Old 11-04-2020, 07:59 PM   #276
nlped
nlped's Avatar
Re: Walter DeWayne...Walt for short
Got him split back apart. I’m going to get all the plumbing in place on the chassis, ie: brake, fuel & air lines. I also decided that the current trans crossmember was NOT going to work with the chevelle headers and the PorterBuilt dropmembers. So, I got an eBay special and it appears to be exactly what I needed to keep the exhaust tucked up tight.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-05-2020, 11:28 PM   #277
nlped
nlped's Avatar
No pictures but I got the high pressure fuel filter mounted. The lines to and from the Boyd EFI tank are made. The rear brake line is mostly made and the new transmission crossmember is finalized. Then I’ll get the airlines run. I’ll have to pull the motor and trans to get the front brake lines built. Then full disassembly and paint of the frame followed by final reassembly of the rolling chassis.
Carter
Old 11-06-2020, 10:42 AM   #278
SCOTI
SCOTI's Avatar
Trans x-member looks decent. Source details?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-07-2020, 01:50 AM   #279
nlped
nlped's Avatar
Scoti, the eBay item # is 184197152581. It’s listed as a 73 up application, but it fits fine, width wise. I just had to drill four holes as the bbc & 700r4 with the PorterBuilt dropmember didn’t line up with the oe holes.
Carter
Old 11-07-2020, 02:09 AM   #280
SCOTI
SCOTI's Avatar
Thanks for the info. I have a couple of the PB trans x-members in a corner as I've used different options that I felt were more robust.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-15-2020, 05:53 PM   #281
nlped
nlped's Avatar
I keep looking at this project and thinking that I’m kinda uncomfortable with it. I really believe I’m going to sell the entire rolling PorterBuilt chassis minus this built rearend & brakes (and motor, trans & fuel system of course). Then just build Walter as a static drop with EFI big block, overdrive and big brakes. I really am to damn old for all this airride, fancy suspension stuff. I just wanna drive Walter.
Carter
Old 11-15-2020, 10:50 PM   #282
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I agree, Walter is cool but a fun driver and less work is going to be wonderful!!
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 11-15-2020, 11:56 PM   #283
SCOTI
SCOTI's Avatar
Nothing wrong w/that option either.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-16-2020, 01:19 PM   #284
TA_C10
TA_C10's Avatar
You certainly don't want to get done and not be happy with it. Either way, it's gonna be cool truck
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 11-22-2020, 09:00 PM   #285
nlped
nlped's Avatar
I suck at staying focused...
Carter
Old 11-22-2020, 11:46 PM   #286
cornerstone
cornerstone's Avatar
SQUIRREL!!!
I can't blame ya man. A nice 2002 is hard to come by.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 11-22-2020, 11:56 PM   #287
nlped
nlped's Avatar
Originally Posted by cornerstone View Post
SQUIRREL!!!
My thoughts precisely. It had been sitting since 2009. 1994 2 years before that. Empty the gas tank, new gas and a battery...drove it on & off the trailer.
Carter
Old 03-17-2021, 04:46 PM   #288
nlped
nlped's Avatar
Okay, I have been terrible at staying focused on Walter! I have finally split him back apart and started on brake, fuel and trans cooler lines. The trans cooler setup is done, the rear brake hard line is run from the crossmember to the firewall location and the fuel lines & filter are run up to the motor, but not finalized as I used the Holley Sniper setup on my 63-1/2 Falcon . So, I will be purchasing another Sniper EFI setup and I am going to go ahead and get the Sniper specific distributor, coil and ignition box so I will be able to control the timing like I have on the Falcon. Once I get that done, I will work on getting the air lines run.
Maybe, just maybe, I will stay focused this time. Sucks not having help or more motivation
Carter
Old 03-17-2021, 05:18 PM   #289
SCOTI
SCOTI's Avatar
You're not alone on that boat.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-17-2021, 07:55 PM   #290
regan wilson
regan wilson's Avatar
Stay focused. No Skewrls! The BMW can wait. Walt needs your attention.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 03-18-2021, 10:47 AM   #291
Chevys4life
It seems like all car guys have the focus problem when they have several projects. Some times it's good to take a break from the project and then go back as long as it isn't too long!!!!
Chevys4life is offline   Reply With Quote
Old 05-31-2021, 12:16 AM   #292
nlped
nlped's Avatar
Almost sold Walter and all his related parts for a fair’ish price. But, I realized very quickly that I’d never be able to replace him, much less build one like I’ll have when I finish this build. Walter is staying home!!! (Unless somebody offers better money...).
Carter
Old 05-31-2021, 09:04 AM   #293
Ol Blue K20
I hope Walt couldn't hear you talk about selling him!
Dale
Old 08-10-2021, 10:29 AM   #294
slowcpe
slowcpe's Avatar
Understand the motivation and distractions I haven't logged in here in a while and went back and re-read my Chester build thread and I've been debating engine swaps for 3 years now Since I've last been on here I've upgraded my daily 2x, sold my sxs and bought another boat. The only good thing is my truck is still running and driving, it just loses bodily fluids regularly and makes funny noises.
I started to think about selling my truck over the last month for something completely different. Took the truck to dinner 2x this past week and now I'm logged back in ready to dive into it again. Now I need motivation to stay on it.
Love the BMW btw.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 08-10-2021, 08:43 PM   #295
nlped
nlped's Avatar
I have actually been working on Walter some lately. I took the motor to a friends place and put it on the engine dyno. It made 524hp/558tq with the complete Sniper EFI setup. Horsepower was over 400 by 2500 rpm & the torque was over 500ft/lbs from 2100 rpm to redline. It’s should do just fine in an ole truck. 😬
Carter
Old 08-10-2021, 11:36 PM   #296
Ol Blue K20
That should be wicked! Probably sounds great too.
Dale
Old 08-11-2021, 09:21 AM   #297
SCOTI
SCOTI's Avatar
Did you have the motor specs in the thread? If so I'll re-read. If not, I'd be interested in knowing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-11-2021, 10:56 AM   #298
lunatic1968
I just found this thread. Beautiful truck and a cool build. I subbed.
lunatic1968 is offline   Reply With Quote
Old 08-11-2021, 10:34 PM   #299
nlped
nlped's Avatar
Oh, it sounds beastly!
It a weird build. I bought a $1500 ‘67 open road camper. When I showed up to buy it, it had been vandalized, but the box full of receipts included a $10k 468 motor build. It turned out to be super low mileage build that just sat. I pulled oil pan, intake, and valve covers. Forged crank, H-beam rods, forged pistons (part # depending on actual chamber size is 9.7 to 10.1’ish), Edelbrock RPM intake & cam, good oval port heads and so many other unexpected parts. I refitted bearings, oil pump, timing chain etc and added the Holley Sniper EFI. It’s a beast, for an ole truck 🤣
I’m proud of Walter for sure. Thanks for tagging along
My plan is running, driving and GoIng by 2022
Carter
Old 08-12-2021, 09:49 AM   #300
SCOTI
SCOTI's Avatar
Ok.... The info sounds familiar so I probably did read it here. My BBC in the RetroRod is similar in build nature but it was built w/a solid flat tappet cam (this was around early '90) w/ported ovals that flowed what the aftermarket Merlins did @ the time. It was a decent low buck deal).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
