Old 05-04-2011, 04:53 PM   #276
oldman3
oldman3's Avatar
Re: My 50 roadster pickup build
Grill frame blasted and ready for primer. I had welded up the holes for the old running/signal lights.
oldman3 is offline   Reply With Quote
Old 05-04-2011, 04:55 PM   #277
oldman3
oldman3's Avatar
Pic 1 Grill bars all cleaned and primered.
Pic 2 Grill frame in primer.
Old 05-04-2011, 04:56 PM   #278
oldman3
oldman3's Avatar
This pic show how I shortened the bumper brackets to pull it closer to the grill.
Old 05-04-2011, 04:59 PM   #279
oldman3
oldman3's Avatar
The front bumper (which I'm using) has been shortened 3" per side, and top cut down by 1", and bumper bolts heads cut off and bolts welded.
Old 05-04-2011, 05:01 PM   #280
oldman3
oldman3's Avatar
I welded the bumper bolts flush with face, then welded the back side, then a large washer was welded to help distrubute the load, and not pull thru.
Old 05-04-2011, 05:03 PM   #281
oldman3
oldman3's Avatar
Sorry for it being sideways, got in to big of a hurry when scanning. Bumper mounted and playing with end design.
Old 05-04-2011, 05:04 PM   #282
oldman3
oldman3's Avatar
Finally decided to leave it like the original shape.
Old 05-04-2011, 05:06 PM   #283
oldman3
oldman3's Avatar
Grill frame and one bar installed to check fit. Here you can see I have cut the fender. I removed about 1/8" of material, moved out, and welded to maintain a good gap with hood.
Old 05-04-2011, 05:08 PM   #284
oldman3
oldman3's Avatar
A cover I made to hide some of the ugly around the radiator.
Old 05-04-2011, 05:10 PM   #285
oldman3
oldman3's Avatar
That's it for today, tomorrow we move to inside the cab, but not what you might think
Old 05-05-2011, 06:54 PM   #286
oldman3
oldman3's Avatar
Now I'm starting on my preliminary interior set-up. I try to get as much stuff done ahead of time, before I do my final stuff on the cab, in case I need to weld, etc. This is the formed corner for the cab.
Old 05-05-2011, 06:56 PM   #287
oldman3
oldman3's Avatar
Here it has been installed. You can see that I'm using my bracing for attachment points for the interior. If you look close you can see the screws going into the brace.
Old 05-05-2011, 06:59 PM   #288
oldman3
oldman3's Avatar
With the center piece installed. Once everything is covered in material, it will be hard to see the screws. The coverplate at the corner, is for my inside lift handle for the door latch. I know this looks like wainscoting for the kitchen, but with material applied it will look like pleats.
Old 05-05-2011, 07:01 PM   #289
oldman3
oldman3's Avatar
This is a sample piece I made to show friends.
Old 05-05-2011, 07:02 PM   #290
oldman3
oldman3's Avatar
Doing layout work for panel design on paper.
Old 05-05-2011, 07:05 PM   #291
oldman3
oldman3's Avatar
Pic 1 Design laidout on lauan boards. Small screws at temporary, all panels will be installed with metal door panel clips, everything will be hidden.
Pic 2 Another view.
Old 05-05-2011, 07:07 PM   #292
oldman3
oldman3's Avatar
Side panel for console.
Old 05-05-2011, 07:08 PM   #293
oldman3
oldman3's Avatar
Layout for the inside of top.
Old 05-05-2011, 07:10 PM   #294
oldman3
oldman3's Avatar
Looking thru the front windshield area.
Old 05-05-2011, 07:11 PM   #295
oldman3
oldman3's Avatar
Tomorrow will be going back for some more body work. Enjoy Jim.
Old 05-05-2011, 11:39 PM   #296
youngrodder
youngrodder's Avatar
I like the interior a lot. It also gives me some ideas as the interior will be one of the last things that I do.
Where did you get the arm rests from?
I like where you are going with this.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-06-2011, 08:33 AM   #297
oldman3
oldman3's Avatar
Marc
Thanks. Got the arms from Old Dog Street Rods, they have several different sizes and shapes. Love the paint job on your ride, when are you going to drop it
Old 05-06-2011, 07:10 PM   #298
flatbed51
flatbed51's Avatar
Jim, where is todays build post????? I am having withdrawal symptoms LOL.
My Build Thread
51 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=437496
48,49,50 Chevy trucks. 41 Olds
flatbed51 is offline   Reply With Quote
Old 05-06-2011, 07:53 PM   #299
oldman3
oldman3's Avatar
Sorry for the delay, cutting grass all day (I mow about 4 acres, takes awhile).
Oh with the shoe (show)
Removed front fenders, so I can start getting them ready.
Old 05-06-2011, 07:55 PM   #300
oldman3
oldman3's Avatar
Pic 1 Removing old tar, etc.
Pic 2 same.
