Old 03-29-2011, 07:41 PM   #3001
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Re: Project Vitamin C-10
This was a couple nights ago.
I installed the throttle linkage and pedal, but they don't line up. It was late and I haven't studied it. My guess is the studs for the pedal are in the wrong place. I replaced the floor in that area and drilled the holes for the studs without thinking.
I knew this would be a problem since the engine was moved forward.
New seals for the cowl vents.
In process. It took maybe 15 minutes to do one vent. It's not hard just have to take some time. The seals could tear easily.
Finished
Also realized tonight that the little chrome piece on the vent window where the window locks closed is removable. I never really paid much attention to it.
Alan's Classic is offline   Reply With Quote
Old 03-29-2011, 09:36 PM   #3002
flips72
flips72's Avatar
looking good alan, you make things look to easy, as far as the accelerator assembly, ever thought about using a 72 cable style, pretty sure thats where im going with mine when i start on the cab.
flips72 is offline   Reply With Quote
Old 03-29-2011, 09:44 PM   #3003
Strodder
Daring to be Different
Strodder's Avatar
Originally Posted by Alan's Classic View Post
[COLOR="Blue"]If your spraying clear make sure you have a clear only gun if money permits. No matter how well you clean your gun something will come out and it won't be the same color as the base coat. /COLOR]
Thanks Allan, but your too late. I cleaned the gun really good too.
I painted my Roadstar bags, trunk and Batwing Fairing silver and black. When I cleared over it all the black had metallic in it. It kinda looks good that way, but it's not what I wanted. Looks like I did it on purpose. So I had it pinstriped anyway.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 03-30-2011, 08:25 AM   #3004
Alan's Classic
Thanks, and no I never considered it. I should have before I sprayed the cab. I was looking at it last night and believe it will be an easy fix.
Nice bike you have there. Do you have a clear only gun now?
Old 03-30-2011, 10:44 AM   #3005
Strodder
Strodder's Avatar
Thanks Allan, No but before I paint again I will.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-30-2011, 02:17 PM   #3006
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Alan quick ? I sprayed my s10 bed about 4 years ago. I did about 3 coats of black, and then 2-3 coats of clear. And yes I only used one gun.
The end of last year my clear started to turn white and flake in spots. I followed the directions to the T. What do you think would be the cause. It's going to get redone, and I'll get another gun. I'll probably do a flat though in the clear.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 03-30-2011, 02:53 PM   #3007
Alan's Classic
What brand of paint were you using? Was it base coat or single stage black? I've seen people including myself spray a single stage let it dry and color sand it and then clear it. Makes for a deeper shine. How long did you let the base coat sit before clearing? Did you spray it in a booth or outside? Just trying to get more info before I make up an answer. J/K I was talkiing to the painter at work about it and these are the questions he asked me.
Old 03-30-2011, 05:13 PM   #3008
ruffrida2005
I think it was a duplicolor base and clear. I think I picked it up from Orielly's because the bed and cab were diffrent colors.
I think I waited 5-10 min between the base and clear. And I did it outside, so I know I got crap in it because I got a bunch of orange peel.
And make up a good answer I wanna hear it!
Paul
Old 03-30-2011, 09:04 PM   #3009
Strodder
Strodder's Avatar
Question, do you put catalyst in the base coat? I was told you don't have to. And another lesson I learned is DO NOT COLOR SAND METALLIC BEFORE CLEAR COAT. I learned the hard way.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 03-30-2011, 10:13 PM   #3010
Alan's Classic
I'm not saying duplicolor is a bad product, because I don't know for sure. I sprayed my first car with something along that line. I didn't want to spend a bunch on my first paint job. Not saying duplicolor is cheap. It was red when it went on and within a year it was orange. This was 20 years ago. I know PPG has a UV protector in it, duplicolor may not. I spray outside sometimes and works great. As long as there aren't any big temp changes. I like spraying early in the morning when the wind is calm and no bugs. I leave the car inside over night taped up and roll it out in the am. MY real concern is if there was a heavy dew.
With PPG base coat is reduced with reducer no catalyst required. It dries quick.
I learned that lesson as well not sanding metallic base before clear. I used 400 out of habit to sand a bad spot out. That made the metallics lay a different way than the rest. The painter said I should have used 2000.
Old 03-31-2011, 09:15 PM   #3011
Alan's Classic
I picked the headlight bezels up yesterday. $5ea.
