Old 01-23-2021, 06:33 PM   #276
69cunningham
69cunningham's Avatar
Re: Lss3
I installed the Mar-K hidden latches. Drilling all the holes and cutting the slots was tricky. I made a wooded jig to position the 5/8” hole. I didn’t want the hole saw to wander. A couple of wedges and a C clamp held the jig in place.
69cunningham is offline   Reply With Quote
Old 01-23-2021, 06:51 PM   #277
69cunningham
Re: Lss3
More work on the circuit breaker panel. I made a cover out of Delrin to protect the copper bus bar. I didn’t want a tool to be able to short the battery to ground.
Old 06-11-2021, 07:57 PM   #278
May70
May70's Avatar
Re: Lss3
Just saw this build, 5 months since the last post, time for an update!!
70 C20 Build link : Project Montezuma
http://67-72chevytrucks.com/vboard/s...d.php?t=794479
How to repair that rusted out 67-72 c10-c30! Please subscribe!
https://www.youtube.com/c/MaycoCustomRestorations
May70 is offline   Reply With Quote
Old 06-11-2021, 08:22 PM   #279
69cunningham
Re: Lss3
You are absolutely right that I should do an update, but I haven't accomplished much lately. My goal is to get the electrical panel installed and the wiring hooked back up so I can start it again. Wish me luck.
Old 12-27-2021, 11:35 PM   #280
69cunningham
Re: Lss3
For three Christmases in a row, I have gotten parts for the bed. First were new bed sides. The next year was the tailgate. This year I got wheel tubs from DAN CARPENTER'S SPECIALTIES. My wheels just barely fit without the tubs. They might rub going around corners. There would be no room for larger wheels without the addition of the tubs. The time to add tubs is before paint.
Old 12-29-2021, 05:16 PM   #281
May70
May70's Avatar
Re: Lss3
Those are some fancy tubs!
Old 12-29-2021, 10:23 PM   #282
dnd1978
dnd1978's Avatar
Re: Lss3
Great build. I enjoyed reading though it. Great fab work.
________________________________
1972 SWB stepside pro tour build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=452840
dnd1978 is offline   Reply With Quote
Old 05-14-2022, 03:01 PM   #283
69cunningham
Re: Lss3
Added notches to the tailgate for the MarK stainless steel links. Before cutting, I added plug welds every 2 inches along the cut line since many of the original spot weld get removed by the notches.
Old 05-16-2024, 11:45 PM   #284
69cunningham
Re: Lss3
Here is my electrical panel mounted to the radiator support. Things are a bit dusty.
