Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-21-2013, 11:27 PM   #301
Captainfab
60-66 Nut
Re: Power Steering Adapter Plates
Reply sent
Originally Posted by skooks View Post
Sent you a pm about payment
Old 02-22-2013, 01:05 PM   #302
skooks
Sent you a PM
skooks is offline   Reply With Quote
Old 02-22-2013, 02:35 PM   #303
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
You know with all the free advise Captainfab gives out to everyone, you would think this thread would be permanent at the top of this section.
Old 02-26-2013, 01:30 AM   #304
hamllik
hamllik's Avatar
Hi I have a 64 k20 4x4 and I have been researching on conversion brackets. Most I have seen drop the bottom bolt below the frame. I noticed yours does not. All the installs that I have seen on the other kits use one of the original steering holes for alignment for the new bracket. Does your bracket use any of the factory holes for positioning of the bracket? Thank you for your time.
hamllik is offline   Reply With Quote
Old 02-26-2013, 02:00 AM   #305
Captainfab
60-66 Nut
On the 2wd's none of the original holes are completely used. There is one hole that needs to be elongated for the power steering box. The supplied template helps you locate the new holes. I'm not sure exactly how this works out on the 4x4's as I have not installed one, and have not heard back from any of my customers that have. I guess I need to contact them. There is a thread in the '60-'66 section about power steering on a 4x4 with some good info in it.
Old 02-27-2013, 10:38 AM   #306
skooks
Hello John
Received the adapter plate yesterday. A guality part, very nice welds. Thanks again. Mark
Old 02-27-2013, 11:21 PM   #307
Captainfab
60-66 Nut
Thanks for the compliment Mark
Hello John
Old 03-04-2013, 04:54 PM   #308
68C20
68C20's Avatar
I am in need of one of your power steering adapter plates for my 68 K10. Do I also need the tube and flange or can the original be reused?
68C20 is offline   Reply With Quote
Old 03-04-2013, 11:55 PM   #309
Captainfab
60-66 Nut
I believe you should be able to use your steering column as it is. I do know that on the 2wd '67-'72's the steering column is the correct length for a power steering box as it is from the factory. I would assume that the 4wd's are the same? If I could see a pic of yours I could tell you for sure. I'll send you a PM with payment info.
Old 03-07-2013, 09:56 PM   #310
68C20
68C20's Avatar
PayPal sent.
Old 03-08-2013, 12:15 AM   #311
Captainfab
60-66 Nut
Replied to your PM......Thanks for the purchase
PayPal sent.
Old 03-23-2013, 03:08 PM   #312
63swb
63swb's Avatar
Captainfab, I am needing one of your power steering adaptor plates for my 63 Chevy C10 2WD.
63swb is offline   Reply With Quote
Old 03-23-2013, 10:55 PM   #313
Captainfab
60-66 Nut
I replied to your PM
Old 03-27-2013, 12:51 AM   #314
rawraw67
rawraw67's Avatar
dose your power steering adaptor plates come with a rag joint connector?
rawraw67 is offline   Reply With Quote
Old 03-28-2013, 12:00 AM   #315
Captainfab
60-66 Nut
The adapter plate and the tube and flange are sold seperately. The tube and flange is shown in posts #126 and 137. Let me know.
Old 04-03-2013, 11:04 AM   #316
T Smith
T Smith's Avatar
Need a bracket for my 66, PM sent.
T Smith is offline   Reply With Quote
Old 04-03-2013, 11:34 AM   #317
Str8axle
Str8axle's Avatar
Cap'n, I'm ready for a bracket and a tube+flange for my '65. These look top notch!
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-03-2013, 08:56 PM   #318
Sizemore 65
Captain, I would like to get two power steering plates, one tube and flange, and one powder coated power brake adapter plate.
Aaron
Sizemore 65 is offline   Reply With Quote
Old 04-03-2013, 11:46 PM   #319
Captainfab
60-66 Nut
I replied to your PM T Smith.....
I'll send you both PM's with ordering info.
Aaron
Old 04-18-2013, 05:22 PM   #320
Gabriel314
Hello Captin Fab I have a 68 short bed looking to install your plate I currently have washers inbetween frame and box Iam a new member so where do we start? What's a PM?
Gabriel314 is offline   Reply With Quote
Old 04-18-2013, 11:32 PM   #321
Captainfab
60-66 Nut
Hello. Do you have a '68 C series or a K series truck?
On a '68 C series frame, you shouldn't need any spacers at all, as '68 was the firest year that integral power steering was available on the C series trucks. Perhaps your frame is an early '68 or a '67 frame. In that case all you need are four 1/4" spacers, which I do also sell for $4.00 each plus shipping. You really don't need thos adapter plate for your frame unless you have a K series truck. Then this adapter plate will work for you.
A PM is a Private Message, which is basically an email that is restricted to just this forum. One way to send one is to click on "User CP" and then scroll down to where you see "New Message" on the left under the "Private Message" category. Or you can send me an email at captainfab454 at hotmail dot com
Let me know what you have, and we'll go from there.
Old 04-19-2013, 12:12 AM   #322
Gabriel314
I believe I have a c10 1/2 ton 6 lug with a 250 4 speed manual. Yea my frame definitely doesn't have the Dimple this is why I used two washers for each bolt about a 1/4 inch thick. I will take the spacers.
Old 04-19-2013, 01:17 AM   #323
Captainfab
60-66 Nut
I sent you a PM with payment details.
Old 04-21-2013, 01:52 AM   #324
Snowbound
Snowbound's Avatar
I finally bolted the adaptor plate on and it fits great! I ended up buying a van tilt and lower shaft from a 69 GMC so I did not use the steering shaft adapter.
I can send it back or forward to a customer if you like. I have no use for it now.
Thanks again for a great product.
Brian
1965 Chevy Short Box Stepside, 230 - 3 speed, 4:11 gears, original paint rust free survivor. Now sporting a 383 SBC and TKO-600
Snowbound is offline   Reply With Quote
Old 04-21-2013, 11:21 PM   #325
Captainfab
60-66 Nut
You can return it for a refund if you like, but it might cost you close to the cost of the tube and flange to ship it back. You might be better off to sell it to another Canadian member.
Brian
