02-18-2015, 09:27 AM | #276 |
Re: Parting out 72 GMC K20 4x4 350-TH350
Oh boy, now I don't know which crank pulley I need. I will definitely take the short water pump pulley and probably the 2 groove cast. Did the 72 use cast though? Also, in that above pic, is that a new parts truck? If so, how much for the door mirrors? :-) I'll let you know later today about the rest of the parts. I could also use the wiring for gas tank and dome light
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
02-18-2015, 08:26 PM | #277 |
Speedometer cable?
Ralph L. Jasper 69 4x4 Suburban PTO winch(NAVY) 13 GMC Ext cab 12 Ford Fusion SE(wife) MAI Interior shop |
02-19-2015, 02:58 PM | #278 |
Tom, I will take the water pump pully, the 2 groove crank pulley, driver side alt brackets ( I bought a set a few weeks back from another member, but I gave up on ever receiving them), 2 seat belt bolts (if you have 2) a price on those mirrors, if they are for sale, along with price for wire for fuel tank sender and dome light, if you have them. I'll pass on the seat belts and shroud for now. Funds are a little tight. Let me know. Thanks
02-20-2015, 01:46 PM | #279 | |
When would this frame be available? and what is the rearend ratio? I may need a 3.73 posi rearend if you have it? or just a 4x4 rear end in 3.73
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-22-2015, 02:38 PM | #280 |
I no longer need the pulleys or alternator brackets, but if you have the mirrors and wires mentioned in my previous post, I'm interested. I do still need the upper alternator bracket though. Just not the lower
02-22-2015, 06:56 PM | #281 |
I'm looking for the long tie rod connecting tube the goes between the left and right tie rod ends. It's tapered and threaded on both ends. Shipped to 06801 please. Thanks
72 Shortbed, fleetside, 4x4, 307,4spd. 55 second, 350, 4spd, almost done 77 K-20, 454, 4spd, plow truck 96 K-1500, 6 inch lift, 178k still going strong |
02-23-2015, 02:23 AM | #282 |
do you have any ac compressor mounting brackets for 350 its for my 72 k20,
02-24-2015, 09:04 AM | #283 |
Hi, any chance you have a pair of fleetside wheel tubs?
Thanks Eddie |
02-25-2015, 02:11 AM | #284 |
"Junkyard Dog"
Guys, just home from the Daytona 500. My wife and kids surprised me with a trip to Daytona for my 50th birthday. Just home today and I will respond tomorrow. Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process. http://s289.photobucket.com/albums/l...t=7eae161e.pbw 88 Monte Carlo SS bought new only 10k miles. 73 Chevelle SS 454 had since high school. 74 Camaro Z28 350 AT numbers matching, Black on Black. 73 El Camino SS 350 4sp. 70 Chevelle SS 396 4sp, number matching with LS6 454 69 Chevy C30 Car Hauler 86 K20 383 4sp 4" lift frame off restoration. http://s289.photobucket.com/albums/l...t=1b1082d3.pbw |
02-25-2015, 09:42 PM | #285 | ||||||
"Junkyard Dog"
For a 4x4? If so 25.00 plus shipping. Quote:
Yes that is a parts truck. Thanks, Tom
02-26-2015, 12:34 AM | #286 |
Sounds like a great present.
I am interested in the frame. Can you please find out the rearend gear ratio and the rear spring length eye to eye measured along the spring?
02-26-2015, 03:24 PM | #287 |
do you have the upper radiator mounts? If you do are they 4 core mounts? If 4 core mounts what would you want shipped to 48326
02-26-2015, 08:30 PM | #288 |
hope you had a nice time for your bday, not for some business. do you have a transfer case shifter bracket that goes on the muncie 3 speed? with divorced transfer case...
02-26-2015, 11:58 PM | #289 | ||
"Junkyard Dog"
Yes, had a great time. All pleasure and enjoyed every second! Maybe, I have a adapter floating around. It would be monday before I could look.
02-27-2015, 12:57 PM | #290 |
Hey looking for the power brake conversion with firewall mounting bracket u still have it ?
Shipping 98295? Thx |
02-27-2015, 08:31 PM | #291 |
Hi, same as post #120. (4) 6 lug steel wheels that fit disc brakes to 27546.
Thanks |
02-28-2015, 10:47 PM | #292 |
"Junkyard Dog"
Ok..the ratio in this truck is 3.07. The spring eye to eye center is 52 inch or very close to that. I checked 3 other 4x4 trucks and they all measure the same. I could build a fully rebuilt 3.73 rear assembly. JLMK Thanks, Tom
02-28-2015, 10:56 PM | #293 | ||
"Junkyard Dog"
Thanks, Tom
02-28-2015, 10:56 PM | #294 |
I have 3.73 in my suburban and would you interested in swapping gears? I prefer 3.07
03-01-2015, 01:32 AM | #295 | |
Thanks Scott.
03-01-2015, 02:15 AM | #296 | ||
"Junkyard Dog"
Thanks, Tom
03-01-2015, 02:27 AM | #297 |
Tom. How hard is it to relocate the rear spring perches? Does the frame you have already have holes for the longer spring? Not sure if you know are not.
Thanks again Scott
03-01-2015, 08:58 AM | #298 |
Mine is 4wd and what would be your total to 39503? And is a posi right?
03-02-2015, 01:45 AM | #299 | ||
"Junkyard Dog"
Thanks, Tom
03-02-2015, 01:24 PM | #300 |
Thanks for the response Tom
My sons truck is a 1968 but the rear spring length was 56" so I ordered the lift for this frame. I will measure the spring again as it has been a little while. I thinks the spring eye to center pin was 28". Another question is what is the price on the/a 4x4 rear axle? Thanks Scott
