01-06-2019, 10:04 AM | #3001 |
Re: PO has me PO'd
Jaros, I just want to say I appreciate your consistency. As a guy that works in fits and starts, I love seeing people making regular progress! How far are you from running and driving this rig?
My LS Swap: http://67-72chevytrucks.com/vboard/s...d.php?t=718573 |
01-07-2019, 05:02 PM | #3002 | |
Re: PO has me PO'd
Secondly, I have no idea or plans for that outcome, other then a anniversary coming up in June20th for a celebration of the brand in Harrisburg, Pa. Hope I don't have to trailer it there, EMBARRISING, but, I do want to install a dry sump system, next on the list of to dos Fits and starts should be my montra Just walked out of court, beat a speeding ticket for 55mph in a 25mph work zone, pulled the marine corp card and he said" sempre fi"
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-08-2019, 03:42 PM | #3003 |
Re: PO has me PO'd
[url=https://flic.kr/p/23u9Kfg]20190108_113522
[url=https://flic.kr/p/2cZz3sj]20190108_113545 secret santa was my daughter in law
01-12-2019, 07:54 AM | #3004 |
Re: PO has me PO'd
[url=https://flic.kr/p/23yjDy2]20190112_064458
sorta ol school....reminds me of my sun tach mount in the '62 chevy [url=https://flic.kr/p/2cLVkzV]20190112_064550 Never heard of a 1/2-150, so looked it up on the www, seems to be a schedule 40 pipe
01-18-2019, 09:54 AM | #3005 |
Re: PO has me PO'd
still searching for the right position to mount gauge. using the heater control mount screw (1/4-20) I put a hex drive stud in it with a flange nut.
DON'T use slotted screws that come with the mounting kit, the screw driver will slip and gouge the mount or worse yet your dash I think I will try to use the other mounting screw for the heater control, since this location looks like it may cause problems with my shifter [url=https://flic.kr/p/2egy1VX]20190117_102220
01-24-2019, 10:22 AM | #3006 |
Re: PO has me PO'd
[url=https://flic.kr/p/23F5Fun]20190118_09531
pic of hex drive 1/4-20 studs [url=https://flic.kr/p/2ejmBqq]20190124_090907 [url=https://flic.kr/p/2cUMoY6]20190119_095013 Had to machine a slot in the bracket for clearance of serrated flange nuts looking for my stepper bit to drill pan for weldless bulk head fitting
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-24-2019 at 10:32 AM. |
01-28-2019, 12:37 PM | #3007 |
Re: PO has me PO'd
Started to work on my seat mounts(utility) PS
had to locate hole with a punch, used starter bolts and lube [url=https://flic.kr/p/2eoiHVm]20190128_093516 [url=https://flic.kr/p/2dmRq3A]20190128_093452 Have to make up some seat mount plates, one stripped, two non existant for rear of seat brackets...DS
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-28-2019 at 12:43 PM. |
01-28-2019, 12:46 PM | #3008 |
Re: PO has me PO'd
01-28-2019, 01:25 PM | #3009 |
Re: PO has me PO'd
boy that truck is getting some serious love .... nice job in getting it together
dont want to hear excuses, i want to hear solution(s) |
01-29-2019, 08:54 AM | #3010 |
Re: PO has me PO'd
Thanks, up to this time, everything was just a mock up, now, problems have to be solved and final fitment needs to happen. Soooo, that is what is taking place, wish me luck going forward
01-30-2019, 10:36 AM | #3011 |
Re: PO has me PO'd
as you can see the angle of the sport buckets have the angle wrong, so it will have to be the utility seat bracket, the keeper bracket is not on the ps, and when done will raise the seat up about 1 1/2"
[url=https://flic.kr/p/2dnVHef]20190129_103844 [url=https://flic.kr/p/23SvT4D]20190129_103358
01-30-2019, 10:41 AM | #3012 |
Re: PO has me PO'd
01-30-2019, 11:41 AM | #3013 |
Re: PO has me PO'd
[url=https://flic.kr/p/23TtUdk]20190130_101754
[url=https://flic.kr/p/23TusBP]20190130_103005 taking bolts out, 2 snapped sounds like they may break, so put studs in, will reinstall with lock tite, easy enough to put a torch up there to break bond if need be X is where the fitting goes, pretty big cavity in trans [url=https://flic.kr/p/SmNpbA]20190130_102840 backing plate,
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 01-30-2019 at 11:49 AM. |
01-30-2019, 12:18 PM | #3014 |
Equal opportunity joke ofender
Re: PO has me PO'd
They look like McMaster packages
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
01-30-2019, 06:15 PM | #3015 |
Re: PO has me PO'd
They're great aren't they, one day to my door, if it is in stock. any fastner I can think of! probably should have gotten 12 point, oh well next order
01-30-2019, 09:38 PM | #3016 |
Re: PO has me PO'd
02-01-2019, 11:00 AM | #3017 |
Re: PO has me PO'd
I like to use a live center when tapping, keeps the threads in proper alignment
[url=https://flic.kr/p/2d8Ugv8]20190201_084147 while raceting tap Also, I like to use a rachet tap handle, pulling down on the quill , and rotate cw with tap [url=https://flic.kr/p/2d8Ugv8]20190201_084147
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-01-2019 at 12:09 PM. |
02-01-2019, 12:12 PM | #3018 |
Re: PO has me PO'd
02-03-2019, 09:12 AM | #3019 |
Re: PO has me PO'd
[url=https://flic.kr/p/2exFCA4]20190202_11
had to find the holes [url=https://flic.kr/p/2d9Vv6B]20190202_111148 Inside mout was hard to hold so I added a 1/4-20 stud in the center
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-03-2019 at 09:17 AM. |
02-03-2019, 09:23 AM | #3020 |
Re: PO has me PO'd
02-03-2019, 10:37 AM | #3021 |
Re: PO has me PO'd
02-04-2019, 09:33 PM | #3022 |
Re: PO has me PO'd
whiskey :30 or whiskey tango foxtrot
[url=https://flic.kr/p/2eAd9Kv]20190204_201344 [url=https://flic.kr/p/2evBvzS]20190204_201429 [url=https://flic.kr/p/2dcrRac]20190204_20163
02-04-2019, 09:52 PM | #3023 |
Re: PO has me PO'd
Bottoms up..Jim
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
02-06-2019, 05:17 PM | #3024 |
Re: PO has me PO'd
Thanks Jesse
Decided to put on the seat backs, ss#10x 3/4" screws, I hate phillip head screws, ordered some square drive today from Mcmaster Carr I watch a show on Utube and he says to wax paint and rusty metal with tolette bowl wax(new) ring . So for 6.00 , I thought I would try it on my seat backs. Keeps the patina I was looking for, but protects the metal from further rust [url=https://flic.kr/p/2dvKjEu]20190206_085314 pics don't want to load
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 02-06-2019 at 05:34 PM. |
02-06-2019, 07:13 PM | #3025 |
Re: PO has me PO'd
