Old 02-18-2017, 09:15 PM   #276
daddyjeep
daddyjeep's Avatar
Re: Daddyjeep Hauler - 85 K30 crew cab short bed
I got the hood primed and painted since it was an absolutely strange 60 degree February day in Pennsylvania. It looks terrible, but I just need to get it in paint and will finish it up later. I started with some Duplicolor self etching priner then shot some Krylon flat white.
[IMG][/IMG]
[IMG][/IMG]
Now, I need some opinions. With the hood emblem...
[IMG][/IMG]
or without?
[IMG][/IMG]
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 02-20-2017, 11:12 AM   #277
Hewfil1
Hewfil1's Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
or without?
[IMG][/IMG]
I personally like it without the emblem, and yeah this PA weather these last two days have been weird!
Hewfil1 is offline   Reply With Quote
Old 02-20-2017, 11:44 AM   #278
COS399
COS399's Avatar
My preference would be to remove the emblem. I think it would be "too busy" looking with it. IMO
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 02-20-2017, 12:02 PM   #279
MTCK
MTCK's Avatar
X3 no emblem in my opinion.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 02-20-2017, 01:56 PM   #280
daddyjeep
daddyjeep's Avatar
Thanks for the opinions guys. I think I have to agree. It gets a little busy with the emblem on there.
04 1500 crew cab
Old 02-20-2017, 05:03 PM   #281
87max
87max's Avatar
no emblem, I'm close enough to the lake the temp drops ten degrees here. Go a mile south and it's like flipping a switch but I'll take it. My maple trees are budding its crazy.
87max is offline   Reply With Quote
Old 02-21-2017, 11:12 AM   #282
Hewfil1
Hewfil1's Avatar
Our lake was still frozen over even during this weird weather.
Old 02-21-2017, 12:13 PM   #283
moregrip
moregrip's Avatar
looks tough as all hell!!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 02-22-2017, 07:38 PM   #284
abner36
abner36's Avatar
man the hood looks killer!! Can't wait to see it all done! I have to agree with the others with no emblem.
abner36 is offline   Reply With Quote
Old 02-25-2017, 02:11 AM   #285
daddyjeep
daddyjeep's Avatar
I finished sanding the passenger side rockers finally and shot on some self etching primer. I am real happy with how the transition from the front rocker to the rear came out.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 02-25-2017, 02:32 PM   #286
MTCK
MTCK's Avatar
Looks great. Nice work. What are you going to tackle next?
-Marcus
Project Plow Truck
Old 02-25-2017, 03:34 PM   #287
daddyjeep
daddyjeep's Avatar
I suppose I need to put an interior together next. Then exhaust.
I shot some flat white Krylon on the rockers and started putting in some Home Depot sound deadener. I just bought one 7" x 25' roll to see how it works. It is not sticking too well, but the shop is a little chilly. I'll go over it for a bit with the heat gun and see if it holds better. the one roll covered a little over half of the passenger side floor.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 02-27-2017, 08:57 AM   #288
NastyBuzzard
NastyBuzzard's Avatar
Is that the tar backed stuff? I am searching for sound/heat deadener for my crew. So far Fatmat seems like the best choice. $150 for 100sq ft and comes with the "install kit."
1988 GMC R3500- Cut Brothers 4WD Conversion Kit, 6.5 TD NV4500/NP208 D60 14BFF
2020 1500 Silverado 3.0 Babymax
2002 2500 Silverado- 6.6/ Allison
2010 CTS V- The "NastyBuzzard"
1979 Trans Am - Eventually getting 6.0/T56 swap with boost
NastyBuzzard is offline   Reply With Quote
Old 02-27-2017, 02:05 PM   #289
daddyjeep
daddyjeep's Avatar
I was trying to find what I used on the Home Depot site, but couldn't. I have to tell you, based on your earlier comments about the stuff, the first thing I did when I found it in the store was cut the packaging and smell it. I found no tar odor. I will get more info up when I buy more.
04 1500 crew cab
Old 03-01-2017, 02:16 PM   #290
daddyjeep
daddyjeep's Avatar
Since I need more material to continue with the interior, I did a little patch work on the rear door. I really didn't want to spend much time on the doors as I would like to get some better doors, but here we go. For the time being I am working with what I have.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 03-09-2017, 12:50 AM   #291
daddyjeep
daddyjeep's Avatar
Passenger side rear door is good enough for now. It needs lots more sanding before it is done, but no time for that quality yet.
[IMG][/IMG]
[IMG][/IMG]
04 1500 crew cab
Old 03-19-2017, 06:52 PM   #292
daddyjeep
daddyjeep's Avatar
[IMG][/IMG]
I finally made it back to home depot to get the rest of my sound deadening. Not much progress on the truck because I have been trying to finish up my logging project in the back yard.
04 1500 crew cab
Old 03-20-2017, 02:36 PM   #293
whitels1
whitels1's Avatar
Awesome work, keep at it!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 03-21-2017, 12:57 PM   #294
daddyjeep
daddyjeep's Avatar
Now that I have completely destroyed my back yard...
[IMG][/IMG]
Maybe I can get back to the truck.
04 1500 crew cab
Old 03-21-2017, 01:09 PM   #295
MTCK
MTCK's Avatar
Nice! That's a good chunk of firewood.
-Marcus
Project Plow Truck
Old 03-21-2017, 02:03 PM   #296
daddyjeep
daddyjeep's Avatar
Those logs are getting sold. I haven’t started on the firewood yet.
04 1500 crew cab
Old 03-22-2017, 09:04 PM   #297
daddyjeep
daddyjeep's Avatar
After splitting wood for a couple hours after work I actually got a little done on the truck. I finished sound deadening the passenger side floor. I found out that a light coat of 3M super 77 really makes this stuff stick.
[IMG][/IMG]
04 1500 crew cab
Old 03-23-2017, 08:35 AM   #298
NastyBuzzard
So I was looking at this U.Seal stuff.. So basically a 25' roll is around $17-$20 for what I am seeing. 25' roll that is 6" wide is only 12.5ft^2. So lets say it takes 100ft^2 to do the crew cab, that means you need 8 rolls of the stuff, which comes out to about $140. So if that's true, fatmat is $149.99 for a roll of 100 sq ft and comes sticky backed with tools to install it. I am not sure if the U.seal makes it easier being in small strips or not. Still trying to determine what route I take but your crew is looking good!
Old 03-23-2017, 12:56 PM   #299
daddyjeep
daddyjeep's Avatar
Math doesn't lie my friend. It probably does make sense to just buy the proper stuff from fatmat for that nominal price difference. I suppose there are advantages of the thin strips in some areas, but some scissors can make a wide strip into a thin strip pretty easily. The U-Seal is adhesive backed, but does not stick well when it is cold. When I hit it with the heat gun it stuck nice and tight. I didn't bother getting a fire going in the shop so it was only about 40 degrees and it did not want to stick well at all.
04 1500 crew cab
Old 03-23-2017, 11:13 PM   #300
75Dually
75Dually's Avatar
I just went through you entire build. That truck is going to be fun! I really like the hood. Good to know there is another guy out there who likes to shape metal!
Can't wait to see it on the road!
75Dually is offline   Reply With Quote
