09-02-2019, 09:51 AM | #3101 |
Re: PO has me PO'd
[url=https://flic.kr/p/2h9kW8j]20190902_094448
now that I have the right patina( 2 years in the backyard), I want to put in a tank and pump so my balls float around the glass housing
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
09-02-2019, 10:48 AM | #3102 | |
Equal opportunity joke ofender
Re: PO has me PO'd
I have to tell ya that that was a disturbing email update to read without the picture there
Members I have met. Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb https://paypal.me/6772GMtruckparts Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type. |
09-03-2019, 09:38 AM | #3103 |
Re: PO has me PO'd
sorry about that, but it would be better than living in a cardboard box in Philly
09-10-2019, 11:17 AM | #3104 |
Re: PO has me PO'd
09-11-2019, 05:02 PM | #3105 |
Re: PO has me PO'd
[url=https://flic.kr/p/2he5JEQ]20190911_165500
even the ones with 50 years machining have a bad day, clamping force just was'nt enough,end mill sucked into part, luckily you won't see it odd shaped part, will redesign with a spacer and machine off all the ugly This was my third attempt to fit over the timing cover
09-12-2019, 09:44 AM | #3106 |
Carpe manana
Re: PO has me PO'd
Wow. No injuries then?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-12-2019, 04:13 PM | #3107 |
Re: PO has me PO'd
No Pete, just my pride and the billet timing pointer! Still looking for a solution, have a sheet metal Mr gasket one in hand, see if I can modify that
09-13-2019, 12:30 PM | #3108 |
Re: PO has me PO'd
[url=https://flic.kr/p/2heRmst]20190913_111230
This may work after all, just have to order some .750 x .250 diameter spacers, give it something solid to pull up on [url=https://flic.kr/p/2heTW96]20190913_111354 this all can be removed after we establish TDC
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-13-2019 at 12:36 PM. |
09-13-2019, 03:40 PM | #3109 |
Re: PO has me PO'd
09-13-2019, 06:32 PM | #3110 |
Re: PO has me PO'd
I agree, but the installer,said "take it off"
09-17-2019, 11:53 AM | #3111 |
Re: PO has me PO'd
SNAFU revision1 part2
mounting flange collapsed, well nuts sucked tank mount down, pictures to follow on evening news at 6 PM...camera batteries low
09-17-2019, 12:02 PM | #3112 |
Re: PO has me PO'd
Hint Vaporworx.com
09-17-2019, 06:51 PM | #3113 |
Re: PO has me PO'd
[url=https://flic.kr/p/2hh2TKq]20190917_184615
Newer in tank pump use a standardized mounting hat, ordered hat trying to contact Carter to get specs on pump #P76088M Can't believe these well nuts sucked the sheet metal up, bad design on my part
09-18-2019, 09:40 AM | #3114 |
Re: PO has me PO'd
cancel search for carter pump...made in China
09-18-2019, 09:05 PM | #3115 |
Re: PO has me PO'd
10-4 on cancel the China pump......
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
09-20-2019, 07:42 AM | #3116 |
Re: PO has me PO'd
yeah, I've got enuff problems without low quality parts, heck they probably stole the blueprints from carter
09-20-2019, 10:33 AM | #3117 |
Re: PO has me PO'd
case in point, my fault for buying cheap....
[url=https://flic.kr/p/2hibwpk]20190920_102639 [url=https://flic.kr/p/2hi8ST8]20190920_102744 30 thou. off
09-24-2019, 07:50 AM | #3118 |
Re: PO has me PO'd
This is the locking ring and SS mount I picked up from VaporWorx, now I have to figure out how to attach to fuel tank. This seems to be the new industry standard for electric fuel pumps
[url=https://flic.kr/p/2hk9x9E]20190924_074530
09-24-2019, 01:12 PM | #3119 |
Re: PO has me PO'd
Installer seems to have been able to get quite a bit done, timing done with cam and crank sensors, adjusted valves, and installed poly locks correctly, working on fuel pump purchase, wiring to all sensors, and power to battery and grounds, trans. temp. ran and done, worked on mounting plenum, I was short one bolt.
Also cranked to motor over and got 60 psi up to rockers and push rods, other than the popping thru the 4 missing plugs, he said it sounded good I lost 3 spark plug wires, in the rush to clean up basement, so the plumbers could install new soil pipe(6" cast iron to PVC) That's about where I'm at, at the moment, still have to source out a welder to tig the ss mount to the tank, but need fuel pump first to check height WOW, 400,000 views, seems like yesterday I started this build, it's been a great trip with all of your inputs. Best board on the net
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-24-2019 at 01:18 PM. |
09-24-2019, 01:27 PM | #3120 |
Re: PO has me PO'd
Hey Jaros - you got a pic of your whole truck? I've bounced in and out of your thread for years but I'm not sure I've ever seen the whole thing!
09-24-2019, 04:00 PM | #3121 |
Re: PO has me PO'd
just the ones at #3090 post, thanks for stopping by
09-25-2019, 11:54 AM | #3122 |
Re: PO has me PO'd
Here ya go 71, just uploaded, right off the press. read all about it. That's the genius himself, walking under the comp. banner, behind the scenes
[url=https://flic.kr/p/2hkJMA5]20190925_103059 [url=https://flic.kr/p/2hkKvEg]20190925_103035 [url=https://flic.kr/p/2hkKvEr]20190925_103008
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-25-2019 at 12:12 PM. |
09-25-2019, 11:57 AM | #3123 |
Re: PO has me PO'd
more...
[url=https://flic.kr/p/2hkKvPE]20190925_103120 [url=https://flic.kr/p/2hkKvRJ]20190925_103143 [url=https://flic.kr/p/2hkKvRJ]20190925_103143
09-25-2019, 12:00 PM | #3124 |
Re: PO has me PO'd
more...
[url=https://flic.kr/p/2hkGW9y]20190925_103204 stage 8 bolt installed [url=https://flic.kr/p/2hkKvZE]20190925_103219 [url=https://flic.kr/p/2hkKwbG]20190925_103241
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 09-25-2019 at 12:06 PM. |
09-25-2019, 12:01 PM | #3125 |
Re: PO has me PO'd
first oil flow in twenty years, heads can except ol style valve covers or center bolt
[url=https://flic.kr/p/2hkKwda]20190925_104833 these guys are doing the work [url=https://flic.kr/p/2hkJN9e]20190925_104930
