Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 12-23-2012, 02:40 AM   #301
White70C20
White70C20's Avatar
Re: 67-72 C/K/T-40's-90's!
Just a quick question: Did they use the same cabs for the C/K 10-30s and 40-90s. I was at a junkyard last week and they had a '70 C60. Its cab was identical to my C20.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 12-23-2012, 09:53 AM   #302
The windshield frame,dash,inner kick panels,top (inside/outside),and back panel (inside/outside) are the same
Old 12-23-2012, 03:23 PM   #303
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
You could probably make it work on a pickup, and modify the fender sides of the flip up hood to be more "Pickup like".
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-23-2012, 04:33 PM   #304
White70C20
White70C20's Avatar
That's what it seemed like to me.
Aren't the medium duty "straight trucks" wider than the pickups? That would be awesome to try sometime, put a C60 cab and front clip on a C30 chassis, then maybe put in a 4-53 Detroit.
White70C20
2005 Pontiac G6
Old 12-23-2012, 06:43 PM   #305
C10 - C90 Bill
C10 - C90 Bill's Avatar
They are the same width.
I personally think it would look awkward having a C-60 Cab on a C-30, but then again, I've never seen one. A 4-53 will fit into the C-30 as it is. I may just get one into one of my trucks yet.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 12-23-2012, 07:02 PM   #306
It's the same cab,but it isn't. Cabs are "assembled" from various panels. The ones that are different are the floor and cowl area panels because the frames & drivetrains are completely different and the whole front clip is different and they mount up different. The engine is actually crowded back farther into the firewall,so the firewall panel is different. You could combine a C/50 cab and a C/10 cab to make one or the other. Problem is,other than all that work,is the areas that are different are the areas that are usually bad.
We have a member here,Livrat,who is building a crew cab combining an MD truck cab & Suburban and using a MD front clip on an MD frame (I think)
Old 12-23-2012, 08:27 PM   #307
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Oh yeah I forgot about that burb, or is it another one because I thought he finished a long time ago.
Tony
Old 12-24-2012, 02:45 AM   #308
keithn
Originally Posted by C10 - C90 Bill View Post
Interesting truck. Seems to be all original.
Keep us posted if you buy it.
The truck is all original. The owner purchased it new and only hauled asphalt with it. I actually had the pleasure of driving it about eight years ago.
keithn is offline   Reply With Quote
Old 12-24-2012, 04:49 PM   #309
MattBMiller
MattBMiller's Avatar
I picked up a 71 GMC 5500 today with 15k original miles on it. Planning on making a 5th wheel/gn hauler out if it. I'll get pics up after Christmas
MattBMiller is offline   Reply With Quote
Old 12-24-2012, 08:29 PM   #310
All#sMatching71GMC
All#sMatching71GMC's Avatar
Here is the old "Winch Truck" 1967 C-50 with it's original 327. It was first titled in 1969, and used in a salvage yard until the late 70's when it was purchased by my great uncle Joe as a thank you gift for my Dad. My dad painted his 1955 Chevy and he liked it so much he bought my dad this old beast. He knew how much the truck was needed for around his shop. It's seen it's better days, that's for sure! But it still fires right up and drags whole trees out of the woods, or picks up some of the biggest rocks you've ever seen with its 30 ton winch. It's been rolling around on level ground, waiting for some attention for about two years...I want to get the brakes working properly again, and put some new doors, cab corners and rockers back on it, and just keep it going. It definitely deserves it! I have a great amount of respect for this machine. Reason One: It will kill you! lol Two: It has been around since I can remember with minimal maintance! Had there been a place to store it, it probably wouldn't need much of anything fixed. Three: Every time a job has called for it...it fires right up faithfully, and gets the job done! And Four: This truck very well could be the cause for my 67-72 Chevy truck illness!
1971 GMC LWB C-10 Restoring as close to original: http://67-72chevytrucks.com/vboard/s...d.php?t=555745
1968 Chevy LWB C-10 to SWB "Basket Case" Cab off build: http://67-72chevytrucks.com/vboard/s...d.php?t=555715
All#sMatching71GMC is offline   Reply With Quote
Old 12-24-2012, 10:34 PM   #311
C10 - C90 Bill
Looks like a tough 'ol truck. I like the Spoke Wheels. It is rare to see them on a C-50.
GMC 9500 Fan
Detroit Diesel Fan
Old 12-25-2012, 10:33 AM   #312
Katrina/10
Katrina/10's Avatar
Very tough truck! Got any pics of the winch?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-04-2013, 01:15 AM   #313
locomotive breath
locomotive breath's Avatar
I finally put my '71 GMC on the road this past weekend. Put about 110 miles on it and did pretty good. The notchy Clark 5 speed + 2 speed rear takes some getting used to though. I don't know if I'm not shifting the 2 spd rear right or not but it seems to grind and take several seconds to shift from high to low range. However, it shifts from low to high just fine???
I stopped at the scales on the way home and I was grossing 29K.
