Old 05-06-2016, 11:34 PM   #276
84 Beast
Re: 89 GMC Cummins conversion
Ya, can completely understand the family obligation deal, that's part of the reason its takes me so long to reply.
Good looking truck BTW.
Got a few questions for ya.
I read thru the thread and there was some brief conversation on wiring up the stock vp44, but am still confused. Not sure if you can shed some more light on how it should be wired up.
I was gonna pull the harness off mine, lay it out on the floor, and snap a picture to hopefully help the cause. I got my motor from a wrecking yard so its fairly complete up to the fuse panel and hydroboost braking system.
The other question is that I am running a 47re, will I need a controller similar to the one your using?
The help is much appreciated.
Pics are of my attempt to place the engine on stand, need to replace oil pan as it got smash at the wrecking yard. Just gonna do it on the cherry picker
84 Beast is offline   Reply With Quote
Old 05-07-2016, 02:39 AM   #277
COS399
COS399's Avatar
84 Beast - I responded on your Cummins Help thread on how to wire up your VP44 fuel pump relay.
I just realized that I didn't give you the internal regulator part number if you decided to go with the first gen. alternator. The part number for it is: C8315 or IN8315 depending on what brand you buy. Good luck with your project and thanks for the compliment.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-07-2016, 02:43 AM   #278
COS399
COS399's Avatar
Here is some information on the wiring to wire in a relay to the VP44 pump to make it start up and run. On the rear of the engine, up near the valve cover, are two quick connect plugs. One has 11 wires and the other has 14 wires. These two plugs are the main wires that I used for my build. I did have to tap into the Injection Pump harness for a Throttle Position signal for my PCS transmission controller.
Purchase a 12 volt relay and the wiring pigtail that fits it.
Connect a fused (5amp) and switched 12V power source to the #1 pin (Green with black tracer) on the 11 pin connector. This is Ignition switch signal.
Connect a constant 12V supply to the #3 pin (Red with white tracer) on the 11 pin connector.
Connect the 87 terminal on the relay to the #7 pin (Red with Light Green) on the 11 pin connector.
Connect the 86 terminal on the relay to the #8 pin (Brown and white) on the 11 pin connector.
Connect the 85 terminal on the relay to negative/ground
Connect the 30 terminal on the relay to positive/12volt
After that, if you have the fuel hooked up and the starter hooked up you can just turn on your VP44 switch and then the jump the starter solenoid to fire it up. Turning off the VP44 switch (pin 1) will shut it off.
I tried to attach some PDF files that show all this but they were too large. PM me your e-mail address and I can try and send them to you direct. Hope this helps you and anyone else that has a 24 valve VP44 project.
Old 06-04-2016, 07:17 PM   #279
COS399
COS399's Avatar
This post comes with sadness and joy. I have sold my 1989 and hauled it to it's new owner last week. The trip down there was filled with some nasty weather. We barely missed a hail storm just east of Denver and in SE Colorado we passed through the aftermath of high wind and/or a twister.
Diesel Wrencher - I posted the Ford pic after reading the comments on your post. lol
Old 06-04-2016, 07:22 PM   #280
COS399
COS399's Avatar
Four semis and a travel trailer blown over. My boy got a picture with a small twister coming off the edge of storm cloud.
Old 06-04-2016, 07:33 PM   #281
COS399
COS399's Avatar
And here is what I hauled back. A '96 12V P-pump, NV4500, 2wd single cable and an extra first gen 12V with an Automatic transmission for a 4wd. The extra engine was welded to the back of the frame and caused a few people to do a double take.
The new owner of my '89 is a forum member but I'm not sure that he will post anymore information on it.
Old 06-04-2016, 07:35 PM   #282
MTCK
MTCK's Avatar
Ah bummer! Sad to see it go and hope you did good on the $ale.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 06-04-2016, 07:41 PM   #283
COS399
COS399's Avatar
I lost some money but gained a lot of valuable experience building it.
Old 06-05-2016, 01:30 PM   #284
collect t/as
It will be enjoyed and taken care of.
collect t/as is offline   Reply With Quote
Old 06-05-2016, 07:57 PM   #285
6BT 56
6BT 56's Avatar
So what are the plans for the new truck ? Is it just a driveline donor ?
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 06-05-2016, 11:45 PM   #286
collect t/as
It will enjoy it's new 12 valve sibling.
Old 06-06-2016, 12:02 AM   #287
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Man, looks like you got lucky missing those storms! Love the ol ford, and look at her doing work. I'm anxious for you to get on the next project! What's the story on the trans am gmc? Obviously has a 6 cylinder. Haha
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-06-2016, 12:36 AM   #288
COS399
COS399's Avatar
Yep, that's the plan. I will have to post in the "Alternate Tinkering" section since it's an International. I am picking up a one owner 1981 GMC Jimmy 4x4 in the next couple of days and see if my boy has any interest in it. So, I may have two projects going.
Old 06-06-2016, 12:46 AM   #289
collect t/as
Talking Re: 89 GMC Cummins conversion
http://67-72chevytrucks.com/vboard/s...d.php?t=679352
Old 06-06-2016, 12:47 AM   #290
COS399
COS399's Avatar
I was going to give you the link but he already replied.
Old 06-07-2016, 06:55 PM   #291
Dieselwrencher
I would just post it in here. I've put ford swaps in here.
Ryan
Old 07-31-2016, 02:00 AM   #292
collect t/as
I got the windows tinted today. Small progress but a big improvement in my opinion.
Old 07-31-2016, 03:10 AM   #293
MTCK
MTCK's Avatar
Looks good, and it stayed in the family!
-Marcus
Project Plow Truck
Old 07-31-2016, 07:02 PM   #294
COS399
COS399's Avatar
Looks nice.
Old 08-04-2016, 01:21 AM   #295
whitels1
whitels1's Avatar
I was so sad that you sold this truck I could not post, but now that I see it stayed in the family, I'm stoked! The truck looks great!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 08-04-2016, 07:48 PM   #296
COS399
COS399's Avatar
Thanks. I'm sure he will keep us updated as time goes on.
Old 08-08-2016, 06:35 PM   #297
Dieselwrencher
That sure does make it look tough IMO. Very nice. I bet you really need it down there too.
Ryan
Old 08-12-2016, 01:09 AM   #298
collect t/as
You tell someone from Texas that it came from the factory with A/C delete & they look at you like you're speaking Chinese!
