-17-2011, 08:10 PM   #280
bruin_d
bruin_d's Avatar
Thanks man. I left one thing out I still need to do. I can't get the stupid distributed cap on! I need to pull my remote reservoir off and do some clearancing on that lip in order for it to go.
Old 07-17-2011, 08:12 PM   #281
67cheby
67cheby
67cheby's Avatar
i am considering a COMPU-TRONIX distributor-less ignition system ...to avoid this problem !!! only issue is it is about $700....
Old 07-17-2011, 08:14 PM   #282
burbguy77
burbguy77's Avatar
how much did htat crossmember cost you?
burbguy77 is offline   Reply With Quote
Old 07-17-2011, 08:34 PM   #283
bruin_d
bruin_d's Avatar
I don't have enough cheddar left to afford that this time around. Is it bad that I'm already thinking about what I want to do in a few years when I pull it apart again to paint it?
Old 07-17-2011, 08:36 PM   #284
bruin_d
bruin_d's Avatar
I think they're going for $1099 right now. Go to porterbuiltfabrication.com
Old 07-17-2011, 09:06 PM   #285
jmedero
jmedero's Avatar
The carrier bearing I used did not need to be shimmed. The base was taller then the oe one I took out. CPP has a billet one they sell. 67cheby has it on his. My buddy has a Mallory small cap hei with the remote power box. Should make good on that tight space you have there.
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-17-2011, 09:36 PM   #286
bruin_d
bruin_d's Avatar
Originally Posted by jmedero View Post
The carrier bearing I used did not need to be shimmed. The base was taller then the oe one I took out. CPP has a billet one they sell. 67cheby has i on his. My buddy has a Mallory small cap hei with the remote power box. Should make good on that tight space you have there.
Juan
First of all, there's no way I'm pulling the motor out to change the distributer. Second, does your buddy have a big block in his? Mine is the MSD pro billet with mechanical advance, I didn't think they got much smaller.
As far as the carrier goes, I'll have to look into that. However, isn't CPP the company people keep complaining about getting their parts so late? If it is, with my luck, I'm going to need to find somewhere else. I could be getting them confused with another company though.
Old 07-17-2011, 10:13 PM   #287
jmedero
jmedero's Avatar
No you got it right... It's them. Lol.
My buddy is running that cap in a 57 with a big block. I know they are diff trucks I just know that cap frees up a bit of space. I will be switching to one when I work on my nova.
Old 07-18-2011, 12:40 AM   #288
YBNORML
YBNORML's Avatar
Looks wicked!! Excellent work. I'm curious about your steering shaft. Nate told me that in order to run headers with a big block I would need to split the shaft and run a third knuckle as well as an idler to keep everything in check. I notice your only running two. Did you do something different?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-18-2011, 03:01 AM   #289
project 67 sub
project 67 sub's Avatar
inland empire driveline in ontario california actually makes that billet and polyurethane carrier bearing you guys are talking about, that cpp sells. you can go on their website and also give them a cal,l and probably might be able to save some headache on the whole deal getting it directly from the manufacturer
project 67 sub is offline   Reply With Quote
Old 07-18-2011, 06:58 AM   #290
bruin_d
bruin_d's Avatar
I didn't do anything special. Maybe its the headers I'm using that gives it the room?
Old 07-18-2011, 06:59 AM   #291
bruin_d
bruin_d's Avatar
Nate recommended them too. I'll probably hit them up today. Thanks.
Old 07-18-2011, 03:08 PM   #292
bruin_d
bruin_d's Avatar
I was looking through a bunch of the pictures I've taken and thought I'd repost some as a before/after.
Old 07-18-2011, 03:09 PM   #293
kev2809
low n' slo
kev2809's Avatar
wow...what did you do with all the wires that ran across the top of the firewall?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-18-2011, 03:12 PM   #294
Wildstreak
"something witty here"
Wildstreak's Avatar
He cut that crap out lol. if you go to a painless harness or a similar brand, you can run the wire by the rad for a cleaner look, Thats what I did...
57 chevy 4x4
70 swb fleetside 4x4
68 burb 2wd:
71 burb 2wd: 350 4spd
71 lwb fleetside 4x4: 350/sm465/205/3.07 eaton posi rear
72 lwb fleetside Cheyenne 454/th400
1991 GMC V3500 CC 4x4
Wildstreak is offline   Reply With Quote
Old 07-18-2011, 03:23 PM   #295
67cheby
67cheby
67cheby's Avatar
my carrier bearing set up , had to build a spacer to go under it. the trailing arm mounts have been shaved and the loop over the driveline raised !!
Old 07-18-2011, 03:36 PM   #296
bruin_d
bruin_d's Avatar
Most of was junk I don't need like AC, blower motor, coil/distributer, windshield washer motor, one wire alt, headlights...crap...guess I better connect that last one back up. Believe it or not, just re-routing will clean it up a ton.
Old 07-18-2011, 03:37 PM   #297
bruin_d
bruin_d's Avatar
67cheby, thanks man. I think I need to do the same thing. Otherwise it seems like the driveshaft is pointed down too much coming out of the tranny.
Old 07-19-2011, 06:58 PM   #298
YBNORML
YBNORML's Avatar
I dunno, I'm still waiting on my parts from Nate. Once they get here I'll check it out. The headers I chose are from a 67-69 camaro. What are yours?
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-19-2011, 11:43 PM   #299
bruin_d
bruin_d's Avatar
They're chevelle 3/4 length if i remember correctly.t
Old 07-19-2011, 11:49 PM   #300
bruin_d
bruin_d's Avatar
You have no idea how big of an accomplishment this is for me. This is the biggest wiring job I've EVER done. The blinkers/lights work, starter works, and the alternator is wired.