I'm confussed right now. I've been blocking on my bed and consider myself a good mud man. I've blocked my left bedside several times and thought it was good enough to prime. I even blocked it with 320 with no problems. i was running my hands over it yesterday and found a major problem. I have my suspitions of what happened, but won't mention it here. I blocked it out with 80 and 180 today and ready for primer again in that spot.
Old 03-31-2011, 10:27 PM   #3012
XtechX
XtechX's Avatar
Alan, I sent another email to verify paypal...Thanks
Opportunity usually comes disguised....As hard work!!!
XtechX is offline   Reply With Quote
Old 03-31-2011, 10:33 PM   #3013
Strodder
Strodder's Avatar
Allan $hit happens.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-01-2011, 12:00 AM   #3014
daverod
SSN 706
daverod's Avatar
He's a sleep walker. Does bodywork late at night with the lights off.
daverod is offline   Reply With Quote
Old 04-01-2011, 01:46 PM   #3015
ruffrida2005
did something get Hot? looking good Alan!
Paul
Old 04-01-2011, 05:30 PM   #3016
flips72
flips72's Avatar
so im not the only one this crap happens to. looks good to me great job on the fuel door.
Old 04-01-2011, 10:44 PM   #3017
Alan's Classic
Allan $hit happens.
You talking about me or Dennis?
Yeah, my temper. J/K Nothing got hot unless I was hand blocking too fast. BTW thanks
Thanks, it must be the gremlins.
I did get my center seat welded up. The seats are ready for the upolstery shop.
Old 04-01-2011, 10:58 PM   #3018
Strodder
Strodder's Avatar
I don't need diapers yet. Not THAT OLD
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-05-2011, 06:11 PM   #3019
XtechX
XtechX's Avatar
Hey Alan or anyone who might be able to help. I sprayed a RTS epoxy primer on my truck, and its been on the truck for a week or better. I sprayed some HB can primer on the epoxy to prepare for a guide coat and the primer cracked ( like wet lightening bolts) every where there was epoxy. I dont think the epoxy ever fully dried completely. If I was to run a DA over it, it gums up. What do I have to do now? Sand it all off? Or will it eventually dry completely? I had planned to spray poly primer next, is that a bad idea? I'm open to suggestions, I really hope I dont have to sand it all off because of the gumminess underneath because I epoxied the interior too, what a pain.
Old 04-05-2011, 09:00 PM   #3020
Strodder
Strodder's Avatar
I've had the same problem. I guess some primers are lacquer based, and will eat enamel. Lacquer primer should be only sprayed on first. Is that right Allan?
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-05-2011, 10:00 PM   #3021
Alan's Classic
Sorry guys I don't have a good answer. A question like this might get a better answer in the paint and body section. I don't want to mislead you. I'm not familiar with RTS. Did you mix it right? What is HB? I'm drawing a blank here.
Old 04-05-2011, 10:37 PM   #3022
XtechX
XtechX's Avatar
RTS ready to spray...It was already mixed and ready to go...I guess.
It did spray thick though, I had it shaken at the hardware and stirred it real good. I sprayed it with my old Devilbiss conventional style gun, I dont know what size tip it has. I had to turn the pressure up to get it to spray.
The HB is high build primer (Rustoleum primer sold at Wal Mart). Is spray bomb primer like that laquer based? That would explain why it "cracked"..?
So if I get that primer off the truck, do you think its ok to shoot the polyester primer over the epoxy thats on there even though its slightly gummy underneath? Hopefully it will fully cure when it gets warmer around my neck of the woods?
Old 04-06-2011, 04:28 PM   #3023
Alan's Classic
I wouldn't spray anything else on it til what you have cures out. If it doesn't cure out then it needs to be removed. There are probably more opinions on this, but it's my .02.
Primed the front of my fenders and the bad spot in the bed.
Got to meet west9378 today discussing some work he needs done to his truck.
Old 04-07-2011, 03:48 PM   #3024
XtechX
XtechX's Avatar
Thanks Alan, I got the package, everything is real nice.
Old 04-07-2011, 11:22 PM   #3025
198plus
198plus's Avatar
I was told when lacquer is used over an epoxy primer, there is a risk of lifting. I'm using urethane primer PPG K-36.
198plus is offline   Reply With Quote
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange
