01-04-2015, 09:57 PM | #276 |
Re: project 86
I have settled on my steroids for the truck and next week I'll finish having my rear built, decided not to try it myself
01-04-2015, 10:01 PM | #277 |
Re: project 86
Now I have achieved my goal of sq and spl. I can change my focus again.
03-05-2015, 01:38 AM | #278 |
Re: project 86
Got the 12 bolt finished not it needs to be painted. I'm install ingredients the rotors read to get a chassis prepared for painting
03-05-2015, 07:58 PM | #279 |
Re: project 86
Tell me about the sectioned crossmember.
03-05-2015, 09:04 PM | #280 |
Re: project 86
Chris, any issues w/the housing? Can't remember..... what differential/axle set-up did you finally decide on?
03-06-2015, 01:25 PM | #281 |
Re: project 86
Not so far had a shop build it. It has a Detroit locker with 3.73 gears. Thanks again for helping me out with that
03-06-2015, 01:26 PM | #282 |
Re: project 86
Scoti Did the work so he's your guy if you need anything
03-08-2015, 02:40 AM | #283 |
Re: project 86
Have the rear diff painted. It would be finished but the axle bearing and seals need to be replaced, and a recent vasectomy is definitely slowing me down
03-19-2015, 03:22 PM | #284 |
Re: project 86
Got the rear installed. And got a quick look at what the truck will look like height wise. Also getting cursed by my cousin for letting my work area turn into a storage.
04-07-2015, 09:44 AM | #285 |
Re: project 86
More updates, had the chance to see what it may look like on the ground
04-07-2015, 11:11 AM | #287 |
Re: project 86
The truck is coming along nicely!
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB 1987 GMC V3500 Dump, 6.2L diesel, TH400 1983 GMC K2500 - awaiting its restoration and Cummins swap. |
04-08-2015, 01:05 AM | #288 |
Re: project 86
Nice job and a good healthy pace.
04-10-2015, 12:53 AM | #289 |
Re: project 86
Thanks guys! I'm trying little by little
04-10-2015, 12:57 AM | #290 |
Re: project 86
Trying to see what it will look like once I reinstall the fuel cell. So by my measurement the way my rear is setup I'll have 4 inches of ground clearance aired out. little close, but meh.
04-26-2015, 03:57 AM | #292 |
Re: project 86
Got a chance to pull the truck out and deep clean my garage . Also received some parts from amazon, can't even trust those guys anymore
04-26-2015, 04:02 AM | #293 |
Re: project 86
Also ran some brake lines, I'll finish when u get the rest in the mail
04-26-2015, 05:25 AM | #294 |
Re: project 86
missing parts in the Amazon shipment?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
04-26-2015, 07:47 AM | #295 |
Re: project 86
looking real good!
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
04-27-2015, 10:31 PM | #296 |
Re: project 86
Truck is going to look awesome!..what did the rearend rebuild cost?
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
04-28-2015, 12:34 AM | #297 |
Re: project 86
They have sent me 2 other packages and both are wrong WTF
04-28-2015, 12:35 AM | #298 |
Re: project 86
04-28-2015, 12:36 AM | #299 |
Re: project 86
$300 for the actual labor
05-05-2015, 12:15 AM | #300 |
Re: project 86
Made a slight measuring mistake but oh well. Instead if 4 inches aired out the tank will be 3 1/4 inches from the ground