'50 GMC 350 COE, 702 V-12 / 4L80E powered
'71 GMC 6500, 427, 5 spd
locomotive breath is offline   Reply With Quote
Old 06-04-2013, 07:39 AM   #314
Man, I am so jealous! You have the perfect set-up right there
Old 06-04-2013, 09:06 AM   #315
C10 - C90 Bill
Nice looking set up.
When Shifting the Rear from High to Low, hit the button down just a little before you need it. If it is a "Split Shift", shift the trans first, then hit the button and let the rear engage while you are releasing the clutch for your trans shift.
By the way, others may say different, but I always use the Clutch when shifting the rear as well. About the only time I would not use the clutch, would be going from Low to High in 5th. That shift is usually pretty smooth.
GMC 9500 Fan
Detroit Diesel Fan
Old 06-04-2013, 10:46 PM   #316
locomotive breath
Thanks guys,
I going to continue to practice. It has the working 5 speed so I'm also having to re-train my brain for 4L-5L-4H-5H shift as well. I think I like the old RoadRanger 10 speeds better.
Old 06-05-2013, 12:51 AM   #317
C10 - C90 Bill
I agree, I like a Road Ranger a whole lot more, but a 2-Speed Rear is better than no 2-Speed.
Having that type of 5-Speed is really nice as you can go through 9-Speeds and only having to deal with engaging Low with the button down twice (skipping 1-H if you have a granny gear first).
GMC 9500 Fan
Detroit Diesel Fan
Old 06-23-2013, 03:35 AM   #318
greywuuf
Dan, That's OK, you will now have room for that Detroit you are talking about.
A 5 X 3 would be a good combination behind a 4-53. Even though I'm a 10-Speed Road Ranger fan, I also wouldn't mind having Twin Sticks.
Man I know this is an OLD thread, but I thought I should mention.... I bought a Brand new short block for this truck .... it came from a gm dealer as a replacement truck motor, and went to a truck shop but unfortunately got stored in a shed that had a roof collapse and when I asked about it,, the guy got it out and had one piston lightly stuck... so he smacked with a hammer and broke it I tore it down and took the 7 good pistons and the bare rod to the machine shop along with a new GM piston and had it pressed on..... so we are back to a factory new short block ( tall deck had my original small port truck heads rebuilt) and the complete motor that came out of it....
it will likely go back as original ... still don't know where to get a shift tower for a 5756b Spicer though........ oh and just in case everyone is lost... this is the 427 truck motor, unfortunately not a detroit
Seeing locomotives breathes on the road has inspired me.
greywuuf is offline   Reply With Quote
Old 06-23-2013, 06:07 AM   #319
greywuuf
Originally Posted by locomotive breath View Post
Here is my contribution to this thread. I picked this up last week about 30 miles from home. It is a 71' GMC 6500 with a really good running 427, 5 speed, 2 speed rear, and air brakes. The previous owner passed away a few years ago and it looks like he took pretty good care of it. I plan on using it to pull my 32' GN trailer.
I still have to get the title transferred, change all the fluids, and clean it up good. I am curious as to what kinda mileage I can expect though. It has 6.50 gears on the high side and 42" tall 10.00-20s which should work out to 3400 rpm at 65 mph. I'm hoping to average 7 mpg towing approximately 16,000 lbs. Anyone think that kinda mileage is possible on long trips if driven right?
I know you have driven yours now and have probably answered this, but my Bro inlaw works at a lumber mill and they have a couple newer 60's with the 427 5x2 combo and huge plywood boxes on them ( like 8' tall think driving a WALL) and he said they used to figure about 6-7 mpg loaded ( firewood or lumber)
Old 06-25-2013, 10:54 PM   #320
locomotive breath
Thanks, I haven't put pencil and paper to it yet but I could live with 6-7 mpg.
Old 06-26-2013, 07:39 AM   #321
Still takes two hands to count the mileage,right?
Old 06-26-2013, 08:29 PM   #322
locomotive breath
So far, but not by much
Old 06-26-2013, 08:32 PM   #323
Don Quixote
Don Quixote's Avatar
I regret not having a picture but I worked in a quarry in NH years ago. We had an '82 C-60 six-wheeler we used to call Stub. We all drove old Macks with Mack-10s or 8spLLs or mine with the 6sp you could eat a sandwich between gears but this little truck would kick all of our a**es. It had a little kitty with a 5sp and 2sp rear that shifted when it wanted to and made sure to let you know it was mad about it. Funny thing that after all the abuse we put old Stub through, it did not break, ever. We broke, it didn't.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves
Jorge: Kia Roller-skate with lots of buttons for the wife
Wovoka: 2017 Indian Chief Vintage, better on gas but not much
So far, this is the oldest I've ever been.
Don Quixote is offline   Reply With Quote
Old 06-30-2013, 01:53 PM   #324
GM72K10
Next!
GM72K10's Avatar
E80 Dump, (yes they were E80s not C80s) 1965? GMC version was a B series. Auction ad had it listed as a 1970 though. Someone got a nice truck for $1400.00
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 06-30-2013, 04:05 PM   #325
Wow! It's been so ling since I've seen a Chevy I forgot they made them. What a deal!!
